Old 10-27-2013, 07:52 PM   #1
BRZnut
Drives: BRZ DGM Limited
How are you guys getting under your car to change the oil?
What are you guys using as ramps? I found one that gets the car up 2.5 inches and should not scrap the front. Would 2.5 inches be enough to reach the drain bolt?
Old 10-27-2013, 08:04 PM   #2
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Race Ramps. Expensive, but very nice. Have several lowered cars, no problems getting any of them up on ramps. 2.5" will not be enough unless you are really really skinny (with a very small head).
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 10-27-2013, 08:06 PM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
Asking if you can reach the hole with 2.5 inches doesn't belong in maintenance section, mods please move this to off topic,.
But to answer your question. You can reach with car on ground I think, but the real issue is will your drain pan fit under the car. Place your drain pan next to the car parallel the hole and if it is more than 2.5 inches higher than the underbody those ramps won't work.
Old 10-27-2013, 08:25 PM   #4
cnk
Drives: '13 DGM BRZ Limited
Rhino Ramps and some pieces of wood in front of the ramp to get the front bumper to clear the ramps.
cnk is offline   Reply With Quote
Old 10-27-2013, 08:31 PM   #5
Foobar
SLO NO MO
Foobar's Avatar
Rhino Ramps here too. I put a brick in front of each to make sure I don't scrape my lip kit. Before I had the lip kit, just a two by four was sufficient.
Old 10-27-2013, 10:45 PM   #6
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
http://www.amazon.com/Pair-Plastic-4...2928277&sr=8-5
Originally Posted by humfrz
I'm old and lazy
Old 10-27-2013, 10:47 PM   #7
twag4
Drives: frs
I made ramps out of 2x12 pine that I had laying around about 10 years ago. Bottom board 36" long, then 28, 20, and 12" on top. I put a piece of 2x2 12" long across the top front to help keep me from driving off the front. They are held together by 3" decking screws. They work great and provide a very gradual easy to climb ramp. Holds the car about 7" high. I jack the back of the car as prescribed to level it, then easily change the oil or whatever I need to accomplish.
twag4 is offline   Reply With Quote
Old 10-28-2013, 12:05 AM   #8
wlwarfield
VTECLOL
wlwarfield's Avatar
Drives: 2011 STi & 2013 F150 SVT Raptor
a floor jack and some jack stands. Takes all of 2 minutes to get the car in the air
follow me on Instagram @wlwarfield
OFFICIAL Texas BRZ, FRS, GT86 Facebook Page
OFFICIAL NM86CLUB Facebook Page
2011 Subaru Impreza WRX STi sedan
2013 Ford F-150 SVT Raptor
wlwarfield is offline   Reply With Quote
Old 10-28-2013, 09:35 PM   #9
zooki
Drives: waiting on a 2021...
My 11,000 lb. hydraulic lift..
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 10-29-2013, 11:20 AM   #10
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Same here.
I wish I had a lift
G_Ride is offline   Reply With Quote
Old 10-29-2013, 12:45 PM   #11
frs10
Drives: tezla
rhinos is what i hear people using, they are inexpensive and very good quality
frs10 is offline   Reply With Quote
Old 10-29-2013, 01:36 PM   #12
DJCarbine
Thupercharged
DJCarbine's Avatar
Rhino ramps with wood in front to prevent bumper from hitting ramp.
For just oil changes I just vacuum the oil out of the dipstick... no ramps needed
2013 FRS
Vortech V3 11psi
Old 10-29-2013, 03:00 PM   #13
muffinz
Drives: 2013 DGM BRZ Ltd
Raceramps!
muffinz is offline   Reply With Quote
Old 10-29-2013, 04:49 PM   #14
Mikem53
Drives: FR-S 6MT
How much of it do you collect? This would be most convenient and least messy way to handle it. How much gets left in the pan with this method...
I have always done it the old fashioned way.. My neighbor has a lift..
Mikem53 is offline   Reply With Quote
BC Coilover settings you guys guys ride on g0lden Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-06-2014 06:56 PM
Help from the ATL guys? Venom600 Southeast 22 08-16-2013 11:09 PM
what do you guys think? xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 08-16-2012 01:08 AM
What do you guys think?? Arcangel Scion FR-S / Toyota 86 GT86 General Forum 19 10-30-2009 11:06 AM
