Old 11-11-2013, 08:42 PM   #1
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
9 inch club, come on in...
Minds out of the gutter ladies and gents.
So I just pulled the trigger on some dirt cheap 17x9"s from Discount Tire Direct, Drag DR-38 in 17x9 et.38, for $358 shipped including Discount Tire's $50 off instant savings they're running now on some wheels. It was too cheap for me to not give them a try.
Initial review of the wheel, from what I can find online, puts the weight at around 22.3lbs, according to the manufacturer and online retailers, so a little heavier than the OEM wheels. A lot of the WRX/STI guys on NASIOC are running them, and so far the reviews are good.
Anyways, I'm looking to hear how guys with 9" wheels are handling track conditions. Under extreme compression, are there any issues with tires rubbing the fender anywhere?
I'd just like to hear back from anyone running a 9" on track, along with the offset, suspension mods, and any issues you encountered. Also looking to see what kind of camber you all are able to get safely, without touching the spring perches on the strut.
I am torn between running a 235/40 or a 245/40 Pilot Super Sport (currently running 215 PSS on OEM wheels). Considering the RS3's as well, which are a little cheaper, but I'm hoping to get a year out of a set of tires, and not sure I will with the RS3's (10-15 track events per year, with about 5-8k street miles in between).
Suspension wise, right now I am on OEM suspension, looking into RCE Yellows shortly, and running Whiteline camber bolts up front with about -1.6 camber.
smbstyle is offline   Reply With Quote
Old 11-11-2013, 08:50 PM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
May want to slightly change how you word thread title ^_^
Do I count if I average 9? 8.5 / 9.5 stagger
The Following User Says Thank You to ZionsWrath For This Useful Post:
Anthony (11-14-2013)
Old 11-11-2013, 09:43 PM   #3
CSG David
CSG David's Avatar
225 RS3 is the fastest in that setup since you're stock power and stock suspension.
Old 11-11-2013, 09:50 PM   #4
smbstyle
smbstyle's Avatar
Sure, I'd like to hear your input as well.
Old 11-11-2013, 09:52 PM   #5
smbstyle
smbstyle's Avatar
Will the 225 even fit on the 9" rim properly? I'm afraid that setup would be too much stretch. Or is the RS3 a "wide" 225?
I also know the tires themselves vary, and find the PSS tires to be a bit wider than others in the same size. The PSS in 215 was a bit wider than the OEM Primacy HP 215 tires.
Old 11-11-2013, 09:55 PM   #6
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'm selling one of my 17x8 setups soon. Probably the Kosei's since I want to keep the RPF1s. And some other BRZ stuff maybe too. Kraut shitbox is going to take all my money
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-11-2013, 09:58 PM   #7
smbstyle
smbstyle's Avatar
Pics and price of said Kosei's? Also, shoot me a PM on what you are thinking about getting rid of.
lol, kraut shitbox. I had a 95 M3 that I picked up for $1g and flipped it before I was into the "track scene".... shoulda kept it.
Consumables/maintenance should be fun on that thing compared to the Integras and BRZ!
Old 11-11-2013, 10:01 PM   #8
CSG David
CSG David's Avatar
It has been done on multiple occasions so don't worry about it. It works perfectly fine for EHP tires. Anything else will require a slightly larger tire. If you don't care much about utilizing the grip properly, go with 245/40/17 on any tire.
Old 11-11-2013, 10:03 PM   #9
smbstyle
smbstyle's Avatar
Im all about experimenting; buddy of mine is running a 245 PSS on a 17x8 and says its too much tire, especially in the rear, and cant get the car to rotate properly, which is leaning me towards a smaller size.
Old 11-11-2013, 10:04 PM   #10
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Luckily it's maintenance in the past year is a list longer than the 13 years with my Integra so it should be good for at least 6 months, maybe a year if I'm really lucky. Minus a little rust to fix. It does have all new bushings, top end rebuilt, VANOS rebuilt, bunch of other stuff, etc.
And it's alpine white over black Next to Avus over black that's my favorite
They are K4Rs.. they look like K4Rs I need to clean them and take pics. Not sure what else will go. Suspension for sure. Maybe intake. Oil cooler adapter also. Gauge holder as well. Dunno what else. Probably not brakes but maybe some brake pads (none of which would be of value to you except maybe BNIB AP C300 rear pads, the rest would be used AP C300 front pads for the essex kit, maybe some CL RC6Es used as well, etc.. not sure what else I have laying around).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-11-2013, 10:13 PM   #11
Byebye
Byebye's Avatar
I ran 17x9 +45 RPF1' s with245/40 BFG Rivals. I'm also on Megan racing easy street coil overs. No rubbing on anything. I don't know my camber. I just pushed it to camber as much is it could go then tightened the bolts.
Your offset is more aggressive so you are more likely than I to rub.
Byebye is offline   Reply With Quote
The Following User Says Thank You to Byebye For This Useful Post:
smbstyle (11-11-2013)
Old 11-11-2013, 10:41 PM   #12
smbstyle
smbstyle's Avatar
You have the Eibach R2, right?
Old 11-11-2013, 10:42 PM   #13
smbstyle
smbstyle's Avatar
Thanks, yeah I'm hoping the et38 offset will clear OK, I'm more worried about the outer fender lip than the inside spring perch, as I can control that with some camber.
Old 11-11-2013, 10:45 PM   #14
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yeah, the car is going on jack stands soon so I can send them off to Eibach to get rebuilt. They will also be getting OTS rate springs put on. I'll use them on the street for a bit afterwards (you can drive the car with them once they are back) and then I'll probably sell them. Between the M3 as a DD and the GS-R as a track car.. there's not much need for the BRZ to have 2 way adjustable coilovers.. hell there's not much need for it to have anything beyond stock, which is what it's going back to.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
8 inch Subwoofer paaji Electronics | Audio | NAV | Infotainment 34 03-13-2020 12:19 AM
15 or 16 inch rims EZWood Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-30-2014 01:58 PM
3 Inch Exhausts? kmbkk Engine, Exhaust, Transmission 9 10-23-2012 02:18 PM
Help! Two 10 inch vs One 10 (or 12) inch cyntage Electronics | Audio | NAV | Infotainment 7 09-27-2012 11:20 PM
19 inch rims too big? Liquidcell Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 09-03-2012 01:07 PM
