Old 10-25-2013, 10:29 PM   #15
dnieves
Drives: FR-S 10 Series
Originally Posted by Jertronic View Post
Okay, with winter coming right up and my plan to use my FR-S as my year round dd I want to buy the part.
1. They come in black only, or more choices?
2. Is there a difference between ordering from dealer and ordering from Amazon?
Thanks
Sent from my iPhone using Tapatalk - now Free
1- They only come in black, they're soft rubbery black plastic so I don't think paint with flex (not flecks) will adhere to them for the long term (if you decide to paint them).
2- No difference for OEM mud guards except Amazon is cheaper. Out of state dealers charge the same as Amazon; local dealerships have to charge the list price Scion states on the website.
dnieves is offline   Reply With Quote
Old 11-11-2013, 11:03 PM   #16
Jertronic
Jertronic's Avatar
Drives: FR-S 10 Series 120 of 2500
Will the holes left by attaching mud flaps be an eye sore when removing flaps in the spring? Curious if it is common to remove once crap weather is over with. Or, do people just keep the flaps on for good?
Jertronic is offline   Reply With Quote
Old 11-11-2013, 11:22 PM   #17
rishi
rishi's Avatar
Drives: FR-S Series 10 #0059
The holes are in the black plastic parts of the wheel well, and they're already drilled and filled with plugs. Just put the original push plugs back in to fill them, and you can pick up some matching plain black push plugs for the one hole you have to drill for each flap.
But really, there's no reason to remove the OEM flaps - they're molded to be very unnoticable, since they match the wheel well itself.
rishi is offline   Reply With Quote
Old 11-11-2013, 11:24 PM   #18
I have the OEM mud flaps and leave them on all year long.
In addition to being "mud" flaps, they are dirty water, sand, gravel and dirt flaps ....
Old 11-12-2013, 01:41 AM   #19
dnieves
if you want to be totally secure that the mudguards will not damage your paint with trapped debris just cut strips of 3M paint protection film on the painted areas covered by the mudguards. -Worked like a charm for me.
Old 11-12-2013, 02:17 AM   #20
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
Originally Posted by Optimus Prime View Post
I used all the pre-drilled holes already on the frame. Followed the directions to a T. They do stick out further than the OEM, but I never understood why people thought they stuck out too far on this car.
Since i never done this before i wanted to make sure. No drilling is required correct?
Kelbyat07 is offline   Reply With Quote
Old 11-12-2013, 04:09 AM   #21
The359
X Rated
The359's Avatar
Drives: 2017 BRZ Series.Yellow
I'd assume the answer would be yes, but I'll ask anyway - The TRD mudflaps will fit the BRZ? Subaru and SPT dont offer any OEM mudflaps for the BRZ.
NULLA TENACI INVIA EST VIA
My BRZ
The359 is offline   Reply With Quote
Old 11-12-2013, 04:52 AM   #22
sc0urge
sc0urge's Avatar
Drives: 2013 BRZ CBS
I'm a big fan of the OEM mud flaps and the way they look on our cars. However, having the flaps come in direct contact with the paint/clear coat makes me uneasy. It's possible that dirt and small rocks could get caught between your car and flaps and cause some marring to the paint. @PantsDants started a thread showing these potential issues (of course YMMV): http://www.ft86club.com/forums/showthread.php?t=50624 . With that said, I think dnieves's suggestion may be a solution to this. Just thought I'd share!
sc0urge is offline   Reply With Quote
Old 11-12-2013, 07:53 AM   #23
Mikem53
Drives: FR-S 6MT
I installed the OEM flaps about 6 months ago... I removed them last week.. Decided I didn't care for the look.. There was some dirt and debris under the flaps where they attached to the car but I was lucky and don't have any rubbing paint damage or anything after they were removed. Looks better without them, IMO.
Mikem53 is offline   Reply With Quote
Old 11-12-2013, 09:53 AM   #24
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Yes I have a set on my BRZ.
Not labelled TRD but they are the stock FRS flaps fitted to all Canadian spec FRS.
Suberman is offline   Reply With Quote
Old 11-12-2013, 08:12 PM   #25
Optimus Prime
Optimus Prime's Avatar
Drives: Whiteout 2013 FR-S
Correct. I did not drill any holes installing the RA flaps. Nor did I remove any tires. However, life would've been much easier with smaller hands or removing the tires. All said and done it took 1 or 2 hours including stopping to eat dinner and play with my daughter for a few minutes...and I'm not the handiest of guys.
Optimus Prime is offline   Reply With Quote
The Following User Says Thank You to Optimus Prime For This Useful Post:
Kelbyat07 (11-12-2013)
Old 11-12-2013, 11:20 PM   #26
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
Ok i just dont know why some people are saying that some has to drill another hole or they had to remove the back tires.
Old 11-13-2013, 02:28 AM   #27
fitcious
i have the OEM mud guards from Scion. I had to drill holes. i believe it is stated in the instructions...but i also heard you don't have to
fitcious is offline   Reply With Quote
Old 11-13-2013, 07:46 AM   #28
Mikem53
Drives: FR-S 6MT
You have to poke a hole in the rear mudflaps for the inner part of the flap to stay tight in the wheel well. This is just a screw sized hole going into the inner fender plastic. When I removed the mudflap I just stuck the plug that was holding the mudflap in and left it in there you can't even tell there was ever a hole
there. I had to remove the rear wheels to get the mudflap installed, but just had to turn the front ones to have access to mount those.
The Following User Says Thank You to Mikem53 For This Useful Post:
Kelbyat07 (11-13-2013)
FS RallyAmrmor Mud Flaps C3L1CA Exterior Parts (Aero, Lighting, Etc.) 17 10-28-2013 10:09 PM
Mud Flaps DIY? Jertronic DIY (Do-It-Yourself) Guides 16 10-13-2013 03:58 PM
Mud flaps Kev01 AFRICA 43 04-13-2013 04:32 PM
Red mud flaps on white frs wtout86 Cosmetic Modification (Interior/Exterior/Lighting) 3 11-09-2012 10:01 AM
Mud flaps worth it? lbroskee Scion FR-S / Toyota 86 GT86 General Forum 31 09-23-2012 02:02 PM
