Drives: AE86, 2x GT86, TE27
When lowering 2 inches or more...
I see more people lowering their cars 2 inches and beyond, and an wondering what other components are going to need to be replaced to get a decent alignment?
At that height, rear camber will be fairly extreme, so will need rear LCA to pull that back. I also imagine the stock toe arm won't have that much adjustment, so will need to replace that. At the front, camber won't be affected, so am thinking the whiteline balljoint/tie rod end is a quick fix; however would you be better to go front lca? Interested to hear what those at this height have done. Thanks |
#2 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Interested in this as well.
#3 |
Drives: 2013 Whiteout FR-S
Sub'd
#4 |
Boosted
Drives: Not a supra....yet
I'm lowered 4.5" and after adding lca's my toe maxed out. I only have -4 in the rear and already have my toe off.
#5 |
Weight Nazi
| The Following 5 Users Say Thank You to Anthony For This Useful Post: | mwjcyber (10-28-2013), Starkiller (10-28-2013), Stealth Gt86 (10-28-2013), Stierzy34 (10-28-2013), SubiePig (10-28-2013) |
#7 |
Drives: 13' Subaru BRZ Limited SWP 6MT
When dropped 2", you're new camber will be approx -1deg front, -2 deg rear.
Front: coilover camber plates give you +/-2deg camber adjustability, crash bolts ~1deg, and stock toe adjustment can handle this drop without mod. Rear: stock toe adjustment, but no stock or coilover camber adjustment, so you'll need bushings or LCAs. The SPC LCAs come with rear toe bushings, but you shouldn't need them for 2" or less drop. FYI, I recommend LCAs over bushings, because if you include cost of a shop using a press to swap bushings, it costs the same as some LCAs; which you can install yourself and easily swap back to stock. Great video detailing rear LCA installation and alignment. [ame]http://youtu.be/pQ5fCjMIfjI[/ame] |
| The Following User Says Thank You to mwjcyber For This Useful Post: | diss7 (11-11-2013) |
#8 |
Weight Nazi
| Wheel Directory: Racing Hart CP-035 17x7.5 +48 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 02-17-2016 11:28 AM |
| Lower car 1.5 - 2.0 inches | F3dzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 06-23-2012 09:30 PM |
