Old 10-13-2013, 12:03 AM   #15
chris x sway
chris x sway's Avatar
Drives: 2014 FR-S in Mayonnaise
I hope we can figure it out. I'm going to order these soon. Any news?
chris x sway is offline   Reply With Quote
Old 10-15-2013, 12:14 PM   #16
NemeGuero
any updates?
NemeGuero is offline   Reply With Quote
Old 10-15-2013, 05:30 PM   #17
stancypants
stancypants's Avatar
Drives: FR-s
put on your favorite song and turn the radio volume to 50 and the noise will be gone I promise
stancypants is offline   Reply With Quote
Old 10-15-2013, 05:33 PM   #18
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
i just tell my self thats what you get for driving a slammed car and suck it up !
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
stancypants (10-16-2013)
Old 10-15-2013, 08:07 PM   #19
PB-GT86
Drives: White GT-86
I have no issue with the noise but would be nice to figure out where its coming from! I will be taking my car in for a wheel alignment tomorrow and will be getting them to inspect the suspension.
PB-GT86 is offline   Reply With Quote
Old 10-17-2013, 07:06 PM   #20
PB-GT86
Drives: White GT-86
Got a wheel alignment yesterday. The guys spent some time looking over the rear section of the car but did not find anything wrong.
Another note is when these vehicles are lowered they produce quite a bit of toe in the rear and front... Alignment is a must!
The Following User Says Thank You to PB-GT86 For This Useful Post:
Byebye (10-17-2013)
Old 10-17-2013, 07:18 PM   #21
Byebye
Byebye's Avatar
End links folks...you need adjustable end links. I have the same issue.
When you lower the car the stock end links are manufactured for stock height. When the car is settled on level ground the connection between the end link and the roll bar should be loose(no pre-load). You should be able to climb under the car and remove the end links with ease.
When you lower the car below stock height the car is sitting lower and loading up the swaybar and end link. The threaded rod of the end link where it attaches to the roll bar is now pointing in a downward position is if the car is going over a bump(suspension goes up over bumps).
Since you've removed the little travel you had the end link bottoms out over bumps and that is the knock you are hearing. The end link can't move down any higher so now the full weight of your car slams on the threaded rod of the end link eventually giving way.
Buy some adjustable end links. Have someone your weight sit in the driver seat and adjust and install the links so that they fit without being pressured in. NO PRELOAD!
Byebye is offline   Reply With Quote
Old 10-18-2013, 12:30 AM   #22
PB-GT86
Drives: White GT-86
When I did the install I left the stock end links in the front and I don't get any knocking. The noise I am getting is coming from the rear.. Would I need adjustable rear end links??
Old 10-18-2013, 12:37 AM   #23
SmsAlSuwaidi
Boosted
wait, you kept the front endlinks stock ?
i talked to a few guys with BC and all whom used the stock endlinks and have no clunking up front, while mine clunks now (using the endlinks provided )
Old 10-18-2013, 01:45 AM   #24
PB-GT86
Drives: White GT-86
Yeah before I went ahead and installed the coilovers I read that some ppl are still running the stock endlinks and the adjustable ones provided wasn't a must... only if you corner balancing your car!
Old 10-21-2013, 08:24 AM   #25
Byebye
Byebye's Avatar
It won't knock if there is no preload on them. The lower you go though you may need to swap them.
Mine clunk in the rear and not in the front.
Old 10-21-2013, 01:13 PM   #26
NemeGuero
I've disconnected my sway bar and still get the clunk. I wouldn't blame it on endlinks.
Try disconnecting yours and see if the noise goes away for you.
Old 03-21-2014, 07:53 PM   #27
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
Any updates here? im getting the clunking noise and tried disconnecting my sway bar. didnt help at all. im getting frustrated. all the bolts are tight. I have checked about 10 times over the past 2 weeks...
IG: @dustin_faulkner
Kuzuri is offline   Reply With Quote
Old 03-23-2014, 08:34 PM   #28
PB-GT86
Drives: White GT-86
I have given up on finding the source of the noise and just dealt with it so far. There has been a few new posts popping up regarding the same issue and no one has found the solution yet.
Is anyone else's dead pedal loose/making noise? KevinR Issues | Warranty | Recalls / TSB 41 01-16-2017 12:33 PM
New rims and tires making a noise Frs32907 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 08-21-2013 03:01 PM
rear brake noise norcal_brz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-19-2013 03:25 PM
Another Coilover noise thread.. 256brz2013 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 07-05-2013 10:49 AM
Ballast Making Noise remorse87 Cosmetic Modification (Interior/Exterior/Lighting) 7 10-24-2012 10:35 PM
