go_a_way1
Old 11-07-2013, 10:44 AM   #2521
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
While I'm thinking about the above bass drop. Gary did you ever setup that windows tablet? I'm going to be doing a nexus 7 install as my head unit today. And I think I worked out a very clean install. Let me know if you are interested.
Installed Mods:
Old 11-07-2013, 12:16 PM   #2522
bfrank1972
Drives: 2013 FR-S Argento
Originally Posted by rusty959 View Post
Ever had a stereo that when the bass hit in neutral your rpm drops due to the extra load on the alt? Mine drops a few hundred rpm.
If you haven't experienced that, you haven't experienced my fabled mpg drop.
[ame="http://www.youtube.com/watch?v=QCd0oqn6mVc"]In Russia the beat drops you - YouTube[/ame]
The Following 2 Users Say Thank You to bfrank1972 For This Useful Post:
SirBrass (11-18-2013), TM (11-07-2013)
Old 11-07-2013, 03:21 PM   #2523
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
I haven't but only because I can't find software that works well on a windows environment. Right now I'm doing basic data logging on my iPhone using ODB Fusion.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 11-07-2013, 09:46 PM   #2524
Sojhinn
Sojhinn's Avatar
Finished my install. I have torque running on the tablet and various other goodies.
Installed Mods:
Old 11-07-2013, 09:50 PM   #2525
silent runner
Drives: 93'Camry, 82'Corolla, 76' Celica
Its a 130 amp alt. And if you are really drawing from it the most you will notice is decreased gas mileage. I notice a couple mpg drop when I'm running my stereo hard on the highway.
So what you said is reasonably correct, but the alt also puts out about 13.8v not 12v.
I thought right away, (after I posted this) that I should have done the math on the (V) the car actually charges at, and guessed at at least 120 amp alternator. I can tell from all the reading that this is a tough crowd.
So it's more like 2.4hp, that the alternator could possibly claw back, if it was not shielded by the esc battery packs, and had to re-supply all the energy back, at 100% of the alternators capacity, until the system was fully recharged. However, some or alot of the time after you have "hit the switch", so to speak, you are going to have to slow down! That is when you get "free" energy recovery, and that alternater can suck the power back in, just at the time when it will be asking for peak current demand. Just thinking, there are a lot of times when I'm driving, that I have'nt just gone all out, and I still have to slow down.
I don't recall any such energy recovery feature on my Mazda 626 Turbo (ancient footnote to history) car, and while conventional superchargers certainly increase power output... They never give anything back, they are
always a drag.
I haven't seen the math, but I'll bet this is a significant part of the calculations of the relative efficiencies of this and other boost systems.
silent runner is offline   Reply With Quote
Old 11-07-2013, 10:14 PM   #2526
fenton
Attachment 56640
Looks really clean. You have a parts list you used?
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
Old 11-07-2013, 10:16 PM   #2527
Sojhinn
Sojhinn's Avatar
I'm going to create a post. With links to amazon etc. I made it as simple as possible and cheap as possible. I'll tag it here when I'm done. But out of pocket cost is about $300
Installed Mods:
The Following 3 Users Say Thank You to Sojhinn For This Useful Post:
asher187 (11-07-2013), CajunFRS (11-07-2013), SpyderMS (11-17-2013)
Old 11-07-2013, 10:40 PM   #2528
asher187
Drives: 2013 FR-S, 1995 Civic Coupe
Very interested in this thanks for sharing.
asher187 is offline   Reply With Quote
Old 11-07-2013, 10:42 PM   #2529
CajunFRS
Drives: Challenger R/T, CRX SI,
I will look forward to that and your tuning results with Shiv!
CajunFRS is offline   Reply With Quote
Old 11-07-2013, 11:18 PM   #2530
Sojhinn
Sojhinn's Avatar
Link to the post. Not very many pictures yet sorry.
http://www.ft86club.com/forums/showt...73#post1319373
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
DAEMANO (11-08-2013)
Old 11-08-2013, 11:09 AM   #2531
Robftss
Drives: VW
always a drag.
Peak power consumed by the recharge is ~ 330 watts, regulated.
So 0.44 HP ideal.... ~ 0.75 HP with alternator efficiency losses.
Robftss is offline   Reply With Quote
The Following 2 Users Say Thank You to Robftss For This Useful Post:
DAEMANO (11-08-2013), rusty959 (11-08-2013)
Old 11-08-2013, 07:27 PM   #2532
silent runner
Thank You! This is good to know! Less than 1hp of claw back, ever! Maybe a tiny bit more than turning on the rear window defroster...
Old 11-11-2013, 07:13 PM   #2533
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Edit: wrong thread
Old 11-11-2013, 07:21 PM   #2534
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
A quick update.
Thanks to having veteran's day off I was able to get some shop time in and completed the mounting plate for my compressor.
I did some bench testing and mechanically it's working great. The brushless controller I'm currently using is giving me a little trouble. Stalling on startup and cutting out at higher RPM. I suspect it just isn't up to the task. I knew that I would be pushing its limits though so no surprise there. It does move a lot of air and seems to create some decent pressure when the outlet is restricted.
I've ordered a 200 amp ESC hopefully it will be what's needed so I can continue testing. The next step for me will be finding all the right connectors to fit it to the intake.
Wrong thread?
Sent from my SGH-I337M using Tapatalk
Bu-Tang is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
