Old 10-26-2013, 12:11 AM   #43
SUB-ZERO
Drives: GT86/GTR R35
Originally Posted by the.big.kahoona View Post
If you need to test anything on a dubai 86 im game haha
Sent from my SM-N9005 using Tapatalk
what do you mean
SUB-ZERO is offline   Reply With Quote
Old 10-26-2013, 12:12 AM   #44
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Originally Posted by SUB-ZERO View Post
1- CP PISTON 9.1
2- CARRILO CONNECTING ROD H - BEAM
3- DYNASTY HEAD STUD
4- HEAD GASKET
5- LABOUR CHARGE ENGINE BUILT
- 3930 $
awesome. thats about what i was hoping. also i saw something about lil 400 HP. is that what the engine is making with all this or was that something different?
lbroskee is offline   Reply With Quote
Old 10-26-2013, 12:17 AM   #45
SUB-ZERO
you can go more but need to upgrade the drivetrain and tran
Old 10-26-2013, 12:38 AM   #46
lbroskee
lbroskee's Avatar
400 NA is more then enough for a DD honestly. any idea on TQ numbers?
Old 10-26-2013, 12:54 AM   #47
SUB-ZERO
IT WILL BE LESS THEN THE HP BY 15%
The Following User Says Thank You to SUB-ZERO For This Useful Post:
lbroskee (10-26-2013)
Old 10-26-2013, 04:48 AM   #48
SUB-ZERO
is their any ecu for this car other then ecutek ?
Old 10-26-2013, 05:25 AM   #49
the.big.kahoona
the.big.kahoona's Avatar
Drives: 2013 Raven 86
what do you mean
I meant if you ever need a car to test something on it im willing to donate mine. Twas a joke but serious at the same time
the.big.kahoona is offline   Reply With Quote
Old 10-26-2013, 05:56 AM   #50
Bingbong
Bingbong's Avatar
Drives: Crv,Legacy-ultramarine frs
[QUOTE=Bingbong;1294667]All my thumbs is up man..just thinking about the trans how long the power 550hp ca handle this whats the upgrade? if i have 5 thumbs ill put it up too..goodluck..:-D
Bingbong is offline   Reply With Quote
The Following User Says Thank You to Bingbong For This Useful Post:
SUB-ZERO (10-26-2013)
Old 10-26-2013, 07:01 AM   #51
NomoreNA
NomoreNA's Avatar
Drives: Raven FRS
If you want to keep DI check out the Hydra ecu from element tuning.
NomoreNA is offline   Reply With Quote
The Following User Says Thank You to NomoreNA For This Useful Post:
Old 10-26-2013, 07:21 AM   #52
armythug
armythug's Avatar
Drives: Pegasus White 86GTS
Nice build. Are you going to upgrade your engine mounts?
Pegasus White 6MT got it. :happy0180:
armythug is offline   Reply With Quote
The Following User Says Thank You to armythug For This Useful Post:
Old 10-26-2013, 09:27 AM   #53
mike the snake
I went with the Hydra system for my car. It has a LOT more to offer, especially for big HP.
It's a standalone system, and also has an associated methanol system called Hydramist (made by Aquamist).
Mine will be installed and tuned in a couple weeks. I'll be doing a build thread.
The Following User Says Thank You to mike the snake For This Useful Post:
Old 10-26-2013, 10:22 AM   #54
lbroskee
lbroskee's Avatar
wow 1800 for a new ECU? thats a lot of money (don't know if that is AVG cost tho)
Old 10-26-2013, 10:37 AM   #55
Ross
Drives: 85 corolla gts
1800 for proper engine management is a fair price. If anything it is actually on the cheap side. I would personally prefer to use a full standalone over the factory ecu for certain cars. A standalone can bring a lot to the table. If the factory ecu had more available inputs and outputs it would be nice. There are a lot of variables I would like to be able to log, with out having to add a secondary logger. These are just my opinions. Also Hydra is a good system and I would definitely recommend checking it out.
Ross is offline   Reply With Quote
The Following 2 Users Say Thank You to Ross For This Useful Post:
lbroskee (10-26-2013), SUB-ZERO (10-26-2013)
Old 10-26-2013, 12:18 PM   #56
mike the snake
Compared to Ecutek, which is $700-$800, it's about a grand more, and it's a true standalone. for me, that meant that I could set the stock ECU aside until I put the car back to stock when/if I decide to sell the car or need to smog it.
I'm also going for more power than just 91 gas can offer, with WMI. The fact that the Hydra has a sister WMI system, Hydramist (made by aquamist), means that it's all going to work together and be much easier to install and tune, almost plug and play.
I saw thread or vid of someone who installed an Aquamist WMI system with Ecutek, and it looked like a wiring nightmare, and still wasn't dialed in. The guy was working with Aquamist still trying to get it to work, and the wiring jumble I saw scared me a LOT.
Also, I didn't want to use Ecutek, and Openflash doesn't support WMI, so I was limited in choices.
My tuner is familiar with Hydra and has tuned with it before, so that weighed in on my decision as well.
The Hydra I was told is better for BIG HP and for racing applications, where more exact control is required.
Frs300 Fa20club built motor and turbo build Frs300 Member's Car Journals 32 01-18-2014 05:27 AM
Worlds Fastest Turbo BRZ gets faster! Accelerated Performance Built - Visconti Tuned Visconti Forced Induction 697 11-13-2013 06:18 PM
Crawford Limited Turbo BRZ - built motor Mrqb22 Forced Induction 8 11-11-2013 01:34 PM
What is the best turbo for a fully built engine scion frs SUB-ZERO Forced Induction 41 09-18-2013 06:41 PM
Will FR-S ever have a aftermarket turbo built? docyzx Forced Induction 50 07-19-2012 12:20 AM
