Old 10-29-2013, 02:36 PM   #15
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
Originally Posted by Mikepage View Post
Do you have a link for this?
http://www.stranoparts.com/partdetails.php?PartID=928
Books is offline   Reply With Quote
Old 10-29-2013, 03:05 PM   #16
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
First post updated!
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 11-01-2013, 12:58 AM   #17
mr. slim
SoCal86
mr. slim's Avatar
Drives: '13 Whiteout FR-S
Don't forget you can use
2008+ STI rear sways which are 19mm
Or 2010+ WRX which is 16mm
.: SUPER KAWAII :.
.: BUBSQUAD :.
.: LivinLow :.
.: FRS86 :.
mr. slim is offline   Reply With Quote
Old 11-01-2013, 01:47 AM   #18
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
The stock sway bars are one of the best suspension parts on this car and I will not be touching it at all. I don't see many aftermarket ones that will beat it.
husker741 is offline   Reply With Quote
The Following 3 Users Say Thank You to husker741 For This Useful Post:
2013GTRNate (02-21-2016), RehabJeff86 (01-12-2014), SilverSkyline210 (10-31-2014)
Old 11-01-2013, 02:21 AM   #19
Kostamojen
Old 11-01-2013, 02:53 AM   #20
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Originally Posted by Kostamojen View Post
G_Ride is offline   Reply With Quote
Old 11-01-2013, 07:41 AM   #21
Mikepage
Mikepage's Avatar
Can you explain your point?
o= FR-S =o
Old 11-01-2013, 08:01 PM   #22
mike the snake
Just scored a 19mm Perrin rear STI swaybar with end links for $150!
Old 11-01-2013, 08:29 PM   #23
simpleisbest
Senior Citizen
Drives: Scion FR-S
I think it's a good idea to start a list like this to help users to make their choices easily.
Stock
Front : 18mm
Rear : 14mm
ST suspensions
Front : 19mm,
2 way adjustable. 41% & 76% stifness increase
Rear : 17.5mm
3 way adjustable. 20%, 58% and 133% increase in stiffness
Witheline
Front : 20mm, 22mm
20mm Fixed or 2 position in option, 22mm
2 position
Rear : 16mm, 18mm
3 position
http://www.whiteline.com.au/do_segue...ehicle=2012-ON
Cusco
Front : 16mm, 20mm
1 position
Rear : 14mm, 16mm
1 position
TRD Stabilizer Set
TRD Site
Jparts Site
Eibach
Front : 25mm
2 position
P1 = 88 N/mm (500 lbs/in) +255%
P2 = 103 N/mm (585 lbs/in) +314%
Rear : 19mm
2 position
P1 = 45 N/mm (255 lbs/in) +126%
P2 = 60 N/mm (338 lbs/in) +200%
http://performance-suspension.eibach...-roll-kit_2013
Hotchkis
Front : 25.4mm
2 position
500 lbs/in (170 % Stiffer than Stock)
630 lbs/in (245 % Stiffer than Stock)
Rear : 19mm
4 position
320 lbs/in (200 % Stiffer than Stock)
405 lbs/in (275 % Stiffer than Stock)
520 lbs/in (385 % Stiffer than Stock)
700 lbs/in (550 % Stiffer than Stock)
http://www.hotchkis.net/scion-frs-sp...sway-bars.html
Perrin
Front : 19mm, 22mm
2 position
19mm Hole #125% Stiffer than 18mm OEM Bar
19mm Hole #272% Stiffer than 18mm OEM Bar
22mm Hole #1130% Stiffer than 18mm OEM Bar
22mm Hole #2218% Stiffer than 18mm OEM Bar
http://perrinperformance.com/i-13324...-fr-s-brz.html
Rear : 16mm, 19mm, 22mm, 25mm
3 position
16mm Hole #130% Stiffer than 14mm OEM bar
16mm Hole #265% Stiffer than 14mm OEM bar
16mm Hole #3116% Stiffer than 14mm OEM bar
19mm Hole #1150% Stiffer than 14mm OEM bar
19mm Hole #2243% Stiffer than 14mm OEM bar
19mm Hole #3347% Stiffer than 14mm OEM bar
22mm Hole #1400% Stiffer than 14mm OEM bar
22mm Hole #2535% Stiffer than 14mm OEM bar
22mm Hole #3729% Stiffer than 14mm OEM bar
Tanabe
Front : 22mm
1 position
http://www.tanabe-usa.com/rnd/?tag=/fr-s
Strano FSB
Front : 22mm
1 position
85% Stiffer than 18mm OEM bar
SuperPro
Front : 20mm, 22mm
Rear : 18mm, 20mm
http://www.fastwrx.com/suswbafbr.html
Great list!!
Just a suggestion:
You might want to list either HOLLOW or SOLID.
The stiffness of the bar will vary greatly depending whether hollow or solid.
Without knowing that, it'll be tough to gauge stiffness with diameter alone.
simpleisbest is offline   Reply With Quote
Old 11-09-2013, 07:32 PM   #24
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
is the oem hollow or solid?
garfull is offline   Reply With Quote
Old 11-09-2013, 11:16 PM   #25
simpleisbest
Senior Citizen
Drives: Scion FR-S
OEM is solid
Old 11-10-2013, 10:31 AM   #26
Mikepage
Mikepage's Avatar
Sway bar option list
I will try to update the list soon concerning hollow and solid informations.
o= FR-S =o
The Following 2 Users Say Thank You to Mikepage For This Useful Post:
chanomatik (01-16-2014), nemes (11-11-2013)
Old 11-11-2013, 02:11 PM   #27
simpleisbest
Senior Citizen
Drives: Scion FR-S
Probably all after market bar are hollow.
Anyway no difference between solid and hollow on the stiffness, I agave talked with my friend engineer.
Typically most aftermarket bars are solid, as solid is bit cheaper to make.
No difference? Please do enlighten us.
Hollow is softer per OD mm vs solid.
You can have a hollow and a solid of equal stiffness, but in such cases the hollow will typically have a larger OD and weigh a couple of pounds less.
Hollow bars are typically designed to provide a certain level of stiffness while trying to save some weight vs solid.
Calculations exists on the differences all over the internet.
If you are comparing bars based on diameter, the detail of it being solid or hollow DOES MATTER.
Old 11-11-2013, 02:46 PM   #28
Mikepage
Mikepage's Avatar
Don't be mad bro we are here to learn, I don't have any problems to say when am wrong.
Could you show to us? Then you will probably inform users correctly.
I want to understand what is the difference between an solid and an hollow bar.
I don't think it's enough big to really see the difference on the street and also maybe on a race track. I mean the difference between the 2 bar types.
I am pretty sure if you try both, hollow and rigid, you will probably not see any differences. It's only about how much the bar are more stiffness then the oem. Example, if you have the same % of stiffness between an hollow and an rigid bar then this is the same thing.
We say the same thing
I just want to say, look at the % of stiffness you want to add on your car and make your choice from this.
o= FR-S =o
New F/I option SnapOv3st3r Forced Induction 41 03-24-2013 09:44 PM
Leather Option. l0aded Scion FR-S / Toyota 86 GT86 General Forum 20 03-02-2013 08:59 PM
Diffuser Option on the BRZ Markone AUSTRALIA 25 01-14-2013 03:21 AM
Scion FR-S Option list Crashoverride Scion FR-S / Toyota 86 GT86 General Forum 38 04-18-2012 03:37 PM
Considering this as another option 2011 WRX Draco233 Other Vehicles & General Automotive Discussions 5 04-01-2012 10:01 PM
