go_a_way1
Old 10-31-2013, 05:18 PM   #1891
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Originally Posted by Slick View Post
18x8.5 +33 will work well on your car. What is your front camber set at?
18x9.5+40 will be very tight and may not fit unless you are running coilovers.
Currently I'm -2 all around but will be -1.5 all around next spring. I'm on kW coils yes.
Old 11-01-2013, 10:07 AM   #1892
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
With that camber, the 18x9.5+40 should be flush, 18x8.5+33 a little tucked in (6mm more).
Why are you reducing the camber?
Slick is offline   Reply With Quote
Old 11-01-2013, 10:58 AM   #1893
OICU812
Just a dude
OICU812's Avatar
Just find -2 to be abit aggressive, especially on rear we'll see. A slight less width on back may balance that some not sure.
Old 11-01-2013, 01:51 PM   #1894
Slick
Slick's Avatar
I concur, our cars don't need as much camber as most do. I'm at -2.2 all around, track the car quite a bit and still find a bit more wear on the inside.
Old 11-02-2013, 09:05 AM   #1895
hamdan
Drives: Toyota 86
Hey guys, finally found the wheels of my dream but they come in limited offsets.
18x9.5 +30 Square. Will they fit? I know theres someone who has run 8.5/9.5 staggered and said he said the slightly roll and flare the fenders which im fine with doing if required. All help appreciated
hamdan is offline   Reply With Quote
Old 11-02-2013, 07:13 PM   #1896
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
correction** +33 will poke a little more than +40 ... but all in all he will fit fine
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 11-02-2013, 07:38 PM   #1897
OICU812
Just a dude
OICU812's Avatar
The comparison was a 18x9.5" : 40 offset to a 18x8.5" :33 offset though.
Old 11-02-2013, 09:50 PM   #1898
Slick
Slick's Avatar
See here: http://www.frsproject.com/tire_size.php
6mm more tucked for the 8.5+33
The other wheel is an inch wider so it's not a straight offset to offset comparison.
Old 11-02-2013, 10:03 PM   #1899
ScionFR-S
ScionFR-S's Avatar
ahhh your right i didnt even notice the inch wider in rim width... running on no sleep lol
Old 11-02-2013, 10:31 PM   #1900
FLIPs_FR-S
KCCO
FLIPs_FR-S's Avatar
Drives: 2013 Raven Scion FR-S, AT
Alright, here goes. I am very lost when it comes the wheel and tire setup. I would really rather not stagger mine when I buy aftermarket but I may have no choice.
How bad would this stick outside the front fenders. 245/30R19 on 19x9.5 ET35, only 2 companies make this size tire according to tire rack. Or 255/30R19, larger choice or tires in this size.
Sent from SAMSUNG GALAXY NOTE. KEEP CALM AND CHIVE ON.
Alabama state head for Southeast 86
https://www.facebook.com/groups/Southeast86/
FLIPs_FR-S is offline   Reply With Quote
Old 11-02-2013, 10:33 PM   #1901
FLIPs_FR-S
KCCO
FLIPs_FR-S's Avatar
Larger choice OF tires** tapatalk wouldn't let me edit.
Old 11-02-2013, 10:51 PM   #1902
Khánh
Khánh's Avatar
Drives: sc00ter
if anyone could help, would greatly appreciate it cuz i'm losing sleep over this haha
Will I be able to fit 255/35/18 with 18x9.5 et34 for the rear without any poking? I don't have any camber kit either and am lowered on coilovers..
Khánh is offline   Reply With Quote
Old 11-03-2013, 01:32 AM   #1903
Antheezy
So I just picked up some Weds Sport Sa-15r 18x8.5 squared setup +48 all around. I think the fronts is pretty close to flush at 1 inch drop, but im a bit lost with everything. Mind helping me out?
Antheezy is offline   Reply With Quote
Old 11-03-2013, 12:34 PM   #1904
Slick
Slick's Avatar
Depends on your suspension, coils or coilovers?
It's a tight fit, more due to the wheel offset than the tire size, so you may need to pull a bit more camber in the front to make it work. Probably around 2.5-3 degrees. Rears will fit fine and the 255 is a better tire for that width, although a bit taller than stock.
I'm sure you already know you will lose acceleration from the added weight of the 19s and the taller tire.
The Following User Says Thank You to Slick For This Useful Post:
FLIPs_FR-S (11-03-2013)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
