| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#29 |
Drives: BRZ DGM Limited
just want to give a follow up....just finished my first top side oil change with the Hydro-Turf Oil Extractor OIL01.
It was very easy but took longer than a regular change since they only supply one size hose that is small so that it can fit down the dip stick tube. Here is a quick summery: First drive the car for 5-10 min. to warm the oil. Take off the oil cap Place the plastic tube down the dip stick. After you feel it pass the curve , advance slowly until you feel some resistance then back it out very slightly. Pump 15 times...and the oil starts flowing! I needed to add ~5 extra pumps every 20 mins It took 90 mins for all the oil to come out! Got ~5.5 liters out. Then change the oil filter, refill with ~ 5.5 liters of fresh oil and you are good to go. Clean up was very easy and I did not get oil on the floor as I usually do. Other than it taking 90 mins, it was better than the traditional way. I was surprised how thin the 0W-20 was...the stuff flows like water! |
| The Following User Says Thank You to BRZnut For This Useful Post: | scionfrs2014 (02-14-2014) |
#30 |
Drives: white Sport-tech
Thread jacking here for a second,
About to do my first oil change and just had one thing bothering me. All I have to use is a jack stand, so the car will just have the front end sticking up, is this also how guys using ramps drain it? Will I have any problems getting it all out at that angle? Thanks |
#31 |
Drives: WR Blue BRZ, 240Z
This is interesting. Are the blocks screwed together or do you build them up depending on the height you are looking to achieve? I would also think with the suspension fully extended that you have to jack the car to the maximum height of the floor jack.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#33 | |
Drives: vrooom...
Sorry for the Thread Jacking
![]() But you can make it like lego if you want. Here is the site I got the info from to make it: http://www.myturbodiesel.com/1000q/multi/wood-block.htm (My setup and measurements differ slightly from what is on the site) As for maxing out the jack it's not too bad: ![]() ![]() I can even stack my suv on it, but I got to use blocks on the jack:
| The Following User Says Thank You to M1K3 For This Useful Post: | hmong337 (11-18-2013) |
#34 |
Yeah, I'm gonna make four of these platforms. They look quite useful.
#35 |
AutoX-10/10ths every run
$20 with BYO fluids and filter at my local shop. I don't have to get dirty.
#36 | |
#37 | |
#38 |
#39 | |
Drives: vrooom...
#40 |
Drives: Firestorm FR-S (MT)
#41 | |
Thupercharged
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#42 |
This extractor came with only one tube designed to fit down the dip stick tube. I know others have another brand that comes with a bigger tube and what they do (its in the DYI section) is remove the dip stick tube and place the larger plastic tube right into the engine that speeds up the process.
| BC Coilover settings you guys guys ride on | g0lden | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 04-06-2014 06:56 PM |
| Help from the ATL guys? | Venom600 | Southeast | 22 | 08-16-2013 11:09 PM |
| what do you guys think? | xpicer | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 08-16-2012 01:08 AM |
| What do you guys think?? | Arcangel | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 10-30-2009 11:06 AM |
