Old 11-15-2013, 03:07 PM   #379
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Originally Posted by Deadspool View Post
I guess its not impossible to have a bad fan. Not all new parts work all the time.
Both of them though ?
Old 11-15-2013, 03:14 PM   #380
carlossanchez89
2Supras1FR-S
Drives: 13 Scion FR-S, 87 Supra
Neither of the two fans turn on
carlossanchez89 is offline   Reply With Quote
Old 11-15-2013, 03:17 PM   #381
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
That would make it highly improbable then.
If everything is plugged in, fuses are good.. Is there a coolant sensor JUST for the fans?
you have one dilly of a pickle on your hands.
Deadspool is offline   Reply With Quote
Old 11-15-2013, 03:20 PM   #382
Deadspool
Much title. Wow.
Deadspool's Avatar
Originally Posted by Dipstik-sportech View Post
Well they get power from the factory wiring harness so unless something is messed up in there (doubtful), it's either a bad connection or bad fans. Just because they're connected doesn't mean they weren't spliced in properly, heck they could be wired in backwards lol.
If they were wired backwards, they'd run backwards. puller becomes pusher.
Seems like no power at all. I would try running a jumper wire from the battery to the positive feed on the fans, and rule that out entirely.
These problems always end up being something stupid.
Old 11-15-2013, 03:20 PM   #383
SmsAlSuwaidi
Boosted
Time to go race car status and put a switch somewhere in your interior saying fans on top of it ( written with a sharpie ofc ) and switch it on every time you turn the car on
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
mack4477 (11-15-2013)
Old 11-15-2013, 03:55 PM   #384
mike the snake
That's not necessarily true. Reversing the polarity on some motors (brushless motors if I'm not mistaken) will not make them run backwards, but it can burn them out.
Old 11-15-2013, 04:40 PM   #385
Frs300
Frs300's Avatar
Drives: Pile of junk
reversing any 2 wires on a brushles motor will make it run backwards but wont change the polarity. this goes for both 3 phase ac/dc brushless motors.
Frs300 is offline   Reply With Quote
Old 11-15-2013, 06:39 PM   #386
mike the snake
You are correct. I was wrong, I remember that about brushless motors now.
Old 11-15-2013, 06:47 PM   #387
carlossanchez89
2Supras1FR-S
Ill push power to the fans individually and test that
The Following User Says Thank You to carlossanchez89 For This Useful Post:
SmsAlSuwaidi (11-15-2013)
Old 11-15-2013, 06:48 PM   #388
SmsAlSuwaidi
Boosted
Did you burn the stock ones or were they after market ? Maybe in that process something else got screwed ?
Old 11-15-2013, 07:30 PM   #389
RickyB
Drives: Mazdaspeed 3
The fan relays are controlled by the engine ECU, so no, there is no separate coolant sensor for the fans. Also, the system is set up so that either both fans run at low speed (just fan #3 relay energized), or the main fan runs alone at normal speed (fan #1 and #2 relays energized, fan #3 relay off) or both fans run at normal speed (all three fan relays energized).
RickyB is offline   Reply With Quote
Old 11-15-2013, 07:46 PM   #390
carlossanchez89
2Supras1FR-S
4 days after running the turbo kit the check engine light turned on.
about 2 blocks down smoke started to come from the engine bay. It went up to Hot and I turned the car off and pulled over.
The shop found the fans to be fried. They are new fans from Full Blown.
Old 11-15-2013, 07:47 PM   #391
carlossanchez89
2Supras1FR-S
This is something LJ from FUll Blown can help me with in the tuning right?
Old 11-15-2013, 07:48 PM   #392
SmsAlSuwaidi
Boosted
Woops... That doesn't sound good.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
