Old 11-16-2013, 04:57 AM   #2199
s2d4
s2d4's Avatar
Originally Posted by OICU812 View Post
So even with inter cooler but higher temp by 10 deg C you lost 10+ whp? While it's obvious the intercooler helps but questionable just "how much".
Well, the only way to know is have one precharger and postcharger, then compare that between non-intercooled and intercooled.
The w2a setup in my MR2 has shown to be effective for +50 celcius improvement on a 20 mins track session and that's on a highly inefficient 80s roots blower. Granted I have a massive reservoir in that, nothing you guys can't do by utilising the space left over from going with a smaller battery.
The Following User Says Thank You to s2d4 For This Useful Post:
OICU812 (11-16-2013)
Old 11-16-2013, 05:08 AM   #2200
Kodename47
Kodename47's Avatar
Drives: UK GT86
I don't think the capacity is the issue, but an improved core may improve things one turning up the boost.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-16-2013, 07:07 AM   #2201
s2d4
s2d4's Avatar
This is all I am using
And just a tiny 350hp rated intercooler on frozenboost.
So yeah, pretty confident the reservoir size has massive benefits.
Old 11-16-2013, 08:41 AM   #2202
Kodename47
Kodename47's Avatar
Drives: UK GT86
It may well do on the Roots setup, but my tuner reckons that the temps stabilize quickly and therefore the capacity isn't an issue. I suggested I may do mine and he said he didn't see much benefit, it certainly wouldn't see a worthwhile power change. However a more efficient core inside the manifold may help reduce intake temps.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-16-2013, 08:52 AM   #2203
s2d4
s2d4's Avatar
Well roots type run a whole lot hotter, I've seen over 100 degrees Celsius after charger. Highest temp after w2a was 52 degrees over an entire track day.
In any case, more liquid takes longer to heat up. With the right size heat exchanger per fluid ratio, it'll make it even harder to heat soak with more fluid.
Are laminova cores really that bad compared to the conventional design? Mine is just some China unknown eBay special...
Old 11-16-2013, 12:00 PM   #2204
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Something I have been doing to track the performance of my car is use Virtual Dyno. The magnitude might not be correct but you can clearly see the difference. This will also fix any problems with cooling when you are on a stationary dyno so you can see more "real life" results. Here is a post from my build page proving that this program is actually consistent and repeatable.
Originally Posted by calispec View Post
So here are some tests that I did to verify that Virtual Dyno was at least repeatable and to see if my road was flat lol.
The first graph is 4 runs, all on the first tuner. Some of the variance could be because I wasn't starting exactly on the same spot, but close. I took them in alternating fashion. East 1 West 1 East 2 West 2.
As you can see my road is a little east bias. Its close enough for me. I could take the average of the two runs and see where that got me but I am not that concerned. It proved to me that the results were repeatable. Each run was made with about a 5 minute down time to let the vehicle cool. Its not perfect I know but its better than paying for dyno time. IMHO!
[IMG][/IMG]
The second graph shows again how my road is east bias. Both are the Delicious Tune.
[IMG][/IMG]
If I get another chance I'll head out to mexico again and do 6 or 8 runs to get some more data.
I don't have the charge cooler and it's too cold to do anything here so more data is going to have to wait till spring but once I get the cooler I WILL be collecting a LOT.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 11-18-2013, 02:42 AM   #2205
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
What is the best way to check if the charger is leaking?
I did a few runs against a stock 86 in 3rd gear from 3000rpm and the stock 86 pulled away until I reached 5000rpm where I pulled it back in and overtook it.
Not a happy chappie
Ryan86 is offline   Reply With Quote
Old 11-18-2013, 03:03 AM   #2206
Kodename47
Kodename47's Avatar
Drives: UK GT86
Not a happy chappie
Have you got no way of monitoring/logging what is going on? Doesn't seem like you're having the best of luck. Do you trust your tuner as really you should be discussing things over with them?
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-18-2013, 03:26 AM   #2207
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
He's using Delicious. My guess is the other guy was in first or second second.
Old 11-18-2013, 03:48 AM   #2208
Ryan86
Road Warrior
Ryan86's Avatar
Correct I'm using Delicious and have discussed this and sent the video.
The other guy claims he was in 3rd, I too presumed he cheated and dropped into 2nd as the way he pulled away from me just Did not make sense.
Bill said to check for leaks at the back of the Charger, so hence I asked what I could use to check if there is a leak, as I can't feel anything.
Old 11-18-2013, 04:07 AM   #2209
ft_sjo
Drives: GT86
You need to hook up a compressor to the intake somewhere, probably onto the throttle body would be easiest. Regulate the air up to about 1 bar should be adequate.
In your ambient heat though, if the ECU is mapped correctly, it will start to reduce power based on high air charge temperatures.
Old 11-18-2013, 05:49 AM   #2210
Calum
That Guy
Drives: 2013 asphalt FRS MT
Dish soap mixed with water in a spray bottle. It will make bubbles if there's an air leak.
Sent from my GT-S7560M using Tapatalk
The Following 2 Users Say Thank You to Calum For This Useful Post:
Ryan86 (11-18-2013), Team STILLEN (11-18-2013)
Old 11-20-2013, 01:02 AM   #2211
sw20kosh
Drives: 2013 Black FR-S
Trying to get a groupbuy going for FA20club's Sweet Twin Screw Aluminum Intake System.
Please PM me if you are seriously interested in getting one of these. If I can get 5 people the price is $299.00 each and a ship date of first week of december.
The Following User Says Thank You to sw20kosh For This Useful Post:
tech4pdx (11-20-2013)
Old 11-20-2013, 01:03 AM   #2212
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
for the entire pipe or just the part thats lil perrins?
really wish i have the money for the kit already. prepping for show problems lol
lbroskee is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
