Old 11-13-2013, 10:17 PM   #127
DR 86
DR 86's Avatar
Originally Posted by Kostamojen View Post
No, the current instructions are MT only. AT doesn't have a plug because that plug is a pipe that goes to the ATF cooler.
Does anyone know if the line coming off that plug to the ATF cooler is a hard line or a hose that can be T'd?
Perrin CAI|Perrin MCB|P&L header|Motiv OP/FP|MXP catback|Tein Type Flex coilovers|Eibach F/R sway bars|GS front strut brace|Street:PM HC+800/Track:Carbotech XP10|StopTech slotted rotors/SS lines|SBC RPF1s|Street:FK453/Winter:Pirelli SottoZero3/Track:Toyo R888s|Leg Sport rear spoiler|EcuTek Tuned|OEM oil cooler|4th/F1 brake lights
DR 86 is offline   Reply With Quote
Old 11-13-2013, 11:12 PM   #128
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
Subbed, this mod has been added to my list of mods and with the price being pretty low this will probably be likely to be done, especially since lower oil temps should prolong engine life. Great write up!
Turkish is offline   Reply With Quote
Old 11-13-2013, 11:16 PM   #129
Turkish
Serial Cone Killer
Turkish's Avatar
Originally Posted by DR 86 View Post
Has anyone confirmed this application in an AT? Are the parts required exactly the same? Anyone have pictures from an AT of where that plug is? Thanks in advance!
I imagine looking at an AT FXT would be helpful in determining how to go about how to install in an AT BRZ. I am also driving an AT brz and want this mod. Unforunately the BRZ is my only car (read DD) so I am not likely to experiment around and be a guinea pig, things would be different if the BRZ was a second car. I hope this is figured out relatively soon! I was planning on springs for my next mod, but at the price for the oil cooler, this might be first.
Old 11-13-2013, 11:33 PM   #130
DR 86
DR 86's Avatar
I'm in the states on vacation and would like to pick up the parts for the oil cooler mod if it's compatible with the 6AT. If someone with an AT could just take a photo from under the car of the area near the driver side exhaust manifold, like this image
Old 11-14-2013, 12:13 AM   #131
Turkish
Serial Cone Killer
Turkish's Avatar
@CARNZ
I was curious as to why you chose to put the oil cooler in parallel to the heater and not in series? I am a newbie to car mechanics, and ignorant of many things (which I am enjoying fixing all that with my BRZ), so please don't skewer me if it is an "obvious" reason. This mod looks pretty easy and fun to do, the low cost makes this easier to do sooner rather than later too.
Old 11-14-2013, 01:49 AM   #132
Wasabi
おい、だいじょうぶ?
Wasabi's Avatar
Drives: BRZ Limited 6 Speed
Awesome!! Thanks for making it OEM! Also, this should give a big F you to all the manufacturers that are trying to sell their kits when this OEM setup obviously is the better choice!
Wasabi is offline   Reply With Quote
Old 11-14-2013, 02:35 AM   #133
Kostamojen
Installed mine today. Used all three metal pipes from the Forester, including the one along side the motor that CARNZ didn't use.
Pics:
Final install pic:
Few things to note:
1) Make sure you know how to refil the coolant in this car, its different from normal and takes awhile. Use this thread for reference: http://www.ft86club.com/forums/showthread.php?t=9883
2) The fitting I used for plug on the block was difficult to install. Better off going with a single piece like CARNZ did or doing this job when the header is removed. The 45 degree angle worked great though.
3) I'm actually not a fan of the Forester heater hose now... It has too many differences from the BRZ. The end under the motor is angled oddly, and the end up above almost hits the firewall. Its also a pain to install the bolt on the rear and too expensive and also backordered until febuary! Just go with a T-fitting like I said before and save yourself some money and trouble...
4) The pipe along side the block that CARNZ didn't use, I understand why he didn't use it, there isn't much space in there. You also need small hands to get between the block and the head to install the top bolt for the pipe. HOWEVER once it is installed, it is easy to bend into a different position for the best clearance possible. I just used a phillips screwdriver to do so and it fits perfectly now. I do recommend unplugging the wiring harness for more room at first.
5) Its not really mentioned, but you need to tweak the exit line on the Oil Cooler a little, bend it towards the front of the car a little for better clearance, otherwise the ignition cover is in the way on the BRZ/FRS.
I will get some numbers on it soon enough. But it looks nice and factory in the engine bay with my install so I'm happy
The Following 7 Users Say Thank You to Kostamojen For This Useful Post:
CARNZ (11-14-2013), CxG (04-25-2016), DM7 (02-17-2014), fstlane (05-24-2014), jcw99 (04-21-2016), normancw (11-14-2013), supramkivtt2jz (02-06-2014)
Old 11-14-2013, 04:17 AM   #134
PantsDants
Drives: Scion FR-S A/T, Whiteout
So I've come up with a few modifications that I plan to do when I get around to installing this on my AT car. Let me know if this sounds reasonable or if I'm way off-base here.
- Presumably, MT cars have a block-off plug whereas AT cars have a hose fitted already for the AT cooler. We can T off that hose (1/2" on all three fittings) for the oil cooler feed line.
- Rather than replacing the FR-S water pipe with the FXT one, we can T off the bigger hose on the end of the pipe that has one connection (aka the hose that gets pulled off in step 8 of @CARNZ's how-to). I don't know how big of a T we would need here, other than the middle connection would be 3/8". It looks like that hose is 1/2" or 3/4".
So my theoretical parts list looks like CARNZ's, minus the FXT water pipe, plus two T connectors and a bunch more hose clamps. Does this sound right? What's the diameter of that bigger hose I mentioned? What material should the T fittings be made out of? Should I be looking at plastic ones or something more substantial?
PantsDants is offline   Reply With Quote
Old 11-14-2013, 08:00 AM   #135
CARNZ
CHECK ENGINE
Drives: 2004 STi
That's weird that you had an issue installing the water pipe bolt for the FXT pipe, mine lined up perfectly and was very simple to install. Strange
As for #5 I didn't have to tweak my oil cooler at all either. When it sits in the cup on the chain cover you can turn it to the left or right a mm or two and that was enough to allow me to mount it and install the hoses without obstruction.
Either way, good work on getting it installed!
i don't cry about crickets
CARNZ is offline   Reply With Quote
Old 11-14-2013, 12:10 PM   #136
Kostamojen
That sounds about right.
Plastic should be fine but metal would be safer of course. The bleeder fitting on the heater hose is plastic.
Old 11-14-2013, 12:47 PM   #137
s2d4
s2d4's Avatar
Part numbers for hoses, pipes, clamps and bolts that CARNZ didn't use?
Old 11-14-2013, 01:09 PM   #138
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
very cool.. thanks for being the guinea pig.. .. Me and some friends looked at it when the new forester came out and thought it would work. GOOD JOB..
Bill
Scooby South is offline   Reply With Quote
Old 11-17-2013, 12:19 AM   #139
xxscaxx
Drives: 2013 SWP BRZ
So I installed my cooler today. If you want to tee into the hose instead of buying the heater pipe, you need a 3/4"x3/4"x3/8" tee. I actually ended up using 3/4"x3/4"x1/2" tee and was able to slip the 3/8 hose onto the 1/2 line. The 3/8" line runs to the exit of the cooler. I bought the hard line for the exit side that runs next to the injector cover and didn't end up using it because after teeing that line, the bottom of the hard line runs too close to that line and it would make for an awkward fit for hose, so I don't recommend it.
Ps I hate coolant lol.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
PantsDants (11-17-2013)
Old 11-17-2013, 01:21 AM   #140
PantsDants
Thanks for that. Where did you get your tee connector? Also did you go with plastic or metal?
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 12:29 PM
