Old 08-27-2013, 06:08 PM   #57
boarder1995
Drives: 2013 Subie BRZ Limited, black, 6MT
What is the benefit to coating struts with bread crumbs?
Ya, lots of dirt roads this past weekend, plus a little bit of rain, and everything gets the red clay treatment! It's now washing off the struts and onto the barrel of the wheel behind the spokes - very noticable unfortunately.
boarder1995 is offline   Reply With Quote
Old 08-27-2013, 06:09 PM   #58
UnOvertime
UnOvertime's Avatar
Drives: Firestorm FR-S AT
Flavor
UnOvertime is offline   Reply With Quote
The Following User Says Thank You to UnOvertime For This Useful Post:
Mr. (08-28-2013)
Old 08-27-2013, 07:09 PM   #59
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by boarder1995 View Post
Here's what a lifted BRZ would look like - it'd be fun with some serious rally driving!
If I could find a cheap BRZ/FRS that wasn't half wrecked, this would be a reality.
Old 08-27-2013, 07:23 PM   #60
leon78
leon78's Avatar
Drives: 13 Whiteout
5mm spacer will be needed in the front
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 08-28-2013, 09:57 AM   #61
boarder1995
It's clearing currently - just not sure by how much - at least several mm. I slid a thick paper card in there and wiggled it in and out and it seems to have several mm gap. I need to get a better angle with the photo as the lense on the iPhone from the photo direction (from the rear) would work better on passenger side to be more in line. What's a recommended clearance in your opinion?
Old 08-28-2013, 12:17 PM   #62
leon78
leon78's Avatar
Drives: 13 Whiteout
I had +42 17x9 rota grids and it does clear with no spacer and when the wheels are strait, but go drive around a parking lot at full lock both directions like a race car. Then look at the inner lips of the wheel, then PM me about the 5mm spacers you need that I happen to have left over.
Old 08-28-2013, 03:21 PM   #63
boarder1995
It'll be the tire that'll rub, correct? I believe the spring perch is a bit above the 17" rim. I'll investigate with some speedy parking lot turns.
The Following User Says Thank You to boarder1995 For This Useful Post:
Leonardo (11-19-2018)
Old 08-28-2013, 11:39 PM   #64
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
The dw tires must run wider compared to other tires.. I have 17x9 et45 with 245/40 hankook evo v12s and I have slightly more clearance more clearance and I'm at -.5 degree of camber in the front which is as much as the oem bolts will slip to. I am considering getting some 3mm spacers just to be safe.
garfull is offline   Reply With Quote
Old 08-29-2013, 10:15 AM   #65
boarder1995
A couple more clearance pics. Ignor the rubbed off dirt - it's from me feeling around, not the tire.
Old 08-30-2013, 07:20 AM   #66
SortaFlushed
SortaFlushed's Avatar
Drives: Raven Black
XD
SortaFlushed is offline   Reply With Quote
Old 08-30-2013, 11:25 AM   #67
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
Wow ... if you aren't going to change out your coils/springs ... maybe a couple 5 mm spacers to get some more clearance?? I wouldn't be comfortable with that small amount of space.
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
Old 11-18-2013, 07:37 PM   #68
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Merged @boarder1995's topic: same wheels w same specs
Old 01-30-2014, 10:09 PM   #69
Ymerej
Ymerej's Avatar
Drives: Whiteout FR-S
Can someone help me out please?
I can't seem to get an answer this but I have 17x9 +42 rota grids getting tires next week. In a month I'll purchase BC Coilovers. Will I need spacers? or should I be good to go? I'm not sure what tire size to run without issues. Hopefully I can get an answer
Ymerej is offline   Reply With Quote
Old 01-30-2014, 10:28 PM   #70
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
You won't have any issues. Common tire widths would be 245/35-255/35. If you are still N/A then the 245's will probably suit you better.
OjiGeorge is offline   Reply With Quote
The Following User Says Thank You to OjiGeorge For This Useful Post:
Ymerej (01-30-2014)
Wheel Directory: Rota DPT 17x9.0 +42 Scooby South Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 90 06-16-2017 01:25 PM
Wheel Directory: Rota Torque 17x9.0 +30 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 113 09-09-2013 10:19 PM
Rota Grid 18x10 30et Nizz300Ft86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 08-14-2012 11:34 PM
??? ROTA Grid Concave 18x10 30et??? Nizz300Ft86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 08-12-2012 04:43 PM
