Old 10-21-2013, 11:34 AM   #15
jamesm
Originally Posted by vgi View Post
What fluid did you go with?
motul gear 300. havent put it in yet though.
The Following User Says Thank You to jamesm For This Useful Post:
vgi (10-21-2013)
Old 10-21-2013, 12:03 PM   #16
vgi
Drives: frs
was thinking if the fluid helped the new feeling
vgi is offline   Reply With Quote
Old 10-21-2013, 12:11 PM   #17
jamesm
no i havent added it yet... going to do that when i get some more free time. all that's been done so far are the springs.
Old 10-21-2013, 03:02 PM   #18
zooki
Drives: waiting on a 2021...
I've already got the Kartboy shifter, Perrin rear shifter bushing, Kartboy transmission mount insert, and Pentosin in the trans. Hopefully this will make it even better. Just ordered, so maybe by next week I'll have them installed.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 10-21-2013, 05:15 PM   #19
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
For those worried about fluids, theres a plethora of info and benefits on this forum, using either Motul 300, or personally coming from the BMW market, Pentozin MTF2.
I've got the MTF2 in and now the only noises from my tranny is the thud from shifting into gear at a stop. No gear chatter (over the sounds of my headerback) and its smooth as butter to shift (this was before I installed the mtec springs). Hope any of this helps, if not, check out the technical topics on fluids.
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
Old 10-30-2013, 12:29 AM   #20
zooki
OK, I installed the MTEC springs. As a recap, I have the Kartboy shifter, Kartboy trams mount insert, Perrin rear shifter bushing, and Pentosin MTF2 fluid. The springs are definitely worth the $30 or so dollars. They tightened up the 2-3 & 4-5 shifts. Shifting feels like a well oiled bolt action rifle now. Kind of a pain to get to, even on a lift, and it takes a bit of force to break the Loctite loose. Impossible to get a torque wrench on the drivers side, at least it was for me. The passenger's side was accessible with a 1/2-3/8 adapter on a 1 1/16 socket and a universal joint. All in all, much recommended.
The Following User Says Thank You to zooki For This Useful Post:
Anthony (10-30-2013)
Old 04-26-2014, 02:23 PM   #21
johnnyfast11
Drives: none yet
I installed the springs after all the possible trans upgrade you could think of. The springs are a good product.
johnnyfast11 is offline   Reply With Quote
Old 05-10-2014, 06:21 PM   #22
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Holy crap... Did anyone have a ton of trouble getting the Detent (passenger side) back in?
I - Cannot - for the life of me - get that bitch threaded and back in. I see no way to get force on the spring to let the threads catch.
Any advice? Driving me nuts.
Also - i'm just working on the garage floor, car on jacks. No lift for me.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 05-10-2014, 06:24 PM   #23
gramicci101
Off Topic
I used a rag and isopropyl alcohol to clean the threads off a bit before I tried to put it back in. After that it threaded and went in with no problems.
Old 05-10-2014, 06:27 PM   #24
Gopherboy6956
Did you leave the exhaust on when you did the install? It is SO in the way - can get no force lol.
Old 05-10-2014, 07:03 PM   #25
Model Citizen
Lacking brains
Drives: frz
Did it with a 3" front pipe in place, only issue was the locative in 27mm bolt hole.
After struggling in my back for an hour with rags, steel wool, cleaner, etc. Eventually took a right angle pick and scraped out enough loctite to make it work.
Till that point I was ready to smash everything in the garage with the fury of 10,000 suns.
Model Citizen is offline   Reply With Quote
Old 05-10-2014, 07:07 PM   #26
gramicci101
Off Topic
I left the exhaust on for mine and it worked just fine. The order of parts went: 27mm socket, 1/2" u-joint, 1/2"-3/8" adapter, 2 3/8"x6" extensions, torque wrench. You have to put the socket and small pieces on first, then feed the extensions in on the passenger side of the exhaust pipe. It was easy and it got the torque wrench and ratchet down below the car where I could turn them.
Old 05-10-2014, 08:34 PM   #27
Gopherboy6956
lol. I ended up taking off the front pipe and using a small flathead to scrape out the crap. Then i finally got a good enough angle to clean more out and get er screwed in.
This was my afternoon. Sad.
Old 05-10-2014, 10:01 PM   #28
xwd
I would always just take off the front pipe, it takes about 30 seconds and opens things up quite a bit.
>>>FT-86 SpeedFactory<<< Kartboy Short Throw Shifter Kits and MTEC Springs FT-86 SpeedFactory Transmission and Driveline 267 12-11-2016 09:20 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
shifter issue? abutterman Issues | Warranty | Recalls / TSB 54 02-26-2014 05:10 PM
Need help fast - suspension issue during spring install finch1750 Scion FR-S / Toyota 86 GT86 General Forum 5 07-08-2013 03:30 PM
MTec Industries Shifter Springs xravexboix Transmission and Driveline 2 04-24-2013 12:39 PM
