Old 10-24-2013, 04:11 AM   #1
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Smile Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download
Hi guys,
Happy to announce the public release of our newest OTS maps (v1.31b). The 'b" is for beta but there really shouldn't be anything beta about them. They will retain that designation for another couple of weeks until I confirm that there are no ROM id compatibility errors (always possible when releasing 24 new ROMs at one time!)
They can be downloaded, for free, HERE
Please read the Release Notes that is included in the download folder. It documents the changes in each map release. As well as providing detailed info about the maps themselves. But long story short, here is the gist of it:
- New v1.31 maps (as compared to previous v1.2 maps) are even more knock resistant in the typically troublesome 3000-3200rpm range due to remapped ignition advance/knock correction map. A very worth while update even if you are perfectly happy with the v1.2 maps. Other than that change, performance will be identical.
- Formerly missing maps for ZAJA00D ROM type is now included. I was luck enough to snag this elusive 6AT ROM from a new OFT customer at the last NorCal meet!
- Updated XDFs. They now have parameters for MAP and MAF DTC limits. Adjusting (raising) these values are necessary for turbo/sc applications as I learned last week when doing some mapping work on a Vortech supercharged car. Some other XDF updates as well.
- Removed AirRaid intake maps since 1) few people use this particular intake and 2) the stock airbox, with a little work, performs better and provides more stable MAF readings. By a "little work" I mean a drop in filter and a modified air snorkel. By modified, I mean shortened and widened for improved airflow. I'll post a thread about this tomorrow (with DIY info/pics). Thanks to those who brought this to my attention.
- And of course, our new Stage 2 maps. I'm like a proud father because I think they are really good. As the release notes say, they are only intended for cars equipped with catless headers. If you don't have catless headers, this map will be too aggressive for you car. So please don't bother running it even if you have every other mod available. Compared to our Stage 1 map, the Stage 2 map has leaner AFR, runs more ignition advance, revised VVT maps, new MAF scaling, and other go-fast mapping changes. You can see all the changes yourself by using the Difference Tool in the free-to-use Tuner Pro software (also downloadable from our website). I really hope you enjoy this map because I've been having a great time with it! As with all of our other maps, it is intended only for use with premium fuel (91-93oct). Running on lower grade fuel will definitely castrate performance.
Below are some dyno results comparing Stg2, Stg1 and the stock tune on the same car, same day, same dyno, same fuel, just minutes apart. They car is a 6MT FR-S equipped with only an EL catless header, running on 91oct. Stock airbox, overpipe, exhaust, etc,. This is a Mustang Dyno. It's a low reading heart-breaker of a dyno and has not be calibrated to read high like a Dynojet. For reference, the test car put down 152whp when it was completely stock. So its best to look on at a relative differences, not absolute numbers
OFT Stage 2 tune vs Stock tune on same car (headers only)
OFT Stage 2 tune vs OFT Stage 1 tune on same car (headers only)
So if anyone has any issues with loading the maps into their OFT (ie, ROM compatibility or such), please let me know and I'll fix it right away. Same goes for any unlikely check engine lights. If you do get any CELs, jut read the code with the ECU fault code reading function in the OpenFlash Tablet. It's unlikely but hey, anything is possible
Also, we are working on international ROM support. So over the next few days, I should have support for some of you folks overseas. Thank you for sending me your stock ROM and for your patience!
And lastly, despite ramping up OpenFlash Tablet production we are running low on stock. So if you would like one, best to order (see link in sig) sooner than later. Once we are out of stock, we won't more for another ~2 weeks.
Cheers,
shiv
Shiv@Openflash is offline   Reply With Quote
The Following 23 Users Say Thank You to Shiv@Openflash For This Useful Post:
3essess (10-24-2013), 8686 (10-24-2013), akyp (10-24-2013), Anthony (10-24-2013), CamryDS (10-24-2013), cjsporl (10-24-2013), Cross (11-08-2013), fstlane (10-24-2013), garfull (10-24-2013), JakeFromStateFarm (10-24-2013), JPxM0Dz (10-24-2013), mwjcyber (10-24-2013), NorCal_Guy (11-07-2013), overlookedx (10-24-2013), Pooverdam (11-09-2013), RC51ed (10-24-2013), RehabJeff86 (10-31-2013), Rockstar Lifestyle (10-24-2013), SloS14 (10-24-2013), tonylop33 (10-24-2013), Trigonx (10-24-2013), Wepeel (10-24-2013), YMAA (10-24-2013)
Old 10-24-2013, 10:13 AM   #2
8686
8686's Avatar
Drives: 86
Finally STG 2
Thank you @shiv@vishnu
STG 3 should be Headers + full exhaust
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
The Following User Says Thank You to 8686 For This Useful Post:
Old 10-24-2013, 10:34 AM   #3
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
Looks good, I always prefer *real* mustang dyno numbers to the inflated numbers dynojet spits out.
Cant wait for logging capability
SpeedyJay is offline   Reply With Quote
The Following User Says Thank You to SpeedyJay For This Useful Post:
Shiv@Openflash (10-24-2013)
Old 10-24-2013, 11:12 AM   #4
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
stage 2 yesssssssssssss!!!!!!! you said before it is tuned for full exhaust right?
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 10-24-2013, 11:14 AM   #5
cnk
Drives: '13 DGM BRZ Limited
@shiv@vishnu - Which xdf file is for manual and which is for auto? Up until your 1.2 release notes, you seem to be using ZA1J__C for manual and ZA1J__D for auto. But in your 1.3 release note, it is now referencing ZA1J__C for the auto? Is that a typo?
The Following User Says Thank You to cnk For This Useful Post:
Old 10-24-2013, 11:15 AM   #6
Unicorn
Drives: GT86
Dear shiv@vishnu,
Could you please tell us more about the MAP limit tables. What problems did you encounter when calibrating the Vortech-equipped vehicle?
Yours faithfully,
Unicorn
Unicorn is offline   Reply With Quote
Old 10-24-2013, 11:59 AM   #7
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Thanks for this! I love how you explain each map and what's been updated
In the process of modifying my own snorkel, look forward to seeing how yours is done
2URGSE
JPxM0Dz is offline   Reply With Quote
The Following User Says Thank You to JPxM0Dz For This Useful Post:
Old 10-24-2013, 12:02 PM   #8
overlookedx
overlookedx's Avatar
Drives: 2015 WRB Limited
Awesome! This is the reason I got the OFT this weekend, so I can finally have a tune with my header! Almost got the Stage 2 beta map this weekend from Shiv, was a little bummed when I only got Stage 1, but now that this is released it doesn't matter. Looking forward to flashing it after work today and noticing any differences on the way home.
Superfast Jellyfish
overlookedx is offline   Reply With Quote
The Following 2 Users Say Thank You to overlookedx For This Useful Post:
AyJay (10-25-2013), Shiv@Openflash (10-24-2013)
Old 10-24-2013, 12:46 PM   #9
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by 8686 View Post
Finally STG 2
The Stage 2 map is suitable for a car with headers and full exhaust. Headers are the only requirement but nothing wrong with additional exhaust mods on top of that.
Old 10-24-2013, 12:47 PM   #10
Shiv@Openflash
Drives: 2013 FRS
Sorry if I said that in the release notes, it's a typo. D is for usdm 6at. C is for usdm 6mt like before
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
cnk (10-24-2013)
Old 10-24-2013, 12:50 PM   #11
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by Unicorn View Post
Dear shiv@vishnu,
Yours faithfully,
Unicorn
With the stock MAP and MAF limit values (voltage), you'll trigger fault codes if running boost. So raising the values fixes this issue. We raise them to max (5 volts).
Old 10-24-2013, 01:29 PM   #12
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
What is the progress on the logging feature?
glorydays is offline   Reply With Quote
Old 10-24-2013, 01:31 PM   #13
Shiv@Openflash
Drives: 2013 FRS
There is progress. Working on a few feature enhancements in parallel so things are taking a little longer than expected. But when done, it will be fully functional and a bit cooler than originally expected.
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
flippy (08-13-2014), glorydays (10-24-2013)
Old 10-24-2013, 02:16 PM   #14
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
Any plans on making a stg 2 for catted aftermarket headers?
CamryDS is offline   Reply With Quote
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 05:48 AM
anyone trying to use the openflash tablet with forced induction? FRSTEVE Software Tuning 69 12-07-2014 05:07 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 11:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
