Old 11-02-2013, 12:32 AM   #29
BRZnut
Drives: BRZ DGM Limited
just want to give a follow up....just finished my first top side oil change with the Hydro-Turf Oil Extractor OIL01.
It was very easy but took longer than a regular change since they only supply one size hose that is small so that it can fit down the dip stick tube. Here is a quick summery:
First drive the car for 5-10 min. to warm the oil.
Take off the oil cap
Place the plastic tube down the dip stick. After you feel it pass the curve , advance slowly until you feel some resistance then back it out very slightly.
Pump 15 times...and the oil starts flowing!
I needed to add ~5 extra pumps every 20 mins
It took 90 mins for all the oil to come out!
Got ~5.5 liters out.
Then change the oil filter, refill with ~ 5.5 liters of fresh oil and you are good to go.
Clean up was very easy and I did not get oil on the floor as I usually do.
Other than it taking 90 mins, it was better than the traditional way.
I was surprised how thin the 0W-20 was...the stuff flows like water!
The Following User Says Thank You to BRZnut For This Useful Post:
scionfrs2014 (02-14-2014)
Old 11-02-2013, 09:04 AM   #30
Muskokan
Drives: white Sport-tech
Thread jacking here for a second,
About to do my first oil change and just had one thing bothering me.
All I have to use is a jack stand, so the car will just have the front end sticking up, is this also how guys using ramps drain it? Will I have any problems getting it all out at that angle?
Thanks
Muskokan is offline   Reply With Quote
Old 11-02-2013, 09:44 AM   #31
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
This is interesting. Are the blocks screwed together or do you build them up depending on the height you are looking to achieve? I would also think with the suspension fully extended that you have to jack the car to the maximum height of the floor jack.
Originally Posted by M1K3 View Post
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 11-02-2013, 04:08 PM   #32
Gunman
Drives: 2019 Mazda Miata RF
Made my own ramps, from a 2x10.
Old 11-02-2013, 04:30 PM   #33
M1K3
M1K3's Avatar
Drives: vrooom...
Sorry for the Thread Jacking
Yes it's all screwed together:
But you can make it like lego if you want. Here is the site I got the info from to make it: http://www.myturbodiesel.com/1000q/multi/wood-block.htm (My setup and measurements differ slightly from what is on the site)
As for maxing out the jack it's not too bad:
I can even stack my suv on it, but I got to use blocks on the jack:
M1K3 is offline   Reply With Quote
The Following User Says Thank You to M1K3 For This Useful Post:
hmong337 (11-18-2013)
Old 11-03-2013, 12:07 AM   #34
Gary in NJ
Gary in NJ's Avatar
Yeah, I'm gonna make four of these platforms. They look quite useful.
Old 11-03-2013, 12:25 AM   #35
whataboutbob
AutoX-10/10ths every run
$20 with BYO fluids and filter at my local shop. I don't have to get dirty.
Build thread:Here
Old 11-03-2013, 01:44 AM   #36
BRZnut
Thanks
Correct me if I am wrong guys but my understanding is to never use just a jack stand to get under the car. If it slips, you're toast.
Old 11-03-2013, 01:49 AM   #37
jcat5150
I got the 2 Ton Low Profile Jack from Harbor Freight
It's a heavy SomBitch though!!!
Get the warranty if you're going to get that one - also wait for one of the huge coupons for this specific jack to offset the costs. I have had to trade in 2 of them already (bought the low profile just for the 86) since I bought the car. It is actually in the back of my truck now waiting to go back on Monday.
jcat5150 is offline   Reply With Quote
Old 11-03-2013, 08:10 AM   #38
Muskokan
well i have a jack and blocks i can use? i just want to know if draining at an angle will still get all the crap out.
anyone?
Old 11-03-2013, 09:37 AM   #39
M1K3
M1K3's Avatar
Drives: vrooom...
Damn that sucks! I got the warranty. I have had mine for over a year now bought it for $120 with the 2yr warranty.
Old 11-03-2013, 09:39 AM   #40
Shagaliscious
Drives: Firestorm FR-S (MT)
Originally Posted by zooki View Post
My 11,000 lb. hydraulic lift..
I don't have my own, but my buddy does. They are fantastic.
Old 11-03-2013, 10:24 AM   #41
DJCarbine
Thupercharged
DJCarbine's Avatar
90 mins is a long time..... is there any way to use a larger tube with your extractor?
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 11-03-2013, 11:02 AM   #42
BRZnut
This extractor came with only one tube designed to fit down the dip stick tube. I know others have another brand that comes with a bigger tube and what they do (its in the DYI section) is remove the dip stick tube and place the larger plastic tube right into the engine that speeds up the process.
BC Coilover settings you guys guys ride on g0lden Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-06-2014 07:56 PM
Help from the ATL guys? Venom600 Southeast 22 08-17-2013 12:09 AM
what do you guys think? xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 08-16-2012 02:08 AM
What do you guys think?? Arcangel Scion FR-S / Toyota 86 GT86 General Forum 19 10-30-2009 12:06 PM
