Old 09-21-2013, 03:00 PM   #71
Trac Toy
Trac Toy's Avatar
Originally Posted by Kostamojen View Post
I keep forgetting there is a Forester XT in the garage thats perfect for getting measurements off of, LOL!
Anyway, the oil cooler coolant lines are 1/2"... MUCH larger than the throttle body coolant lines, so those are not an option :/
I need to find out the thread/size of that bolt hole on the water pump that might work for adding an extra coolant nipple thingy to.
Awesome, thanks for looking into that! At least we have a solid answer as to using them or not.
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
Old 09-21-2013, 04:21 PM   #72
Kostamojen
Ok, the cylinder block "plug" which could be used for a nipple fitting is part number 11021AA112 but I don't know the dimensions. I had one ordered just to see. It looks like its from various model years though, so its probably a common thread size.
It also might be the spot used for adding an engine block heater.
Edit: There are TWO plugs, one on the driver side that is small, one on the passenger side that is HUGE.
Old 09-22-2013, 02:47 AM   #73
Kostamojen
Ok, I'm thinking the easiest route is for sure tee-ing off the heater hoses...
So we need a T that looks something like this:
But with the small side at 1/2" for the oil cooler hose and the two larger sides for the heater hoses at 5/8" (or possibly 3/4"?)
The Following User Says Thank You to Kostamojen For This Useful Post:
The Racers Line (09-22-2013)
Old 09-22-2013, 03:18 AM   #74
ft_sjo
Drives: GT86
I may have missed it, but is there a reason you can't just use all the OE stuff including hoses, or at least use the original water pick up points?
Old 09-22-2013, 09:10 AM   #75
wparsons
wparsons's Avatar
I would bet the only reason for that is needing to get all the parts, it looks like quite a lot of the coolant lines are different.
flickr
Old 09-22-2013, 10:19 AM   #76
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I believe at least one of the water pickup points in our engine(vs the dit) is plugged from the factory.
industrial is offline   Reply With Quote
Old 09-22-2013, 12:58 PM   #77
Kostamojen
Two reasons:
1) As mentioned the dit bits don't match up completely.
2) The oem bits are EXPENSIVE! Probably $200 for just the hoses and pipes from the dit not including the oil cooler itself!
Old 09-27-2013, 01:43 PM   #78
regal
Drives: Scion FR-S/Toyota Yaris
OK I got my JY WRX oilcooler and my car back from the shop.
I don't know if think of T-ing off the heater hoses will be consistent because when you turn the heater dial to red most of the coolant will travel thru the heater coil rather than the oil cooler, then with the heater off the oil cooler will get much more flow.
Then again when you need to use the heater you probably don't neeed as much from the oil cooler.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 10-16-2013, 02:25 PM   #79
Kostamojen
So I was looking for some wheel pictures, when I came across the STI concept car from last year.
Note the Forester DIT oil cooler all setup from Subaru already...
CxG (04-25-2016)
Old 10-16-2013, 08:49 PM   #80
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
That is a good eye. I wonder how the coolant lines are routed.
Old 10-17-2013, 02:34 AM   #81
Kostamojen
Probably simular to how the Forester lines are routed.
Old 10-27-2013, 02:08 AM   #82
Kostamojen
Used the Torque app to record my Oil temps during todays drive... Note the 260 degree oil temps at the 11 minute mark!
I'm renewing my interest in this Oil cooler now, my only concern now is how its going to bump my autox class around a lot :|
[ame="https://www.youtube.com/watch?v=xLDftVSI_BA"]Kost In-car Vid 2 - YouTube[/ame]
Old 10-27-2013, 04:20 PM   #83
CARNZ
CHECK ENGINE
Drives: 2004 STi
Just read thru this thread. I have had the same idea to adapt the FXT oil cooler onto my FA20.
Tomorrow at work(I work at a Subie dealer), i'll see if i can bring in one of our in-stock FXTs and look over the coolant line routing to see what all we need to make this happen.
I'll lift up both the BRZ and FXT to try to do some comparisons.
i don't cry about crickets
CARNZ is offline   Reply With Quote
The Following 6 Users Say Thank You to CARNZ For This Useful Post:
akyp (10-27-2013), illmatic (10-27-2013), number1Tango (09-16-2014), R2 (10-27-2013), roddy (10-27-2013), TeamZleep (10-27-2013)
Old 10-27-2013, 08:29 PM   #84
TeamZleep
Drives: 2013 FRS/2011 TDI
I absolutely LOVE this idea over the largely priced aftermarket coolers. I really want to do this.
TeamZleep is offline   Reply With Quote
BRZ wheels on Forester XT sea otter 99 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2017 06:56 PM
Wheel Directory: OEM Subaru Forester STi (2005) 18x7.5 +48 Surok Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 03-24-2015 07:42 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
OEM Forester All Weather floormats Laika Cosmetic Modification (Interior/Exterior/Lighting) 2 01-14-2013 09:19 PM
1998 Forester on BRZ/FRS Rims :) Meeners BRZ Photos, Videos, Wallpapers, Gallery Forum 11 11-23-2012 08:45 PM
