Old 11-08-2013, 11:26 AM   #1
autobrz
Drives: Mazda 3
street + track oil question
usage:
1k street miles per month
40 track miles per month
requirements:
must be 0w20
must meet oem specification to not void warranty
must be less than $10/qt
any suggestions?
please reply in the following manner if possible:
brand
reason
estimated oil change interval for my usage
Thanks
autobrz is offline   Reply With Quote
Old 11-08-2013, 11:28 AM   #2
autobrz
Drives: Mazda 3
p.s. I wanted to try to mazda with moly but the local dealer wanted $9.70/qt so I'm back to the drawing board.
Old 11-08-2013, 11:29 AM   #3
MightyMeeple
Slower than Fast
MightyMeeple's Avatar
Drives: BRZ Limited 6MT
Interested in responses to this as well
. Sub'd.
MightyMeeple is offline   Reply With Quote
Old 11-08-2013, 11:29 AM   #4
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
Have you tried Motul 300V?
Anthonytpt is offline   Reply With Quote
Old 11-08-2013, 11:31 AM   #5
CSG Mike
CSG Mike's Avatar
300V is a little bit out of his specified price range... unfortunately. $10/qt prices him out of all the top tier stuff.
@autobrz: What is your planned OCI?
Old 11-08-2013, 11:35 AM   #6
Anthonytpt
Anthonytpt's Avatar
It's ~$6 over the specified range, but seeing as there will be track usage in Texas, I figured it was worth asking.
Old 11-08-2013, 11:37 AM   #7
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
Eneos 0w-20 At Oakos Automotive is $54 for a 6 quart case.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 11-08-2013, 11:47 AM   #8
autobrz
Drives: Mazda 3
I don't like changing oil so the closer to 7.5k the better.
Also, if a more expensive oil can last longer for me, then it is still a good deal if all the less expensive oils need to be changed more often. $10/qt is a requirement I came up with without thinking about the effect of OCI on expenses. So what are my options if considering any price?
Old 11-08-2013, 11:48 AM   #9
autobrz
Drives: Mazda 3
why and how often would you change it?
Old 11-08-2013, 11:54 AM   #10
CSG Mike
CSG Mike's Avatar
300V is going to be around 15-17/qt shipped, but it is a top shelf oil.
I run a UOA on every oil change on my own car (s2000), and I run it for 10k miles between changes, although the UOA says I can run it for longer. The 10k includes plenty of redlining, canyoning, and tracking, and the car sees desert heat during track days in the summer (as high as 120F ambient).
I recommend you determine your OCI via UOA, as everyone's experience is a bit different. If you buy them bulk, theyre $18 each, +10 for TBN tests.
Here are some 300V UOA on the FA20.
Ranatsu - BRZ Motul 300V HR - 4,801 miles (half life check)
lordtakuban - FRS Motul 300v 2nd oil change - 6k miles
Old 11-08-2013, 11:57 AM   #11
CSG Mike
CSG Mike's Avatar
An older post I made about 300V
http://www.ft86club.com/forums/showthread.php?t=30803
Old 11-08-2013, 12:00 PM   #12
brn12345
brn12345's Avatar
I use eneos 0w20 sustina. Very happy with it and very affordable.
brn12345 is offline   Reply With Quote
The Following User Says Thank You to brn12345 For This Useful Post:
ZionsWrath (11-14-2013)
Old 11-08-2013, 12:14 PM   #13
SubiePig
I put it in at my 7500 mile oil change and have not changed it yet. I am going to change it at 15k and get it analyzed. My car is mainly highway, driving 8 miles to work in the morning, and 1-2 autocrosses a month. If they say I can go longer ,which I am sure they will, I will probably bump it up to 10k between changes.
Old 11-08-2013, 12:26 PM   #14
autobrz
Drives: Mazda 3
ah. autocross not the same as 20 min sessions...
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
T1R B52 Street and Track Coilover Review jau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 09-08-2013 01:33 PM
Street to track giraffee Australia Classifieds 1 10-31-2012 02:03 AM
Different pads for street and track Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 08-01-2012 02:55 PM
BRZ and FR-S Street and Track Brake Products available now JRitt Brakes, Suspension, Chassis 3 07-31-2012 09:37 AM
