Ideal ride height for best suspension geometry?
Hi, I recently bought a set of coilovers and I am very confused on how to setup my ride height for proper performance at the track and for autocross. Right now I am at -1.5" front and -1.75" rear, and I feel that is way too low since at this height the rear lca is pointing up and that the camber can only go to -2.0 max even with adjustable lca. For Next season I am looking to raise the ride height to get -1.5 rear camber since i dont seem to be using all the Tire at the rear when i went for a track day.
do you guys have any advice in what is the perfect ride height to achieve good suspension geo??
STX Whiteout Build Thread
http://www.ft86club.com/forums/showthread.php?t=47980 Anybody in the West Lafayette, IN area pm me ![]() |
#2 |
Stock height is ideal for geometry.
How much does the actual geometry matter? Well.... we don't run any correction. |
#3 | |
i'm sorry, what?
Drives: Canada
#4 |
Drives: Nevermorange FRS
I can't imagine the contrary to this would readily be found.
PRO86 | WTCC | STL
#5 |
#6 |
i'm sorry, what?
Drives: Canada
but it costs nothing to just raise to OEM using existing coilovers..
#7 |
#8 |
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
![]() Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication STX Build thread 14th/67 SCCA Nationals (2014) |
| The Following User Says Thank You to SubiePig For This Useful Post: | Hachi86Roku (11-19-2013) |
#9 |
There are a lot of trade-offs.
You're making a compromise with suspension geometry, travel, and center of gravity. In some cases (CSG for example) running pretty low with less than ideal geometry but a really low center of gravity works well since they are running fairly high spring rates and a good amount of camber. And I suppose they don't need to clear driveways and all that. With softer rates, a higher ride height might be more advantageous. - Andy |
| The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | JMon85 (06-04-2018), WillRacer1jz (11-19-2013) |
| Tags |
| coilover, height, low, ride |
| Stock ride height numbers? | xwd | Tracking / Autocross / HPDE / Drifting | 16 | 07-11-2018 12:42 PM |
| Coilover to Raise Ride Height | Furtive | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 48 | 07-28-2014 12:57 PM |
| Questions on Suspension Geometry | Zach3794 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 07-02-2013 10:53 PM |
| Stock ride height or lower? | StevenDavisPhoto | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 156 | 01-31-2012 10:58 AM |
| Lower ride height in NYC? | blur | NY / NJ / CT / PA | 9 | 01-19-2012 06:31 PM |
