Old 10-22-2013, 02:19 PM   #15
TRD_07
TRD_07's Avatar
Drives: Firestorm 6MT
Not sure if you were only interested in Vortech or twin screw applications but KW will eventually offer a stage II which should place you within the numbers you're looking for.
TRD_07 is offline   Reply With Quote
Old 10-22-2013, 04:44 PM   #16
Sonolin
Honestly if I were to do this, I wouldn't go with any of the current out of the box kits being offered. There's also the c38 rotrex (Kraftwerks says they have an upgrade path for this) which is a bigger unit than in the Jackson & KW kits. There's also an upgraded sprintex blower if you're looking for innovate route. And, there's the Vortech oil fed unit which is said to also have a higher redline.
There are Vortechs pushing 350-380whp on e85 (@charged86) but to my knowledge they are also all overspinning the blower which is likely to reduce its lifespan. If you're looking for reliably doing 400hp with a supercharger I'd go with an upgraded blower for this reason mainly. Also proper cams + higher redline (if possible) I would think would both greatly increase performance of a centrifugal.
I'd also love to see your build in action . A S/C 400whp FRS would be killer. And I don't think its necessary to go turbo you just need a bigger blower.
Sonolin is offline   Reply With Quote
The Following User Says Thank You to Sonolin For This Useful Post:
Ruckus (10-22-2013)
Old 10-22-2013, 04:47 PM   #17
Sonolin
Competely irrelevant to the thread. All that video shows is how bad Crawford is at tuning and that they have blown a motor up already. It is definitely possible to hit 400 whp with a supercharger and E85, and I don't think you need a built motor to do it either.
I thought it ridiculous how Matt was also still getting driving problems with the car. Really? If a customer puts that much money into their car I would be pissed if I was getting driving problems like he was explaining.
Old 10-22-2013, 04:50 PM   #18
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Ruckus View Post
don't think it will be able to hold up? I was curious about that also... seeing that it's the only twin screw for are car right now. I guess it makes sense. More moving parts means more places for catastrophic failure.
It's more the size of the blower itself that is the limiting factor. It just can't breathe enough to support 400whp. I think the 300whp area will be close to the max you will see from the Innovate kit with the stock blower. Sprintex does make a larger blower that will bolt on to the manifold, but may or may not fit in the engine bay with the stock hood.
Old 10-22-2013, 06:55 PM   #19
Ruckus
Ruckus's Avatar
Drives: Firestorm FR-S
Thanks Ill do some more research!
Hopefully in the next month Ill be makeing some more purchases.
Ruckus is offline   Reply With Quote
Old 10-22-2013, 07:27 PM   #20
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
If you want S/C for the sound your not going to find the whine one any non-root style blower. Pretty sure nobody has hit even 300whp with the innovate kit yet. (Probably wrong)
Old 10-23-2013, 09:25 AM   #21
cantholdanymore
cantholdanymore's Avatar
Drives: FR-S Very Hot Lava
Why Crawford gets no love in this forum?
cantholdanymore is offline   Reply With Quote
Old 10-23-2013, 09:39 AM   #22
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Because a turbo kit is not a supercharger?
Sellout is offline   Reply With Quote
Old 10-23-2013, 10:20 AM   #23
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Because I haven't seen a single member on here purchase the kit or show the dyno results or a build thread.
cantholdanymore (10-23-2013)
Old 10-23-2013, 11:07 AM   #24
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
They aren't even selling their turbo kit yet either...
http://www.crawfordperformance.com/c...3-brzfrsgt-86/
And correct me if I'm wrong but most of their kit seems to be based on their low compression build/parts. A step most of us don't want to do until the stock block gives.
The Following User Says Thank You to Kiske For This Useful Post:
Old 10-23-2013, 02:34 PM   #25
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Looks like they have delivered 4 so far:
https://www.facebook.com/photo.php?f...020&type=1
In another post dated October 3, they said they're on the final leg of making 10 kits.
I think the full build is overpriced and the old videos showed what looked like a poorly tuned car. I think Crawford wasn't tuning it themselves. That being said, they also make some great stuff.
Old 10-23-2013, 02:46 PM   #26
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Only thing that got my attention from crawford was that they are selling a complete long block ( Built ) for about 7 grand which is think is not bad
Old 10-23-2013, 06:09 PM   #27
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Down there page they have another picture of the car. @APRil 28th.
"Crawford Street Edition FRS #001 leaving the building! — in Oceanside, CA."
comments section they posted:
"The tire size is 245 and 265, wheels are 8.5 and 9.5, zero engine mods, Crawford AOS, K&N air filter, lowering springs, front and rear sway bars, Crawford Gymkhana axle back exhaust, graphics package and serialized billet Crawford Edition badge."
followed by...
"Thanks Walter... time will tell how the rest of the world reacts to our Crawford spec cars"
Old 10-23-2013, 06:52 PM   #28
nelsmar
Originally Posted by reyruiz191 View Post
http://www.ft86club.com/forums/showthread.php?t=34171
There's also someone else who recently hit 360whp with the Vortech on e85 as well, that dyno and more info is in the Vortech questions thread.
The 360WHP was me. And I did this with a factory exhaust, factory header, factory cat, and a slight pulley upgrade. I am not even running the smallest pulley i can. I still have another step up before i hit the limitation of my self oil-fed supercahrger. Vortech does however have a "race kit" that uses external oil supply that can spin at a 20-25% RPM.
While I said you could get there with a supercharger. The Innovate kit with the blower it comes with is not one of those that will be able to do it.
^ This. Go with Vortech or KW. Both of these kits have "upgrades" that are direct bolt on to large blowers. The vortech is an oil fed unit that can rev higher. The KW is a larger rotrex unit that has a fairly high flow rate.
I'm excited to hear that people have made over 300 with the vortech kit. I've completely missed those threads. I did see the one with the hks blower a few months ago that someone linked here.
^this again. There are at least 2 vendors that tried to make power but were unable to produce more power after a certain point. The twin screw efficiency range is not like a turbo or the centrif superchargers. It just falls off at a certain point and over-reving will only get you so much. Which is quite unfortunate because damn... those inovate are a lot of fun! But even with their fun they have their own issues.
I am not over spinning my blower. IIRC i am spinning at roughly 40-42k and the bearing setup is rated for 50k.
If i were to put a full exhaust, high flow cat, and a proper header to rid of that wonderful cat up front and put on a 3.00" pulley with a stock redline... I am fairly certain I would be in the 400's. However keep in mind this is on E85, not pump gas.
You haven't seen my thread as I have kept quite while testing things. I had fair number of issues while testing my setup and making changes over the months. However all the manufactures I have worked with have all made changes and resolved the issues. I am switching back to pump gas for further testing here soon and once I am finished and finish with all of my dynos comparing boost levels, fuel types etc I will be posting my experiences & dynos with my car and other FI setups I have driven.
My flickr - Canibeat
Local magazine scout
The Following 4 Users Say Thank You to nelsmar For This Useful Post:
cjsporl (11-15-2013), RedAlert (10-30-2013), Ruckus (10-24-2013), Sonolin (10-28-2013)
Who has a built motor? Fabron757 Forced Induction 77 11-19-2020 10:04 PM
Fully built engine with big turbo in dubai TARGET 550WHP SUB-ZERO Forced Induction 84 12-01-2014 12:34 AM
Frs300 Fa20club built motor and turbo build Frs300 Member's Car Journals 32 01-18-2014 05:27 AM
Crawford Limited Turbo BRZ - built motor Mrqb22 Forced Induction 8 11-11-2013 01:34 PM
What is the best turbo for a fully built engine scion frs SUB-ZERO Forced Induction 41 09-18-2013 06:41 PM
