Old 11-03-2013, 09:04 PM   #1
jflogerzi
jflogerzi's Avatar
Borla UEL Header Installed, exhaust leak now?
So with a couple of local guys, we installed the Borla UEL header. Now while sitting idle in my garage, after revs I can smell fumes from the front driver side of the car. There is no issues or problems when driving the car. Whats the best way to test for leaks from the header and overripe? I used the grimspeed gaskets for the header flanges.
Old 11-03-2013, 09:14 PM   #2
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
remove aluminum panel, let car completely cool down. Start the car then book ass back under the car and stick your hand around the 3 possible leak areas to see if you can feel anything leaking. Stock up on aloe.
Old 11-03-2013, 09:29 PM   #3
Tiremonkey0824
Drives: 2013 Argento 6mt
Get the car in the air and crank it up. Then get under it with a piece of paper or preferably cellophane and hold it up to each flange where you think it is leaking. If there's a leak the paper will flutter.
Tiremonkey0824 is offline   Reply With Quote
Old 11-03-2013, 09:51 PM   #4
Hardrock4445
Hardrock4445's Avatar
If you have access, smoke machine on the tailpipe.
Also, it's a borla header, look for cracks...
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
Old 11-03-2013, 10:04 PM   #5
DJCarbine
Thupercharged
DJCarbine's Avatar
Are you sure its not just normal exhaust fumes? The whole car will stick up depending on the wind/enclosed area you are in
An exhaust leak big enough to give you fumes should sound very apparent, if there is no ticking/knocking at WOT you should be fine. How many miles are on the header? The first few drives smelled strong of fumes underhood due to the burning off of oil on the header
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
jflogerzi (11-03-2013)
Old 11-03-2013, 11:13 PM   #6
fstlane
fstlane's Avatar
Drives: BRZ Limited
Spot on post. In addition to the manufacturing oils burning off you are likely just experiencing the increased exhaust fumes and noise from the elimination of your primary cat. An exhaust leak generally makes a distinct sound as mentioned above.
fstlane is offline   Reply With Quote
Old 11-03-2013, 11:21 PM   #7
jflogerzi
jflogerzi's Avatar
Its been less than 500 miles. I will be doing some logging. I dont think there is any knock. I have never experienced knock. There were no cracks and the header looked decent for borla quality.
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
Old 11-04-2013, 07:58 PM   #8
kuhlka
Drives: 2013 BRZ Limited AT
I think I might have the same leak on my Rev Works UEL. I think the fit of the header to overpipe is a bit picky. Might need to use a tiny dab of putty to hold the gasket in place before fitting up the exhaust and tightening down. Leaks can also happen if you don't evenly torque down the bolts.
kuhlka is offline   Reply With Quote
Borla Exhaust Installed!!! microcarmag Engine, Exhaust, Transmission 54 08-20-2016 06:15 AM
Borla UEL Header installed = CEL! jordanrw260 Engine, Exhaust, Transmission 83 06-12-2016 01:53 PM
Anyone else get the dealer installed Borla exhaust? teamturbo Engine, Exhaust, Transmission 5 07-14-2013 07:49 AM
Borla UEL Header and Stock Exhaust CEL 01s0uljah Engine, Exhaust, Transmission 23 05-30-2013 05:45 PM
Dealer Installed Borla Exhaust TaddyDobbins Engine, Exhaust, Transmission 7 02-18-2013 01:26 AM
