Old 10-21-2013, 08:55 PM   #15
utekineir
blowhard
Drives: frs, project forester
IMHO, it is only noticeable in 6th gear, 30 mph and putting load on the engine. Aside from that, I don't notice much.
so.... a majority of the time for anyone dding?
utekineir is offline   Reply With Quote
Old 10-21-2013, 09:43 PM   #16
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Do you really spend a lot of time in 6th gear going over 50% throttle?
6th gear is usually reached at 45+ mph and at that point its extremely minimum.
Old 10-21-2013, 09:46 PM   #17
utekineir
blowhard
just read like 6th gear to me, not 6th gear and high load
my bad
Old 10-21-2013, 09:52 PM   #18
Sportsguy83
Drives: Limited BRZ
my bad
No problem, my explanation might have been incomplete. Its only at around 30 mph. Anything 40+ its barely noticeable and once up and running (around 50+) its ok. I am not saying they are equal to stock or anything like that, but its really a small increase in NVH.
Old 10-22-2013, 07:46 AM   #19
Calum
That Guy
Drives: 2013 asphalt FRS MT
How did you even find that? Oh wait, you have torque...
Thanks man.
Old 10-22-2013, 07:50 AM   #20
Sportsguy83
Drives: Limited BRZ
Thanks man.
Old 10-23-2013, 03:11 PM   #21
Taber
Drives: 2013 BRZ Limited
Anyone running the Cusco mounts? Feedback?
Taber is offline   Reply With Quote
Old 10-23-2013, 06:23 PM   #22
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
We run the Cusco mounts on our shop car here and we love them. Yes, they are very very stiff. I would not recommend them if you value comfort, or if this is your daily driver. Now the good thing about them being so stiff is that the response from the engine is immediate as you no longer have any soft mounts soaking up the movement.
You can check out my thread on the cusco engine mounts and rear diff brace here.
http://www.ft86club.com/forums/showthread.php?t=30313
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 10-23-2013, 06:33 PM   #23
grostoine
Drives: Subaru BRZ
Thanks! I allready saw your video on the cusco engine mount!! This is realy interesting!
grostoine is offline   Reply With Quote
Old 10-23-2013, 06:53 PM   #24
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
Avo has engine mounts and transmission mounts.
DesertFrs is offline   Reply With Quote
Old 10-24-2013, 01:37 PM   #25
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
http://www.avoturboworld.com/avoshop...nts-p-219.html
http://www.avoturboworld.com/avoshop...unt-p-218.html
Anyone want to try these or own it and want to do a review?
EvilBeaverFace is offline   Reply With Quote
Old 10-24-2013, 02:43 PM   #26
Dodzilla
Drives: 2013 Subaru BRZ
Those are the STI engine and transmission mounts on avoturboworld.
Dodzilla is offline   Reply With Quote
Old 10-24-2013, 04:04 PM   #27
EvilBeaverFace
Didn't catch that before I posted though it is a little confusing since they don't say anywhere that they're the STI version. I was just going off what the other guy said and since they were the only ones listed on AVO's site.
Thanks for letting us know.
Old 10-24-2013, 04:56 PM   #28
Stevo22
Stevo22's Avatar
Drives: GR86
Originally Posted by ATL BRZ View Post
Looking into a pair myself. How were your install experiences guys? I've heard they can be a huge PITA.
Did you leave the header on or take it off when installing them?
Here is a bulleted guide from @mrk1. Engine Mount Install
Stevo22 is offline   Reply With Quote
Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic ecko04 Electronics | Audio | NAV | Infotainment 10 05-05-2018 03:47 PM
What will happen to the aftermarket for this car after the engine bump? enjoi23 Scion FR-S / Toyota 86 GT86 General Forum 19 10-13-2013 02:08 AM
*Raceseng Tow Hook w/ Go Pro Mount Built In Front/Rear Mount -fteightysix* 86SPEED Exterior Parts - The Rest 2 08-20-2013 01:37 AM
DIY: Making a GoPro camera mount with a GrimmSpeed front plate mount PMok DIY (Do-It-Yourself) Guides 2 06-11-2013 10:58 AM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
