View Poll Results: Who Has the Advantage/s?
Rotary(Rx8 motor) has the Advantage Over Flat 4's? 17 47.22%
Or Flat 4 over Rotary Engines (Rx8 Motor)? 19 52.78%
Voters: 36. You may not vote on this poll
Old 11-06-2012, 02:22 PM   #99
DarkSunrise
DarkSunrise's Avatar
Came across this recently. Thought it might be interesting to see an RX-8 and GT86 tested on the same dyno (Supersprint's MAHA brake dyno). The RX-8 revs much higher and makes an additional 12-13 peak hp, but surprising (at least to me) how much more torque the GT86 made in the low/mid-range. About 50-60 N m (40 lb-ft) more torque from 2100-3100 rpm.
Old 11-24-2012, 08:13 PM   #100
swift996
swift996's Avatar
I use to have a RX8, I clipped a 14.4 with it in the 1/4. Had some wider tires and intake/exhaust. Loved the car, handled great, but getting 17mpg without a lot of go got old. Rotary engines have several advantages vs a piston engine. The flat/boxer engine is the next best thing to a rotary IMO.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-13-2013, 02:20 AM   #101
Wolfe
86 Investigator
Wolfe's Avatar
Drives: RX-8
RX-8 1.3 liters. Automatic does not redline as high as the M/T. All the power is in the high end RPM of the 8. Its probably the worst automatic sports car for that reason and the fact that it will not clear carbon as well causing premature engine failure. RX-8 and FRS are for the track. Stop drag racing them! making us look bad! haha.
日本製
Wolfe is offline   Reply With Quote
Old 02-13-2013, 11:39 AM   #102
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
OP is heavier? just say it to your friend your car is super faster.
no drag racing on street.
Old 04-27-2013, 01:44 AM   #103
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
Lol, you'll beat him on the second run though when he runs out of gas.
Ganthrithor is offline   Reply With Quote
Old 04-28-2013, 10:59 AM   #104
Shredicus
Shredicus's Avatar
Drives: 03 Lincoln LS V8
Originally Posted by GT-ROKIN View Post
After an argument about which car is better, my friend who owns a 2006 Mazda Rx8 VS my FRS.
1/4 Mile Run
On the launch i was a head for like a few second in sport mode using the paddle shifters perfectly, but for some reason i can feel my car maxing out and not moving a fast as i think it would, on each gear high revs and that feeling of getting tossed back in to the seats was missing. i felt oddly out of place.(Felt like i was driving a Hyundai). However, the RX8(also AT W/Paddle Shifters) took the victory by one car length +.
HIGHLY DISAPPOINTING!!
I dont know if this might be a flaw in my car, or the it has some thing to do with the ECU or Tranny / something else.... any ideas?
Or Rotary Engines Totally Have the upper hand (which i refused to believe)
The one with 75 more horsepower or the one with 150 more?
Shredicus is offline   Reply With Quote
Old 05-07-2013, 01:48 AM   #105
civdaddy
Drives: Slow
I don't know why people are bashing them for racing their cars because they are both slow. If its a close race, it's always fun in my book.
civdaddy is offline   Reply With Quote
Old 05-07-2013, 09:12 AM   #106
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by roadtrip1098 View Post
Keep in mind a rotary motor is smaller, and the cylinder fires 3 times every rotation where a single cylinder conventional motor fires once every two rotations.
So with a 1.3L Rotary you get 1.3L 3 times per rotation so that's 3.9L per rotation
Not exactly...
Each rotor only fires ONCE per crank rotation. Three times per *rotor* rotation, but rotor rpm is 1/3 crank rpm.
If it's a 3.9 liter, it's a 3000rpm 3.9 liter, as that's the maximum rpm of the rotors.
In an H4 2.0 you get 2 cylinders firing per rotation at .5L each so that's 1.0L per rotation.
Yes, and the 13B rotary engine displaces 1.3 liters per crank revolution.
Like a 2-stroke, the rotary displaces its full displacement every crank rev. This is an advantage, but really more like a 1.5x advantage rather than 2x due to inherent rotary inefficiency (throws away energy as heat like CRAZY).
So a 9000rpm 1.3 liter na rotary ends up roughly comparable to a 9000rpm 2.0 liter piston engine. 13B ~ F20C. But not quite... F20C makes a little more.
Old 05-07-2013, 03:20 PM   #107
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
1/4 Mile Run
The fault is in the owner, who the hell buys an automatic sports car?
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
The Following User Says Thank You to Adeets For This Useful Post:
Tim_Asphalt_FRS (05-07-2013)
Old 10-27-2013, 06:51 PM   #108
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Originally Posted by RowTarEEE View Post
The FR-S should eat an automatic RX-8 alive. Now, a manual RX-8 with comparable drivers will beat a manual FR-S/BRZ every single time. Don't know how you lost to that RX-8. Source: I have both cars
? someones on crack. i take my buddys rx8 all day. just this friday we were on the highway and i was behind him we both stayed in 6th and i actually passed him about 112mph from behind him n i had to go around him.
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 10-27-2013, 06:54 PM   #109
sosick
fastest frs in sbg
sosick's Avatar
I have a series 1 MT '04 RX-8 which quoted 14.3 at the 1/4th. In this article from caranddriver, 14.5 for MT. " the RX-8 scooted to 60 mph in 5.9 seconds and through the quarter-mile in 14.5 seconds at 96 mph." You are quoting the series II RX-8 R3 which is heavier. Besides, the OP raced an automatic RX-8, which is significantly slower than a MT with only 7,500RPM redline
http://www.caranddriver.com/comparis...da-rx-8-page-4.
u guys are looking at pro drivers....
2014 firestorm frs
Old 10-30-2013, 11:24 PM   #110
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
I raced a nice, clean mt rx8 twice one night (before my header/unichip) and beat it both times. They are nice cars.. some are quick, some are not.
Car is gone - parts for sale
6speed_Sam is offline   Reply With Quote
Old 05-17-2014, 01:40 AM   #111
ronboogieon
BReeZy Hunter
ronboogieon's Avatar
Drives: 13 DGM BRZ Limited 6MT
RX8 tried to race me... Winner...Cop by a car length!
Lol, I ignored him. He pulls away and an unmarked popo comes behind him and pulls him over a car length later!
ronboogieon is offline   Reply With Quote
RX-9 Rotary Rumor Mill Churning Again Ae86 Other Vehicles & General Automotive Discussions 55 09-10-2012 08:26 AM
TSW Nurburgring Rotary Forged Wheels Eric@GetYourWheels Wheels and Tires 6 08-01-2012 12:19 PM
TSW Interlagos Rotary Forged Wheels Eric@GetYourWheels Wheels and Tires 9 08-01-2012 12:15 PM
Rotary Extinction??? Rotarydisciple Other Vehicles & General Automotive Discussions 53 01-23-2010 09:58 PM
