Old 02-05-2012, 10:53 PM   #1
ahausheer
Re-member
Drives: Toyota camry
Replace stock hubs with different bolt patern ones?
Is it possible to press out the hub and replace it (along with the bearings that you just destroyed pressing out the hub) with a new one with a different bolt pattern? Say if you want rims that are only available with a different bolt pattern?
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 02-06-2012, 04:21 AM   #2
Infernal
NO FI?! (╯°□°)╯︵ ┻━┻
Infernal's Avatar
Drives: BMW e92 330D
greddy did it with their test car - they took current gen wrx hubs i beleive? for the 114x5 spacing
Infernal is offline   Reply With Quote
Old 02-06-2012, 05:09 AM   #3
old greg
Rocket Surgeon
Drives: PSM GGA OMG
WRX's have always been 5x100, only the STI has 5x114.3.
old greg is offline   Reply With Quote
Old 02-06-2012, 07:04 AM   #4
Infernal
Infernal's Avatar
ah okay - i forget that more wrx's than the uk, we only get the wrx sti so normally we just refer to the "wrx sti" as a "wrx" :P
Old 02-06-2012, 07:42 AM   #5
ahausheer
Re-member
I recently replaced a wheel bearing, hub, and axle shaft and it caused me to think you could just change out the hub to one that has the bolt pattern you need.
Old 02-06-2012, 08:08 AM   #6
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
if the diameter of the hub that is pressed in the bearing is identical, and the amount of splines inside the hub is also identical, then technically you can do it.
but usually they will be it 0.1mm off so you can't :/
we won't know until we have these in our hands.
when doing the rs/wrx --> sti converstion people have to also get new axles and diff if they want 5x114 (or get new axles and hubs if they want the 6 speed)
Old 02-06-2012, 09:56 AM   #7
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Wasn't it stated that GReddy used the 04 STi hubs? Or did they just use a conversion kit?
- The Ancient BRZ Sacrament
by Zaku
Old 02-06-2012, 10:23 AM   #8
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
for a 1 off make, greddy could have done anything really..
they could have simply re-drilled the stock hubs and welded in new studs just for the fuck of it :/
Old 02-06-2012, 01:52 PM   #9
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
But they used spacer adapters, they used 04 STI brakes.
There's zero evidence that they used different hubs, but there is visual evidence that the wheels are pushed out farther than they should be, likely due to spacer adapters.
They also had the car for a week, spacer adapters would have accomplished what they wanted with zero effort so they could spend the time on stuff they had to build jigs for like the exhaust.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-06-2012, 10:14 PM   #10
ahausheer
Re-member
So basically it can be done but its a pain in the expensive ass.
Old 02-07-2012, 12:24 AM   #11
ahausheer
Re-member
Originally Posted by ThisGUY View Post
all talk here..
What does that even mean? I'm just trying to learn about cars and have gotten some very useful information in this little thread. Do you have something to contribute?
Bolt Pattern, Wheel Hubs and Studs Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 03-08-2012 02:49 AM
The wheel bolt pattern is... quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 193 02-29-2012 06:04 PM
Estimated HP gains - bolt on mods and reflash? ahausheer Engine, Exhaust, Transmission 207 01-14-2012 06:14 AM
Stock or JZ? Samdajiggaman Engine, Exhaust, Transmission 62 05-25-2011 06:12 PM
Stock suspension adjustability? #87 Scion FR-S / Toyota 86 GT86 General Forum 4 01-02-2010 04:36 PM
