Old 11-18-2013, 10:52 AM   #1947
ft86me
ft86me's Avatar
Drives: 2013 FRS
Originally Posted by RavSpec View Post
It should be +40mm offset, that's the spec for 57xtreme.
Yes will work. Front has plenty of clearance.
Thank you much good sir !
ft86me is offline   Reply With Quote
Old 11-18-2013, 01:00 PM   #1948
TONYpepperon1
TONYpepperon1's Avatar
Drives: 2013 CBS BRZ
Originally Posted by Slick View Post
Very close but do-able. A few are running 18x9.5+38 and making them work, you have a few extra mm's to play with. If you go with extra camber (other than lowering), you will be very close to the spring perch.
Tires are a good size, OEM diameter.
Im sorry im a little confused now. On one hand Slick is saying it will be very close but you RavSpec are telling me there will be plenty of room. Im not sure if both your answers are saying the same thing. If the 57xtremes are actually +40mm, wont that bring the wheels closer to the spring perch and give me LESS room? Im still trying to edumacate myself on wheels.
TONYpepperon1 is offline   Reply With Quote
Old 11-18-2013, 01:04 PM   #1949
RavSpec
Drives: Rx7
There are tons of BRZ/FRS already running 18x9.5 +40mm. Plenty of clearance.
We run both 19x9.5 +43mm and 18x10 +44mm without any issues.
RavSpec is offline   Reply With Quote
The Following 2 Users Say Thank You to RavSpec For This Useful Post:
ft86me (11-18-2013), TONYpepperon1 (11-18-2013)
Old 11-18-2013, 01:05 PM   #1950
RavSpec
Drives: Rx7
Use this , a very helpful guide
http://www.ft86club.com/forums/showthread.php?t=7535
The Following User Says Thank You to RavSpec For This Useful Post:
Old 11-18-2013, 02:18 PM   #1951
ft86me
ft86me's Avatar
Drives: 2013 FRS
Will this fit? (width, offset and tire size Qs)
Thank you for your input. Wouldn't really matter if I went 17x9.5 +40 with 255 50 17 would it ? I'm thinking of going that route instead. So from 18 to 17
What tire size for the 18x10 +44 and camber how much camber ?
Old 11-19-2013, 11:50 PM   #1952
BRO-027
Drives: 2013 Toyota 86
18 x 9.5 +38 square.. Which tyres?
Hey guys, hoping you can help me with my situation.
I have a set of Work Xt7s, 18x9.5 +38, square.
I have a set of BC coilovers, (extreme drop) coming, along with stance LCA and SPC toe arms.
I like the look of a low profile tyre - 35 or 40.
Dont mind a little bit of stretch, and want to go as low as possible.
(Purely for aesthetics on the street, i will have another set of wheels for track fun)
My question is, can i run a 235 or 245 with these specs? I dont really like the way the 225 looks stretched onto the 9.5 inch wheel.
Please help with some recommendations!
Brodie
BRO-027 is offline   Reply With Quote
Old 11-20-2013, 01:00 AM   #1953
FLIPs_FR-S
KCCO
FLIPs_FR-S's Avatar
Drives: 2013 Raven Scion FR-S, AT
Brodie
http://tyrestretch.com/
This will probably help with a least how it will look. If you haven't come across this site yet. I didn't look for your mentioned sizes though. They should be on there.
Sent from SAMSUNG GALAXY NOTE. KEEP CALM AND CHIVE ON.
Alabama state head for Southeast 86
https://www.facebook.com/groups/Southeast86/
FLIPs_FR-S is offline   Reply With Quote
Old 11-20-2013, 10:34 AM   #1954
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Brodie
I would run a 245/35R18. It will still look a bit stretched on a 9.5" wheel (my sig photo shows my 245/35R18 Conti Extreme DW on a 9" wheel) but not a crazy stretch like a 225. Plus you like the lower profile of the 35 series and it is the same diameter as stock. The 235/40R18 will be taller than stock.
Slick is offline   Reply With Quote
Old 11-20-2013, 11:15 AM   #1955
RavSpec
Drives: Rx7
Brodie
I agree, 245/35/18 perfectly fine.
I'll consider doing 255/35 on the rear.
Plenty of room.
Old 11-20-2013, 11:19 AM   #1956
RavSpec
Drives: Rx7
I run about -2 camber front and rear.
255/50 are a bit tall and I don't think that size tires are easy to get.
Maybe 255/45 and roll the fender.
Old 11-20-2013, 01:26 PM   #1957
jshadeck
jshadeck's Avatar
Brodie
Dont forget different tires/brands have different tread widths for the same sizes. Not all 235 have the same stretch on a 9.5" rim
jshadeck is offline   Reply With Quote
Old 11-20-2013, 04:50 PM   #1958
Fast_Freddy
Drives: Passat
Will 245-40-17 fit on 17x8 +35 rims with no rubbing or should I stick with 225-45? Stock springs and no intention of changing them. Could I do 225-45 up front and 245-40 in back or would it look weird on 8" rims? TIA
Fast_Freddy is offline   Reply With Quote
Old 11-20-2013, 05:32 PM   #1959
BRO-027
Thanks FLIPs_FR-S, Slick, RavSpec, and jshadeck.
I am thinking of running the suggested 245/35/18; on that tyre stretch site this size looks a lot better in my opinion.
One last question though, will there be much of a/any difference in how low i can go between 225 - 245?
Appreciate it guys.
Old 11-21-2013, 05:33 PM   #1960
kanundrum
Drives: 2013 Whiteout FR-S
Anyone know how much a 17x7 5x100 steelie would weigh ?
Trying to get winter tires and decide if I should buy steelies or just use some heavy 18's (Thin tire of course). NM Found out its 32lbs WOW
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
