Old 09-20-2013, 02:21 AM   #57
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Originally Posted by NoFear99 View Post
If I add this electric supercharger mod on top of that setup do you think I could be looking forward another 20-30 extra WHP like it did to a stock car ?
There is no reason it shouldn't. However anything would just be speculating.
Speculation is correct - it should be reminded that we know from experience that typical performance from I/H/E mods when stacked together, do not equate to the total performance as if they were used independently of each other added together.
If I had to make an educated guess though, I would have to say that you should be able to get the same numbers as you would otherwise, but with better bottom to mid range performance. In other words, the ESC would help (dramatically) on the bottom end but at the top, the dyno chart would look similar to your typical NA set up with a bolt ons, @ WOT. The slight restriction with the minimal boost pressure would probably negate getting much more. This is all conjecture of course.
The exception to that is using E85, and that's going to be more of the same but with the increased ignition timing, you should be able to break into the 200s.
Originally Posted by Element Tuning View Post
Was the drop in HP gains at high rpm a result of voltage drop and therefore less compressor flow?
Heya Phil ~ that would be my guess, but we've apparently been told otherwise within these threads. I guess we'll have to wait and check out the new revisions!
Cheers!
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
Old 09-20-2013, 02:25 AM   #58
regal
Drives: Scion FR-S/Toyota Yaris
Originally Posted by fenton View Post
Trust me Rob is the man when it comes to this. The sad fact is the energy to create 5 psi at redline is 15 to 20 kW if I remember correctly.
Most people think well just turn that motor a couple 10,000 rpm more and your there. Unfortunately all that increases the motor required, controller required, batteries required and so on. Once you get into those wattages you are talking about cooling every component and the list goes on and on.
Can you imagine the batteries required for even a 30 second shot, times what we have now by 5 and your trunk is half full.
Short answer is yes absolutely its possible but you are talking about more money than most of the turbo kits and at that point the costs outweigh the benefits of non parasitic boost.
As tech evolves the price to performance will continue to improve.
I see you said IF you had better technology, which is good, whereas a lot if people just say crank it up. Lol
Sent from my HTC One using Tapatalk 4
IMHO this would be a more attractive kit with modern Lithium batteries. Why not LiFePO4 batteries I think they are non-explosive?
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 09-20-2013, 02:43 AM   #59
fenton
Cheers!
Hey Bob,
The fact that proves this is if you wait until 5000 or even 6000 with a full charge and go wot you get the same boost pressure. The voltage drop that you see on the readout doesn't effect boost pressure unless it goes down to the shut off level (18v)
I thought the same initially as well, but after many tests it was plain to see that boost pressure created is directly proportional to the engines efficiency at a given rpm.
Sent from my Nexus 10 using Tapatalk 4
fenton is offline   Reply With Quote
The Following 3 Users Say Thank You to fenton For This Useful Post:
DAEMANO (09-20-2013), Drift-Office (09-20-2013), raven1231 (09-20-2013)
Old 09-20-2013, 09:05 AM   #60
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by Fast_Freddy View Post
: lol:
You guys aren't exactly in agreement here
That funny, really? Have you ever talked to someone who designs headers? They take into account all sorts of variables to do with both what they have to work with and what their goals are. An FI engine is moving more air than a NA one. Pretty much the whole point of the supercharger, isn't it? So it should require changes in the design to account for that, shouldn't it?
I'm not a design expert so my estimation that the factory exhaust with high flow cats would be sufficient with a small blower like the electric may be off, but I don't think it's that far off.
And you took two quotes on different topics and said they disagree. Nice job genius.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 09-20-2013, 01:07 PM   #61
bakerr6
Drives: 2013 raven black fr-s
There are a lot more variables that go into designing a set of headers, that I would worry about vs. the volumetric flow rate on these cars. There are other restrictions much further down the line that would be more detrimental.
Most headers would not break through their volumetric efficiencies, as they are usually not designed to just hit an efficiency point equal to the flow rate of the current engine.
bakerr6 is offline   Reply With Quote
Old 09-20-2013, 01:37 PM   #62
Robftss
Drives: VW
It sounds like this little ESC is more for short 0-60 bursts than 1/4 mile and that is very weak sauce indeed. How long can this ESC maintain max boost at WOT? 0-60? 0-100? Burnout and 1/4 mile pass?
[ame="http://www.youtube.com/watch?v=xA_Sf4IdrAo"]http://www.youtube.com/watch?v=xA_Sf4IdrAo[/ame]
Going up a steep mountain pass to demonstrate sustained boost.
Pressure vs. rpm is primarily a function a centrifugal compressors fluid map (PR drops with flow @ constant rpm, look up any compressor map).
Voltage drop is a function of load. Sustained voltage during boost is a function of energy source discharge curve. The SLA's discharge curve is nearly flat for the 1st 30 seconds after the initial load is applied.
One gear boost... not very meaningful.
Rob
Robftss is offline   Reply With Quote
The Following 2 Users Say Thank You to Robftss For This Useful Post:
DAEMANO (09-27-2013), Drift-Office (09-20-2013)
Old 10-17-2013, 06:08 PM   #63
forzajuve
Drives: Ultramarine 86 - 6MT
I don't see the price for the Phantom SC anywhere. What is the price exactly? Also, when will this be available to purchase? I am in California, and this seems like a nice alternative and something I would strongly consider in the near future
forzajuve is offline   Reply With Quote
Old 10-24-2013, 10:53 PM   #64
Mr.
Supra Senior Member
Mr.'s Avatar
Drives: AE86 & BRZ
SPAM. JK. Looks interesting. This was a good read. Hope the people develop and finish this.
Build Thread
YouTube Channel
IG - Fwankyhong
Subscribe
Mr. is offline   Reply With Quote
Old 10-25-2013, 08:16 AM   #65
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Originally Posted by retrosmiths View Post
I wonder how much this would cost...
Should be around $1,500 plus the cost of batteries. The batteries cost me $135 from AtBat.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 10-25-2013, 08:43 AM   #66
regal
This car excels at driving extended high rpm twisties. I'm talking >5k for for miles and miles. This seems more likes something for city/highway drivers who need to pass someone or blast up an on ramp.
I think an option where it only turns on at WOT would be a great benefit for those who drive in the power band around rural roads. Just turning on when you need torque to get over a hill ?
Also just curious why not use LiFePO4 batteries I think they have all the benefits of Li-Ion without the safety concerns?
Mods:
Old 10-25-2013, 09:16 AM   #67
Gary in NJ
Gary in NJ's Avatar
It's for anyone that is looking for part-time boost. I typically don't drive at 5000 rpm for extended periods. It's a range I pass through, not sustain. I much prefer the 3-4000 range, relying on boosted power when needed. Still, on-boost at 5000 rpm I still have a 40-50 lb-ft advantage over a NA FA20.
I can think of two reasons. One is cost. All three SLA batteries cost me $135 shipped. Just one LiFePO4 could cost double that. Tell someone that they have to add $135 of batteries to their car and they don't think twice about it. Tell someone that they have to add $750 of batteries to their car and you'll have to pick them up off the floor. The other reason is the way the SLA's provide current under high load. SLA's don't require any complicated charging solutions and can withstand deep and rapid charge/discharge cycles. LiFePO4 batteries do have a greater charge density, but the SLA's are a VERY cost effective solution.
Old 10-25-2013, 09:51 AM   #68
regal
Originally Posted by Gary in NJ View Post
It's for anyone that is looking for part-time boost. I typically don't drive at 5000 rpm for extended periods. It's a range I pass through, not sustain. I much prefer the 3-4000 range, relying on boosted power when needed. Still, on-boost at 5000 rpm I still have a 40-50 lb-ft advantage over a NA FA20..
We probably drive a completely different type of terrain, I drive the engine in the power band for miles.
I have only used LiFePO4 batteries in high end audio applications and they were quite inexpensive, I guess the cost scales exponentially with size. Thanks.
Mods:
Drift-Office : HKS EL Header Tuned! Drift-Office Engine, Exhaust, Transmission 84 05-05-2014 12:34 AM
Drift-Office : Borla UEL Header... TUNED. Drift-Office Engine, Exhaust, Transmission 41 10-26-2013 11:54 AM
Drift-Office : Vortech / HKS EL / Perrin / Greddy Installed & Tuned! Drift-Office Forced Induction 8 09-03-2013 06:20 PM
Drift-Office : Vortech / Perrin Combo Installed & Tuned! Drift-Office Forced Induction 44 08-06-2013 06:37 PM
Got my stock BRZ tuned at Drift Office over the weekend... edocura Engine, Exhaust, Transmission 46 05-23-2013 08:05 AM
