Old 11-03-2013, 06:50 PM   #1
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Greddy SP Elite cold start rattles
Anyone else with this system experience this? Is there a way to make it stop??
Old 11-03-2013, 06:56 PM   #2
SliverBrz
Drives: Silver 2013 BRZ limited
resonated front pipe, i had the same problem
I had a sp elite, paired up with headers + non resonated front pipe and it sounded bad
i bought a resonated front pipe and it helped big time.
SliverBrz is offline   Reply With Quote
Old 11-03-2013, 08:59 PM   #3
BlueDubbinTDI
I still have the stock catted 1 in, you really think a resonated 1 would make a big difference?
Old 11-03-2013, 09:03 PM   #4
SliverBrz
oh what.... lol nvm then
You may have some other problem going on.
the stock one is catted and resonated.
mine only rasped becaseu of the headers. if you have none of thta then your greddy could have a problem
Old 11-03-2013, 09:43 PM   #5
BlueDubbinTDI
It's fuckin used...is Greddy quality something I need to worry about falling apart? Or am I just over thinking this and there is just rubbing I haven't seen yet? It looks like its in perfect shape
Old 11-03-2013, 10:45 PM   #6
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
im also running mine with stock everything else. no problems here after around 5000 miles. i'd say make sure its still tight and sitting straight
abutterman is offline   Reply With Quote
Old 11-04-2013, 09:07 AM   #7
BlueDubbinTDI
Damn. I'll have to have my local shop check it out. It's pretty bad when cold and takes about 5 mins to go away 90%. Only barely rattles when under light load after warm-up.
Old 11-04-2013, 10:37 AM   #8
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Are you sure it's not an exhaust leak?
Mine leaked with the included gasket, when cold, not matter how tight the bolts were.
I ended up using two stock gaskets, with the metal lips facing outward on each.. sealed up perfectly.
uspspro is offline   Reply With Quote
Old 11-04-2013, 11:43 AM   #9
BlueDubbinTDI
I'm assuming its something along those lines. I'm leaving work 30 mins early today to catch my local exhaust shop (awesome service) and see what they can't uncover. I don't make boatloads of money so a purchase like this that has problems really stresses me out
Also how did you discover that was the problem?
Old 11-04-2013, 12:29 PM   #10
frslee
Just drive it
Drives: 13' FR-S
isn't SP Elite just an axle back? If so, check if the exhaust is touching any other metals.
frslee is offline   Reply With Quote
Old 11-04-2013, 01:17 PM   #11
DarkCard
Drives: Asphalt Scion Frs 6MT
Never had a issue with mine.
DarkCard is offline   Reply With Quote
Old 11-04-2013, 01:38 PM   #12
SliverBrz
If its an exhaust leak, you only have one joint to check since its an axle back.
Put copper silicone gasket maker in there and you are good.
autozone its liek 5$
Old 11-04-2013, 01:53 PM   #13
BlueDubbinTDI
How do I check if this is the cause?
Old 11-04-2013, 02:15 PM   #14
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
an exhaust leak is pretty easy to diagnose since you can hear it. Now the rattle, does it sound like it's metal on metal, or squeaking, etc?
bkblitzed is offline   Reply With Quote
Cold start question retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 106 11-15-2016 02:14 PM
Cold start up popping noise Weeber Issues | Warranty | Recalls / TSB 51 09-23-2016 12:54 PM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-12-2015 11:53 PM
backfire at cold start FreaQshoQ Scion FR-S / Toyota 86 GT86 General Forum 15 10-16-2013 06:21 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
