Old 11-01-2013, 02:00 PM   #43
CARNZ
CHECK ENGINE
Drives: 2004 STi
You could disconnect the water pump bypass hose from the BRZ water pipe, run it up to the oil cooler, then run the oil cooler outlet down to the BRZ water pipe.
i don't cry about crickets
CARNZ is offline   Reply With Quote
Old 11-01-2013, 02:04 PM   #44
boxer 2.5
Drives: 2007 Impreza, 2013 BRZ
Come install it on mine!
boxer 2.5 is offline   Reply With Quote
Old 11-01-2013, 02:26 PM   #45
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Do you have logs of oil temps? At what temps do the oil stabilizes at?
Tye300 is offline   Reply With Quote
Old 11-01-2013, 02:32 PM   #46
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
Ok, everything on order. Ill update once I get it installed.
Thanks again!
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 11-01-2013, 08:06 PM   #47
utekineir
blowhard
Drives: frs, project forester
In for results.
Be awesome if this works better than the ej25 implementation.
utekineir is offline   Reply With Quote
Old 11-01-2013, 09:03 PM   #48
Kostamojen
Originally Posted by no chrome View Post
So this does effectively put the cooler in parallel with the heater core?
I like it but might prefer to have the cooler after the radiator, I'll have to take a look at mine and see if that is even possible
The coolant throughout the system is regulated to ~195 degrees so ya its more about pressure. Plus we are trying to replicate the turbos routing as close to factory as possible.
But ya as carnz mentioned, you could put the cooler routed before the heater core or before the ATF cooler on the AT cars if you want.
Old 11-01-2013, 10:59 PM   #49
xxscaxx
Drives: 2013 SWP BRZ
I ordered everything as well. Thank you OP for the information and writeup.
xxscaxx is offline   Reply With Quote
Old 11-01-2013, 11:28 PM   #50
CARNZ
CHECK ENGINE
Drives: 2004 STi
Got some interest from people for the "Oil Cooler Bundle", should be placing the first orders Monday with the parts shipping Thursday.
The Following User Says Thank You to CARNZ For This Useful Post:
niceguy21 (11-02-2013)
Old 11-02-2013, 12:27 AM   #51
Kostamojen
Hopefully we don't exhaust the supply of these oil coolers... LOL!
The Following User Says Thank You to Kostamojen For This Useful Post:
Old 11-02-2013, 12:42 AM   #52
niceguy21
Socal Valley 86 Member
niceguy21's Avatar
Drives: 2000 Toyota Tacoma SR5 & Scion FRS
I'm definitely interested in buying a bundle too and I was also wondering if anyone else is going to try this would it be possible to make a video. I know the instructions are pretty straight forward, but a vid would helpful too. I'm not too mechanic savvy however it would be greatly appreciated
Sent from my HTCEVODesign4G using Tapatalk
niceguy21 is offline   Reply With Quote
Old 11-02-2013, 02:36 AM   #53
8686
8686's Avatar
Drives: 86
I am also onterested
Just waiting for some temprature readings before and after the cooler.
Thank you
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
The Following User Says Thank You to 8686 For This Useful Post:
Old 11-02-2013, 02:59 AM   #54
PantsDants
Drives: Scion FR-S A/T, Whiteout
And if anyone could post pics for what they did differently on an auto, that'd be A+. It sounds like a simple change to the instructions, but I'd rather have pictures in front of me when I set out to do this.
PantsDants is offline   Reply With Quote
The Following 3 Users Say Thank You to PantsDants For This Useful Post:
TheMedakaBox (08-15-2017), Tye300 (11-02-2013), zoomzoomers (11-04-2013)
Old 11-02-2013, 04:17 AM   #55
akyp
Drives: 2012 86
Would this be any different with RHD cars?
akyp is offline   Reply With Quote
Old 11-02-2013, 06:37 AM   #56
Tye300
Tye300's Avatar
In for this. AT owner here just waiting for additional info.
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 12:29 PM
