Old 11-14-2013, 11:19 PM   #1
grostoine
Drives: Subaru BRZ
MTEC shift springs
Do you have any feedback on these? : http://ft86speedfactory.com/mtec-shi...g-kit-949.html
Does it make a real difference?
grostoine is offline   Reply With Quote
The Following User Says Thank You to grostoine For This Useful Post:
dave77 (03-30-2014)
Old 11-14-2013, 11:20 PM   #2
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Yes one of best mods I did for sure 100% if you search this out there is lots of discussion on this spring set btw.
The Following User Says Thank You to OICU812 For This Useful Post:
dave77 (03-30-2014)
Old 11-14-2013, 11:42 PM   #3
zooki
Drives: waiting on a 2021...
I replied to another thread on these, but I'll tell you they are definitely worth it. I just installed them a couple of weeks ago to go with my Kartboy shifter, Kartboy transmission mount insert, and Perrin rear shifter bushing, and it all adds up to a very precise shifting experience. With Pentosin fluid in the trannie it feels like a well oiled rifle bolt sliding home. Much recommended!
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following 2 Users Say Thank You to zooki For This Useful Post:
dave77 (03-30-2014), whataboutbob (11-15-2013)
Old 11-14-2013, 11:47 PM   #4
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Totally worth it even on the stock shifter, feeling is believing...
** That's what she said...
FT-86 SpeedFactory is offline   Reply With Quote
The Following 13 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
Anthony (11-15-2013), continuecrushing (12-30-2013), dave77 (03-30-2014), diss7 (11-15-2013), flippy (02-24-2014), jflogerzi (02-24-2014), Mo707 (11-23-2013), pcporo (11-15-2013), Simply_the_best (04-30-2014), SirBrass (11-15-2013), SkAsphalt (11-15-2013), suaveflooder (01-02-2014), whataboutbob (11-15-2013)
Old 11-14-2013, 11:59 PM   #5
jamesm
Completely worth it. Best value mod I've ever done.
Old 11-15-2013, 02:16 AM   #6
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Do you need to drop the front pipe to gain access? Any special tools required?
Fizz is offline   Reply With Quote
Old 11-15-2013, 03:22 AM   #7
Luis_GT
Best mod ever... no need to remove anything aside from the cardboard panel
Old 11-15-2013, 03:43 AM   #8
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Worth it. Costs less than a dinner at a restaurant.
digital_assassin is offline   Reply With Quote
The Following User Says Thank You to digital_assassin For This Useful Post:
boxer 2.5 (11-15-2013)
Old 11-15-2013, 03:47 AM   #9
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Ok so I just had a quick peek under...one side requires a 10mm hex which looks easy enough to get to....but the other side needs a socket and looks like a bitch the get that out because not enough room.
By the way what size socket for that?
Old 11-15-2013, 03:55 AM   #10
digital_assassin
The domed nut is a bitch to get out without the right ratchet and socket combo. I ended up needing to hit Harbor Freight and the impact sockets were perfect depth. Put the socket on the nut and then push the ratchet onto the nut.
Old 11-15-2013, 04:00 AM   #11
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Thanks. I think it needs a 1 1/16 (27mm) socket. Did you have enough space to run a 1/2 drive to 3/8 adaptor?
Hmm I wonder if vice grips on the socket will work? LoL
Old 11-15-2013, 09:33 AM   #12
FT-86 SpeedFactory
The only special tool I would say that most don't have would be the 27mm socket.
27mm and it's actually pretty easy to get to.
Definitely do not use vice grips.
Install video guys, also on the page of our site.
[ame="http://www.youtube.com/watch?v=Jk8mkTfLANk"]MTEC Shift Spring Installation for Scion FRS / Subaru BRZ / Toyota 86 - YouTube[/ame]
The Following 4 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
DrDuquette (12-30-2013), Fizz (11-16-2013), ShoGun (11-16-2013), unsurety (04-05-2014)
Old 11-15-2013, 09:45 AM   #13
jdubious
Drives: 13 Scion FR-S
Yes it is a 27mm. I tried several setups and found the 1/2" to 3/8" adapter with a long flex head ratchet worked pretty good. You could always remove the front pipe to give more room. It was lock tighted in there and somewhat of a bitch. The 10mm has lock tight too and might be tough if using a regular allen like the video showed. There is not enough space to get a typical 1/4" allen socket in there, you will need a short one. Also there is not enough room to get a 1/4" torque wrench w/socket in there as the video suggested.
The springs are awesome btw
jdubious is offline   Reply With Quote
The Following User Says Thank You to jdubious For This Useful Post:
Fizz (11-16-2013)
Old 11-15-2013, 04:28 PM   #14
jamesm
that 27mm is a bitch to get off. i ended up having to use a breaker, and it felt like i was gong to hurt something lol.
>>>FT-86 SpeedFactory<<< Kartboy Short Throw Shifter Kits and MTEC Springs FT-86 SpeedFactory Transmission and Driveline 267 12-11-2016 10:20 PM
MTEC shifter spring install issue jamesm Engine, Exhaust, Transmission 36 12-06-2015 10:36 AM
DIY Trans Bushing, Rear Shift Bush, MTEC spring Q Ralph Spoilsport Engine, Exhaust, Transmission 7 10-31-2013 10:15 PM
HUD shift up and shift down display question JS86JS Electronics | Audio | NAV | Infotainment 6 05-17-2013 03:54 AM
MTec Industries Shifter Springs xravexboix Transmission and Driveline 2 04-24-2013 01:39 PM
