Old 10-24-2013, 08:15 PM   #29
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
Originally Posted by shiv@vishnu View Post
I recommend sticking with Stage 1 if you are running stock headers. Especially on the 91oct we get here in CA. Stage 2 will likely be too aggressive.
Just to make sure.
Even with aftermarket headers, if we're using a catted header it's still best to stick with stage 1 correct? I plan to pick up the FA20 Headers, but I'm not sure what would be best either catted or non-catted. I'm just worried what would happen when smog time comes around what's going to happen.
CamryDS is offline   Reply With Quote
Old 10-24-2013, 09:39 PM   #30
jeebus
Originally Posted by CamryDS View Post
Just to make sure.
smog time in California you are not ok with aftermarket headers, even if they have a cat. So you will have to remove them anyway. That said, buy the catless.
jeebus is offline   Reply With Quote
The Following User Says Thank You to jeebus For This Useful Post:
Shiv@Openflash (10-24-2013)
Old 10-24-2013, 09:45 PM   #31
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
As for the dip, no amount of tuning will get rid of it completely. Certain headers may help move it around a bit but it will always be there to some degree. The only thing that will eliminate it completely is boost (turbo/sc).
Shiv
Im sure this has been discussed before...so what this means is that the dip is caused by hardware instead of software? I'm just curious because if it's "by design" then why did the engineers choose to leave it there because surely they could have done something about it during development/testing? Is there even another new NA car on the market today that has a torque dip as bad as this?
Fizz is offline   Reply With Quote
Old 10-24-2013, 10:32 PM   #32
fstlane
fstlane's Avatar
Drives: BRZ Limited
Originally Posted by Norkoastal View Post
@shiv@vishnu Shiv, when you get a chance can you show us an example of the snorkel mod you are recommending? Thx!
There is some discussion about snorkle mods in the OpenFlash Tablet Tuning Tech thread but it's possibly something similar to this. We'll find out for sure tomorrow.
http://www.ft86club.com/forums/showp...&postcount=453
I'm stock except for OFT stage 2, Borla uel headers, modified snorkle and a Cosworth drop in filter. Driving around today the car ran and sounded AMAZING! I noticed the biggest difference on the highway when I stepped on the gas in 6th to pass and the car pulled strong. No more downshifting with the extra torque in the critical cruising rpm range. Thanks Shiv!
fstlane is offline   Reply With Quote
The Following User Says Thank You to fstlane For This Useful Post:
RC51ed (10-24-2013)
Old 10-24-2013, 11:45 PM   #33
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
READ from first post in this thread▼
- Removed AirRaid intake maps since
1) few people use this particular intake and
2) the stock airbox, with a little work, performs better and provides more stable MAF readings.
By a "little work" I mean a drop in filter and a modified air snorkel.
By modified, I mean shortened and widened for improved airflow.
I'll post a thread about this tomorrow (with DIY info/pics).
Thanks to those who brought this to my attention.
Cheers,
shiv
▲That means 10/25/2013
@shiv@vishnu
On another note, or suggestion.
Shiv you ought to make a new thread with a clean simple layout.
Specifically (a how to) for not so technical features.
Just keep updating the first couple post in it so its all in one place.
If I heard one more...
...How do I turn on/use Launch control , Flat foot, (insert something already explained a lot!)
Its be gone over 20+ times in two threads!
/rant
I know your being nice, and I respect that.
Not trying to be harsh, I'm sure I'll have my share of questions aswell.
On yet another note.
I applaud you for this Tuning system.
I'm watching closely.
Again, to you and your peoples,
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 10-24-2013, 11:58 PM   #34
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
@shiv@vishnu
/rant
Good looking out.. Hard to keep track of each separate OPT thread.. Cant wait to flash 1.3!!
CO>CA Cartel
Norkoastal is offline   Reply With Quote
Old 10-25-2013, 12:28 AM   #35
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
- Formerly missing maps for ZAJA00D ROM type is now included. I was luck enough to snag this elusive 6AT ROM from a new OFT customer at the last NorCal meet!
Could have used this .... yesterday. Got that customer into ECUTEK instead.
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
Old 10-25-2013, 01:30 AM   #36
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Bob I know you make money with your tunes. On the phantom esc tunes are you encrypting them or Allowing them to be open?
Installed Mods:
Old 10-25-2013, 01:36 AM   #37
Unicorn
Drives: GT86
With the stock MAP and MAF limit values (voltage), you'll trigger fault codes if running boost. So raising the values fixes this issue. We raise them to max (5 volts).
Dear shiv@vishnu,
I am familiar with the MAF limit table, but not sure if the MAP equivalent has been discovered yet on the rainbow. If it's voltage based then it's most likely not an issue yet as I'm using a 2.5 bar sensor.
Yours faithfully,
Unicorn
Unicorn is offline   Reply With Quote
Old 10-25-2013, 01:40 AM   #38
Drift-Office
@$300 - $450 for a pro dyno tune that we spend an average of 3-5 hours on? I think you have us mistaken for someone else. All tunes in ECUTEK are encrypted by default... Why? Should I make it open and free to the world?
The Following User Says Thank You to Drift-Office For This Useful Post:
Fast_Freddy (10-25-2013)
Old 10-25-2013, 01:41 AM   #39
Sojhinn
Sojhinn's Avatar
Never hurts to ask.
Installed Mods:
Old 10-25-2013, 01:45 AM   #40
Drift-Office
Never hurts to ask.
Someone famous in the tuning industry once told me... "This isn't UNICEF."
Cheers!
The Following 2 Users Say Thank You to Drift-Office For This Useful Post:
Fast_Freddy (10-25-2013), Sojhinn (10-25-2013)
Old 10-25-2013, 07:58 AM   #41
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Just ordered an OFT!
Old 10-25-2013, 09:13 AM   #42
regal
Drives: Scion FR-S/Toyota Yaris
There is progress. Working on a few feature enhancements in parallel so things are taking a little longer than expected. But when done, it will be fully functional and a bit cooler than originally expected.
@shiv@vishnu
Can you at least share some data-logs? I am most interested in knock that plagues the OEM tune (tip in knock, 3k-3.2k knock) stock vs v1.31 ?
Correct me if I am wrong but your philosophy has been fix the emission hand-caps and oversights from the OEM tune. Make it a reliable better running engine first and foremost over pushing the limit for hp. It reminds me of race teams who develop their own track tunes that don't really add a ton of power but they make the engine hold up long term ?
Also curious if your tunes help with the oiltemps, I remember when the Mustang guys found a tune that reduced oil temps and it was a breakthrough for them.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
anyone trying to use the openflash tablet with forced induction? FRSTEVE Software Tuning 69 12-07-2014 04:07 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
