Old 11-01-2013, 09:30 PM   #1
jordanrw260
Drives: Dark Grey Metallic 2013 BRZ
Borla UEL Header installed = CEL!
I just had my Borla UEL Header installed today. I reset the ECU and drove about 17 miles I got the CEL. I had a bung welded after my HFC on my Berk Front Pipe for the o2 sensor to go after the cat. The shop also used the o2 spacer I provided to them (Vibrant Performance o2 spacer). The option with the smallest hole was used. I bought it from FT86SpeedFactory here http://ft86speedfactory.com/o2-spacer-for-cel-1090.html
My other mods are a drop in filter, kartboy pulley, and a UniChip with the All Drop in + All Cat back + All Headers +Standard Fuel and Timing map.
I thought the route I took would be a pretty sure bet on me not getting a CEL. Should I not use the o2 spacer since it is already behind the cat?
Thanks for any input
And right now I'm happy with the unichip and will not be getting any other tune.
jordanrw260 is offline   Reply With Quote
Old 11-01-2013, 09:33 PM   #2
CodyFRS
CodyFRS's Avatar
Drives: Asphalt FRS
This makes me nervous about installing my Borla UEL. I have no tube and vibrant o2 spacer as well.
CodyFRS is offline   Reply With Quote
Old 11-01-2013, 09:40 PM   #3
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Its totaled
Old 11-01-2013, 11:08 PM   #4
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
why weld something into your HFC when you already got a spacer ?
I have the borla UEL with the vibrant spacer and i get a cell rarely every now, and then it goes away
Old 11-02-2013, 01:03 AM   #5
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
Is it necessary to get a sensor with the headers?
And you have borla headers with berks pipe right? If so, how loud is it because i am planning to go with the same set up.
Kelbyat07 is offline   Reply With Quote
Old 11-02-2013, 02:03 AM   #6
lgunnz
Drives: 2013 Toyota GT86
I installed mine a month ago with no spacer and still no CEL. Can't you get rid of the CEL with the Unichip
lgunnz is offline   Reply With Quote
Old 11-02-2013, 02:06 AM   #7
FR-S Matt
Get it tuned properly and all this goes away. Spacers are hit or miss, and O2 extensions might be the same as well. Haven't seen many try that. You don't need a spacer if you have a bung welded in your front pipe.
Old 11-02-2013, 12:36 PM   #8
jordanrw260
The sound is barely louder than stock with the HFC on the front pipe and a catless header. It sounds meaner when you rev it out but standard driving is barely impacted. Cold start is louder but I was kind of shocked at how quiet it still was.
Old 11-02-2013, 12:37 PM   #9
jordanrw260
Originally Posted by Fast_Freddy View Post
Which CEL did you get? lean or rich? It makes a big difference!
Can you point me to another thread that would possibly tell me how to check the code? I'm not even aware on how to do that.
Old 11-02-2013, 12:40 PM   #10
jordanrw260
I wonder if I remove the spacer everything would be fine then?
Old 11-02-2013, 01:41 PM   #11
TopGearSolutions
TopGearSolutions's Avatar
Drives: C6 Corvette Z06
You could go to something like an autozone to get the code pulled for free.
You may want to try running without the o2 spacer and see if it goes away.
Otherwise tuning will get rid of the CEL for sure assuming it's from being catless.
You still have the primary o2 sensor before the cat and the secondary o2 sensor after the high flow cat, right?
TopGearSolutions is offline   Reply With Quote
Old 11-02-2013, 03:01 PM   #12
jordanrw260
That is correct, the only thing I noticed that the shop did was put the primary o2 in the secondary o2 spot on the borla and then plugged the original primary o2 spot. Now the secondary is behind the cat on the front pipe.
Old 11-02-2013, 04:51 PM   #13
TopGearSolutions
I would personally put the primary back in it's intended spot. Definitely pull the CEL code now as it might not be a cat efficiency code but a lean code or something from the primary o2 sensor being in the wrong spot.
If you dont have the tool you can also get a o2 sensor removal tool at a local auto parts store. It will make it easier.
Old 11-02-2013, 06:54 PM   #14
jordanrw260
Thanks, I'll talk with the Shop on Monday to see if they can relocate the primary sensor back to its intended spot. Also do you agree with FR-S Matt above saying I do not need the spacer in the 2nd o2 sensor behind the HFC?
2013 Subaru BRZ Metallic Grey 6-Speed - Mods: HKS Drop in, Perrin Inlet Tube, Kartboy Crank Pulley, Berk HFC Front Pipe, Borla UEL Header, PLM Overpipe, Open Flash Tablet Stg 2 tune
borla, header, spacer
Borla UEL header BeltedBiscuit Engine, Exhaust, Bolt-Ons 11 03-05-2014 05:35 PM
SOLD sw20kosh Engine, Exhaust, Bolt-Ons 5 12-16-2013 11:46 PM
FS: NEW Borla UEL Header Cjymiller Engine, Exhaust, Bolt-Ons 10 10-13-2013 10:04 AM
FS: Used Borla EL header FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 3 10-07-2013 02:11 PM
Ny Fs: Borla header DarkCard Engine, Exhaust, Bolt-Ons 12 07-31-2013 09:44 PM
