#57 | |||
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
If I had to make an educated guess though, I would have to say that you should be able to get the same numbers as you would otherwise, but with better bottom to mid range performance. In other words, the ESC would help (dramatically) on the bottom end but at the top, the dyno chart would look similar to your typical NA set up with a bolt ons, @ WOT. The slight restriction with the minimal boost pressure would probably negate getting much more. This is all conjecture of course. The exception to that is using E85, and that's going to be more of the same but with the increased ignition timing, you should be able to break into the 200s. Quote:
![]() Cheers! Bob @ Drift-Office, LLC |
#58 | |
Drives: Scion FR-S/Toyota Yaris
IMHO this would be a more attractive kit with modern Lithium batteries. Why not LiFePO4 batteries I think they are non-explosive?
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#59 | |
The fact that proves this is if you wait until 5000 or even 6000 with a full charge and go wot you get the same boost pressure. The voltage drop that you see on the readout doesn't effect boost pressure unless it goes down to the shut off level (18v) I thought the same initially as well, but after many tests it was plain to see that boost pressure created is directly proportional to the engines efficiency at a given rpm. Sent from my Nexus 10 using Tapatalk 4 |
| The Following 3 Users Say Thank You to fenton For This Useful Post: |
#60 |
Drives: FR-S 10 #103 AT
That funny, really? Have you ever talked to someone who designs headers? They take into account all sorts of variables to do with both what they have to work with and what their goals are. An FI engine is moving more air than a NA one. Pretty much the whole point of the supercharger, isn't it? So it should require changes in the design to account for that, shouldn't it?
I'm not a design expert so my estimation that the factory exhaust with high flow cats would be sufficient with a small blower like the electric may be off, but I don't think it's that far off. And you took two quotes on different topics and said they disagree. Nice job genius.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#61 | |
Drives: 2013 raven black fr-s
There are a lot more variables that go into designing a set of headers, that I would worry about vs. the volumetric flow rate on these cars. There are other restrictions much further down the line that would be more detrimental. Most headers would not break through their volumetric efficiencies, as they are usually not designed to just hit an efficiency point equal to the flow rate of the current engine. |
#62 | |
Drives: VW
Going up a steep mountain pass to demonstrate sustained boost. Pressure vs. rpm is primarily a function a centrifugal compressors fluid map (PR drops with flow @ constant rpm, look up any compressor map). Voltage drop is a function of load. Sustained voltage during boost is a function of energy source discharge curve. The SLA's discharge curve is nearly flat for the 1st 30 seconds after the initial load is applied. One gear boost... not very meaningful. Rob |
| The Following 2 Users Say Thank You to Robftss For This Useful Post: | DAEMANO (09-27-2013), Drift-Office (09-20-2013) |
#63 |
Drives: Ultramarine 86 - 6MT
I don't see the price for the Phantom SC anywhere. What is the price exactly? Also, when will this be available to purchase? I am in California, and this seems like a nice alternative and something I would strongly consider in the near future
#64 |
Supra Senior Member
Drives: AE86 & BRZ
SPAM. JK. Looks interesting. This was a good read. Hope the people develop and finish this.
#65 |
Drives: WR Blue BRZ, 240Z
Should be around $1,500 plus the cost of batteries. The batteries cost me $135 from AtBat.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#66 | |
This car excels at driving extended high rpm twisties. I'm talking >5k for for miles and miles. This seems more likes something for city/highway drivers who need to pass someone or blast up an on ramp. I think an option where it only turns on at WOT would be a great benefit for those who drive in the power band around rural roads. Just turning on when you need torque to get over a hill ? Also just curious why not use LiFePO4 batteries I think they have all the benefits of Li-Ion without the safety concerns?
#67 | |
I can think of two reasons. One is cost. All three SLA batteries cost me $135 shipped. Just one LiFePO4 could cost double that. Tell someone that they have to add $135 of batteries to their car and they don't think twice about it. Tell someone that they have to add $750 of batteries to their car and you'll have to pick them up off the floor. The other reason is the way the SLA's provide current under high load. SLA's don't require any complicated charging solutions and can withstand deep and rapid charge/discharge cycles. LiFePO4 batteries do have a greater charge density, but the SLA's are a VERY cost effective solution.
#68 | ||
| Drift-Office : HKS EL Header Tuned! | Drift-Office | Engine, Exhaust, Transmission | 84 | 05-05-2014 12:34 AM |
| Drift-Office : Borla UEL Header... TUNED. | Drift-Office | Engine, Exhaust, Transmission | 41 | 10-26-2013 11:54 AM |
| Drift-Office : Vortech / HKS EL / Perrin / Greddy Installed & Tuned! | Drift-Office | Forced Induction | 8 | 09-03-2013 06:20 PM |
| Drift-Office : Vortech / Perrin Combo Installed & Tuned! | Drift-Office | Forced Induction | 44 | 08-06-2013 06:37 PM |
| Got my stock BRZ tuned at Drift Office over the weekend... | edocura | Engine, Exhaust, Transmission | 46 | 05-23-2013 08:05 AM |
