Old 10-25-2013, 08:22 AM   #29
charged86
charged86's Avatar
@SUB-ZERO nice work my friend!
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
The Following User Says Thank You to charged86 For This Useful Post:
SUB-ZERO (10-25-2013)
Old 10-25-2013, 10:09 AM   #30
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Originally Posted by NomoreNA View Post
Nice build I will definitely be following this. I am curious why you chose c16 over q?
Doesn't C work better on low comp application? Or something to do with fi and hi comp, I just woke up and I can't think
Old 10-25-2013, 10:37 AM   #31
MrSlay
Drives: Gx 460, FRS, Prius
Q is oxygenated and will runs a bit leaner... Theoretically makes more power though.
15 FRS
12 Prius
12 ISF
15 Gx 460
My YouTube Channel
MrSlay is offline   Reply With Quote
Old 10-25-2013, 11:12 AM   #32
NomoreNA
NomoreNA's Avatar
Drives: Raven FRS
Q can also handle more timing and in most cases improves spool. Knowing what fuel best suits your car is definitely important. In full race applications I have seen up to a 23% increase in power just from changing fuel and optimizing my tune.
NomoreNA is offline   Reply With Quote
The Following User Says Thank You to NomoreNA For This Useful Post:
MrSlay (10-25-2013)
Old 10-25-2013, 11:40 AM   #33
Ross
Drives: 85 corolla gts
Only concern I would have with q is the injectors. Not just the port injectors but the direct injectors. I know some injectors have low compatibility with q. With that said how will the direct injectors deal with it.
Ross is offline   Reply With Quote
Old 10-25-2013, 12:08 PM   #34
Alhammadi
Drives: 2013 Toyota FT86
Hi Sub-Zero, I heard alot about Sub-Zero shop in UAE, I have FBM turbo kit on my 86, and I am planning to build my engine as well, please let me know if its possible to bring the car to you guys to do that. and aprox how much its gonna cost. PM me plz =)
Alhammadi is offline   Reply With Quote
Old 10-25-2013, 01:03 PM   #35
SUB-ZERO
Drives: GT86/GTR R35
Done
SUB-ZERO is offline   Reply With Quote
Old 10-25-2013, 01:04 PM   #36
SUB-ZERO
guys it's not important for now I am going to finish my engine and put the turbo kit and computer after ill think about the fuel
Old 10-25-2013, 01:20 PM   #37
the.big.kahoona
the.big.kahoona's Avatar
Drives: 2013 Raven 86
If you need to test anything on a dubai 86 im game haha
Sent from my SM-N9005 using Tapatalk
the.big.kahoona is offline   Reply With Quote
Old 10-25-2013, 01:52 PM   #38
SmsAlSuwaidi
Boosted
Good to know!
Old 10-25-2013, 03:33 PM   #39
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Wut was the cost in parts about just for a built block? I'm really curious on this way more then a swap
lbroskee is offline   Reply With Quote
Old 10-25-2013, 03:40 PM   #40
SmsAlSuwaidi
Boosted
The thing that interests me is the usage of the hks gasket
edit: Part number for the clutch being used ?
Old 10-25-2013, 11:57 PM   #41
SUB-ZERO
Wink
WEBSITE ; http://www.ppi-ats.com/Carbon_clutch...010_Toyota.pdf
Old 10-26-2013, 12:10 AM   #42
SUB-ZERO
1- CP PISTON 9.1
2- CARRILO CONNECTING ROD H - BEAM
3- DYNASTY HEAD STUD
4- HEAD GASKET
5- LABOUR CHARGE ENGINE BUILT
- 3930 $
The Following User Says Thank You to SUB-ZERO For This Useful Post:
lbroskee (10-26-2013)
Frs300 Fa20club built motor and turbo build Frs300 Member's Car Journals 32 01-18-2014 05:27 AM
Worlds Fastest Turbo BRZ gets faster! Accelerated Performance Built - Visconti Tuned Visconti Forced Induction 697 11-13-2013 06:18 PM
Crawford Limited Turbo BRZ - built motor Mrqb22 Forced Induction 8 11-11-2013 01:34 PM
What is the best turbo for a fully built engine scion frs SUB-ZERO Forced Induction 41 09-18-2013 06:41 PM
Will FR-S ever have a aftermarket turbo built? docyzx Forced Induction 50 07-19-2012 12:20 AM
