| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#29 |
Drives: Outback 3.6R, F150, RAV4 hybrid
Have you verified the other 3 wheels are good? Are the bends on the opposite side from where the wheel was hung from?
#30 |
Drives: 2013 Scion FRS
There are two bends, one on the front wheel and the other on the back. I haven't seen the bends because its in the shop but I am tomorrow morning. I am just hoping I can get some sort of discount or money back from this incident. I'll most likely just leave it as it is as long as it doesn't affect performance or look obvious
#31 |
is better than you
Drives: 2013 raven FRS
affect performance? With a stretch like that there is no performance lol. If there are bends on more than 1 wheel, it's most likely the powder coatings fault.
#32 |
Pull my finger...
Drives: Silver Scion Slushbox
That doesn't look like a warp condition to me. That looks like some careless handling at the coater. Like, as in dropped by a mindless shop helper.
#33 |
Drives: 2013 Argento 6mt
Exactly. I can confidently say that your wheel was dropped/ impacted and is bent, not warped. I can also tell you that you might as well get a new wheel because that one is likely beyond repair since it is bent on the outer lip of the wheel. If i was you i would try and make the powder coater eat the cost of the wheel.
#34 |
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
Sorry to see this. I think it might be Karma. When the wheels saw the color they were about to become, they jumped off the table and tried to run away.
#35 | |
Pegasus White
Drives: 86
Driving: Pegasus White Manual GTS 86.
#36 |
u aware?
Drives: it like a turtle.
sucks
you aware OP? |
#37 | |
#38 |
Drives: Scion FR-S
Looks like that was from someone being a little overzealous mounting the tire. I've had it happen to wheels before. I doubt it's from the powder coating.
#39 | |
The shop, however, can easily check the wheel for roundness before mounting the tire. Why didn't the OP inspect upon receipt? Why didn't the shop inspect before sending for paint? Why didn't the shop inspect before installing the tires? These are very minor bends, which are hard to catch. I think the OP is fine to run the wheels as is. Did the shop check the balance of the wheels before tires? I know a lot about powder coating and even more about aluminum casting - OP, send me a PM if you have any specific questions. I also responded to your other thread about this. |
| The Following User Says Thank You to DougNuts For This Useful Post: | DriftEightSix (10-20-2013) |
#40 |
Drives: Daihatsu
At this point I think its almost impossible to hold someone accountable for the bends.. it could of happened during shipping, it could have happened during powder coating, it could of happened during mounting the tires... sucks but you should of taken a look at them when you received the wheels.
| The Following User Says Thank You to JOSI For This Useful Post: | DougNuts (10-20-2013) |
| Tags |
| can we discuss the color?, heat warps stuff, where is super kaz |
| VIP Modular VRC13 Wheels Bent | Admired | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 10-20-2013 12:16 PM |
| Bent Rim | Sir Alex | Mid-Atlantic | 5 | 08-09-2013 03:34 PM |
| Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! | stratodyne | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 07-17-2013 02:21 PM |
| 17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? | SteveH | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 02-14-2013 10:26 PM |
| Wheels, Wheels, Wheels | Island Import Performance | IslandImportPerformance | Wheels and Tires | 4 | 07-31-2012 10:08 PM |
