Old 08-28-2013, 10:13 PM   #57
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by mike the snake View Post
Do the subframe bushings move that much? In the under-car vid I watched, I could see the diff itself moving a BUNCH, but I couldn't see the subframe bushings move at all.
I know on my BMW 135i, it made a Huge difference, and was the first thing anyone did when improving the suspension. The 135i subframe moved over an inch with stock bushings, but the BRZ/FRS subframe I couldn't see it moving at all.
Take another look at the video. The subframe moves, it's no where near as much as the diff, but it does move.
Old 09-24-2013, 09:21 AM   #58
Trackspeed_Nick
Drives: Scion FR-S, MK1 MR2
Not to bring up an old thread but there hasn’t seemed to be any sort of root cause of this issue.
I’m on a stock setup and like many it will hop like crazy in the damp with a spirited start. Watching that video on the first page it looked like the diff bushings were a major culprit in the play though someone in this thread said they replaced them and the subframe bushings to no avail.
I’d like to fix this issue but rather not just keep throwing different bushings under it and hoping for the best. I’m hoping it’s not a “sum of the parts” fix to this and it can be pointed to one flawed part.
Does anyone have any success stories in fixing this issue other than “moar throttle”? lol
Trackspeed_Nick is offline   Reply With Quote
Old 09-24-2013, 10:56 AM   #59
Calum
That Guy
I fear it will be a sum of the parts issue. You're trying to prevent the cyle of deflection, bind, unbind, deflect again. The only way your going to do that is to ensure everything will move to a point and then stay set, which to the best of my knowledge will require bushings with less movement then stock.
Old 09-24-2013, 11:01 AM   #60
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
damp spirited start and you don't want to use moar throttle?
the only wheelhop i've experienced was in my FWD car... never once did i have it in my FRS, damp or no damp. Not sure what i'm doing differently?
Old 09-24-2013, 03:51 PM   #61
troek
troek's Avatar
Drives: 2012 Toyota 86
yeah no wheel hop for me either. have you guys tried not letting the wheels hop as much? that's what I do.
troek is offline   Reply With Quote
Old 09-24-2013, 04:00 PM   #62
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Brilliant. Don't let the wheels hop as much to prevent wheel hop.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
The Following User Says Thank You to Tansey86 For This Useful Post:
troek (09-25-2013)
Old 09-24-2013, 04:36 PM   #63
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
You are all complaining about the FRS' wheel hop? Go drive a 1990's mustang. Wheels jumped up an down so hard under loaded cornering that my door came ajar.
Old 09-24-2013, 05:44 PM   #64
Dipstik-sportech
Dipstik-sportech's Avatar
Yes but that's a 90's ford with a solid axle. These cars do hop, I can watch my shifter move 3" and can feel the back end going all skittish. If I launch control in second it will just roast the tires, no hop. I wonder if first gear is just too low to allow adequate wheel speed to over come the hop.
Old 10-20-2013, 03:18 PM   #65
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
I went to the drag strip for the first time with this car yesterday. Violent wheel hop and traction problems.
Current setup
1. 245/40 Hankook tires - 20psi
2. Fortune coilovers set middle damping setting
3. Whiteline transmission mount insert
4. Whiteline subframe bushings
5. Traction/VSC turned off by holding both buttons down
6. 295whp
Over the winter we want to build the motor and bring the power up to about 4-450 and do some drag radials to help with traction.
For this wheel hop problem I am going to try Cusco motor mounts (which makes a big difference on STI), Whiteline diff bushings. Not really sure where to go from there.
Anyone solve this issue yet?
No Limit Motorsport is offline   Reply With Quote
Old 10-20-2013, 09:20 PM   #66
Kostamojen
Hmm... what swaybars are people running while having thr wheel hop?
Old 10-21-2013, 05:37 AM   #67
Dipstik-sportech
18mm hotchkiss, I'm going to try unhooking it at the track next year.
Old 10-21-2013, 09:23 AM   #68
DougW
Drives: FR-S stock for now
Anybody tried a non torsen diff and still had the chatter?
DougW
DougW is offline   Reply With Quote
Old 10-21-2013, 09:55 AM   #69
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
I think the best way to start is the subframe bushing and differential bushing.
But it's so difficult to fixe the wheel up completly with indenpendant suspension setup this car have.
My friend on a 350z fixe a lot of wheel up with installing differentiel alluminum bushing.
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 10-21-2013, 10:36 AM   #70
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
I get this with damp roads, summer tires or winter tires doesn't matter. Watching the shifter rattle violently...is disconcerting.
Oh man, I know this specific post is ancient but I finally got around to reading this thread. The shifter thing really had me worried. I was going to ask on the forum but I was afraid of the answer. Glad to know that it is from the wheel hop in the damp.
DylanFRS is offline   Reply With Quote
Wheel Directory: ProDrive GC-012L 18x8.5 +48 MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 05-12-2013 03:55 PM
OK wheel gurus, wheel are here, now for tires FRSGT86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-12-2013 01:36 AM
Wheel Gap & Wheel Size white_knight Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-26-2013 10:01 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
