Old 11-18-2013, 03:58 PM   #1
Hachi86Roku
Hachi86Roku's Avatar
Ideal ride height for best suspension geometry?
Hi, I recently bought a set of coilovers and I am very confused on how to setup my ride height for proper performance at the track and for autocross. Right now I am at -1.5" front and -1.75" rear, and I feel that is way too low since at this height the rear lca is pointing up and that the camber can only go to -2.0 max even with adjustable lca. For Next season I am looking to raise the ride height to get -1.5 rear camber since i dont seem to be using all the Tire at the rear when i went for a track day.
do you guys have any advice in what is the perfect ride height to achieve good suspension geo??
STX Whiteout Build Thread
http://www.ft86club.com/forums/showthread.php?t=47980
Anybody in the West Lafayette, IN area pm me
Hachi86Roku is offline   Reply With Quote
Old 11-18-2013, 04:00 PM   #2
CSG Mike
CSG Mike's Avatar
Stock height is ideal for geometry.
How much does the actual geometry matter? Well.... we don't run any correction.
Old 11-18-2013, 04:14 PM   #3
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
why not?
Old 11-18-2013, 04:35 PM   #4
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I can't imagine the contrary to this would readily be found.
PRO86 | WTCC | STL
Old 11-18-2013, 04:54 PM   #5
CSG Mike
CSG Mike's Avatar
Originally Posted by 7thgear View Post
why not?
Diminishing ROI, and we don't really have the money to dedicate to experimenting with geometry...
Old 11-18-2013, 05:46 PM   #6
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
but it costs nothing to just raise to OEM using existing coilovers..
Old 11-18-2013, 05:52 PM   #7
CSG Mike
CSG Mike's Avatar
Except we'd lose all droop travel... and our coilovers aren't capable of going that high to begin with
Old 11-18-2013, 06:02 PM   #8
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
http://www.ft86club.com/forums/showthread.php?t=10643
Post 11
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
The Following User Says Thank You to SubiePig For This Useful Post:
Hachi86Roku (11-19-2013)
Old 11-19-2013, 07:46 AM   #9
Racecomp Engineering
There are a lot of trade-offs.
You're making a compromise with suspension geometry, travel, and center of gravity.
In some cases (CSG for example) running pretty low with less than ideal geometry but a really low center of gravity works well since they are running fairly high spring rates and a good amount of camber. And I suppose they don't need to clear driveways and all that.
With softer rates, a higher ride height might be more advantageous.
- Andy
JMon85 (06-04-2018), WillRacer1jz (11-19-2013)
coilover, height, low, ride
Stock ride height numbers? xwd Tracking / Autocross / HPDE / Drifting 16 07-11-2018 12:42 PM
Coilover to Raise Ride Height Furtive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 07-28-2014 12:57 PM
Questions on Suspension Geometry Zach3794 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 07-02-2013 10:53 PM
Stock ride height or lower? StevenDavisPhoto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 156 01-31-2012 10:58 AM
Lower ride height in NYC? blur NY / NJ / CT / PA 9 01-19-2012 06:31 PM
