Old 11-03-2013, 11:36 AM   #1905
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by Khánh View Post
if anyone could help, would greatly appreciate it cuz i'm losing sleep over this haha
Will I be able to fit 255/35/18 with 18x9.5 et34 for the rear without any poking? I don't have any camber kit either and am lowered on coilovers..
No issue with that tire on the rears, you could run a 265 if you wanted. The wheel determines flushness or not, but you will be pretty flush with that setup, camber dependant of course.
Slick is offline   Reply With Quote
Old 11-03-2013, 11:43 AM   #1906
Slick
Slick's Avatar
Originally Posted by Antheezy View Post
So I just picked up some Weds Sport Sa-15r 18x8.5 squared setup +48 all around. I think the fronts is pretty close to flush at 1 inch drop, but im a bit lost with everything. Mind helping me out?
Don't think you will be flush with combo. I am flush on 18x9+35 with also a 1" drop (see sig pic), and you'll be a further 19-20mm inward. Not sure what offsets are available for that wheel, but something more like +35 will be closer to flush. Camber also impacts on flushness as well, what are you at?
Old 11-03-2013, 02:59 PM   #1907
Antheezy
Well I just ordered the rims and BC coilovers, Its a daily driver. I havent even begun looking at tires... I was thinking of adding spacers. Camber probably will be 0 since its a DD and I usually wont drive it aggressively. Im very new to this.
Antheezy is offline   Reply With Quote
The Following User Says Thank You to Antheezy For This Useful Post:
FLIPs_FR-S (11-03-2013)
Old 11-03-2013, 03:55 PM   #1908
FLIPs_FR-S
KCCO
FLIPs_FR-S's Avatar
Drives: 2013 Raven Scion FR-S, AT
I too am very new to this.
Sent from SAMSUNG GALAXY NOTE. KEEP CALM AND CHIVE ON.
Alabama state head for Southeast 86
https://www.facebook.com/groups/Southeast86/
FLIPs_FR-S is offline   Reply With Quote
Old 11-04-2013, 04:13 AM   #1909
Khánh
Khánh's Avatar
Drives: sc00ter
thanks.. I'm concerned if I should run 9.5" rear would be a bit poke.. i stated I have no camber adj..I'm worried cuz you said you have 9" and you're sitting flush... 1/2" poke is alot.. with the frsproject calculator, I'm good but I dunno how accurate it is with the fender
Khánh is offline   Reply With Quote
The Following User Says Thank You to Khánh For This Useful Post:
FLIPs_FR-S (11-04-2013)
Old 11-04-2013, 06:02 AM   #1910
FLIPs_FR-S
KCCO
FLIPs_FR-S's Avatar
I was unaware of the frsproject site. Thanks for mentioning it. That, used with rims n tires dot com tire comparer and tyre stretch dot com. It should be easy to determine the proper fit.
Old 11-04-2013, 08:25 AM   #1911
Slick
Slick's Avatar
It's not really 1/2 difference in poke, only 1/4" (1/4" more inside, 1/4" more outside) which is fine for the rears.
But with 0 camber, it will poke. Most guys running a wider wheel will have some camber due to lowering which will pull the top of the tire under the wheel arch.
The Following User Says Thank You to Slick For This Useful Post:
Khánh (11-04-2013)
Old 11-04-2013, 03:36 PM   #1912
Khánh
Khánh's Avatar
Drives: sc00ter
no prob
ya you're right.. i was thinking about 9.5vcomparing to 8.5 for some reason haha I'm lowered with one finger gap in the rear with stockies right now and it looks like top of the rim is about 1" from flush. ah the dilemma maybe i should just go with 8.5" square ..
Old 11-07-2013, 02:15 AM   #1913
Raven23
So I originally wanted to get staggered 18x8.5/9.5 wheels and read it that would be pretty flush at 1.5" drop.
Now these new SSR GTV01 wheels came out but only have it in size 18x8.5. Im willing to go square set up and add spacers to make it flush. Only, I dont really know much about spacers.
Will I need spacers to make it flush? If so, what brand / size spacers do you recommend?
Raven23 is offline   Reply With Quote
Old 11-07-2013, 01:58 PM   #1914
Khánh
Khánh's Avatar
Drives: sc00ter
i'm sure someone can help you but u need to give the wheel offset
Old 11-07-2013, 06:05 PM   #1915
RavSpec
Drives: Rx7
GTV 01, BRZ / FRS fitments will be 18x8.5 +44mm offset. They are currently price around $1600.
Use a 25mm spacers in the rear to be flush. Front, use a 10mm spacers or just run wider tires, 245/40.
Should be around Jan/Feb for delivery.
RavSpec is offline   Reply With Quote
Old 11-07-2013, 07:51 PM   #1916
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
One thing I do know is you do not want zero camber all way around. As car suspension compresses and you turn etc you want some bite. Even -1 to -1.5 all way around. It's not going I have crazy wear, be less actually then zero as you have I think of positioning under pressure and turning etc. This car IMO would skate all over with zero especially in the rear. Zero toe is good however.
Old 11-07-2013, 10:21 PM   #1917
FLIPs_FR-S
KCCO
FLIPs_FR-S's Avatar
How about this. Stock suspension. With 18x9.5ET34 with 245/35/18 all around only 3mm taller than stock.
Old 11-07-2013, 10:33 PM   #1918
OICU812
Just a dude
OICU812's Avatar
Not really any room for 9.5 up front with stock suspension.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
