Old 10-13-2013, 03:25 PM   #1
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
How to: CANADIAN Avic X9310BT - Rearview Camera :UPDATED
Hi all,
For all the Canadian BRZ people out there heres a few pictures and notes from my install. (links to all parts at the bottom)
Installation was pretty straight forward:
-remove trunk liner,
-undo plaque bolts,
-measure cam location,
-drill hole, (I used this drill bit to be more precise)
-feed wires thru hole with grommet,
-feed through existing rubber grommet into interior,
-solder on longer section of wires.
-run along body, zip-tying as you go,
-feed into back of headunit,
-wire it all up and done.
...see simple lol
Name:  photo 3 (2).JPG
The purple wire below is what tells the headunit that you're in reverse. It's wrapped in the existing harness, so you will need to strip and then run a jumper to the rear tail light wire in the driver side wheel well.
Name:  photo 1 (2).JPG
The tiny pink wirebelow is the power wire for the reverse lights. It's hidden behind the cover where your hood release is by the pedals. You run the jumper wire from the purple wire to this little guy.
Name:  photo 2 (2).JPG
Wiring:
1. Yellow AV connector (from Camera) went to the Brown connector (from harness).
2. Red +power wire (from Camera) was spliced into a Red wire (from existing harness) to gain the +12VDC, only when the car was on.
3. Black -power wire (from Camera) was attached to one of the grounding bolts on the body of the car, behind the head unit
4. Purple wire (from existing harness) was jumpered to the pink rear light signal wire in (driver side wheel well)
Parts used:
Camera - http://dx.com/p/eagleyes-ec-th1009-1...-dc-12v-195193
Harness - [ame="http://www.amazon.com/Replacement-Assembly-Harness-Pioneer-X9310BT/dp/B0088HRFJG/#productDetails"]Amazon.com: Subaru Replacement RCA Cord Assembly AV Radio Harness for Pioneer Avic X9310BT.: Car Electronics[/ame]
- 20ft of 24 gauge wire for all extensions.
- 1 rubber grommet.
- zip ties
- black tape / crimps / splicers / soldering iron
Let me know if you have any questions.
cheers - Jimmilion.
UPDATE: Well seems the "waterproofing" isn't what it made out to be. The first frost this season proved to much the camera. The lens is frosted over from the inside.... pretty disappointing, but it's still useable.
jimmillion is offline   Reply With Quote
The Following 2 Users Say Thank You to jimmillion For This Useful Post:
djdnz (11-04-2013), SVXdc (04-06-2015)
Old 10-16-2013, 03:20 PM   #2
Bringiton
Bringiton's Avatar
Drives: WRB BRZ
How well does that camera work at night?
Bringiton is offline   Reply With Quote
Old 10-23-2013, 11:36 PM   #3
jimmillion
Power Ranger Elite
jimmillion's Avatar
To be perfectly honest, not great but you can still make things out.
I did a LED conversion for my reverse lights and still not much of an improvement.
I can see everything up to the yellow guide lines (approx 2 feet) but no much after that.
I'll grab you a picture one day.
The Following User Says Thank You to jimmillion For This Useful Post:
Bringiton (10-24-2013)
Old 10-28-2013, 10:27 PM   #4
jimmillion
Power Ranger Elite
jimmillion's Avatar
As promised here they are:
1st) Well lit intersection.
2nd) non lit parking lot, 1/4 moon with overcast, curb at approx. 4.0m(13ft)
3rd) non lit parking lot, 1/4 moon with overcast, curb at approx. 1.5m(5ft)
Bringiton (10-29-2013), djdnz (11-04-2013)
Old 10-29-2013, 09:06 AM   #5
Bringiton
Bringiton's Avatar
Drives: WRB BRZ
Originally Posted by jimmillion View Post
As promised here they are:]
Not the bad for a discount camera.
Thanks.
Old 10-29-2013, 09:42 AM   #6
rip curl
Drives: 13 BRZ
Looks like I have my next project! So how did you route the wires back to the head unit so that they are hidden in the interior?
rip curl is offline   Reply With Quote
Old 10-29-2013, 11:44 AM   #7
rip curl
Drives: 13 BRZ
I think I might have answered my own questions...
I'm guessing this guide was useful for routing the wires: http://www.ft86club.com/forums/showthread.php?t=30144
And I'm thinking of using this camera and mounting it where one of the license plate bolts go (similar to the beat sonic install): http://dx.com/p/e366-compact-vehicle...12v-ntsc-50507
Old 10-31-2013, 08:08 PM   #8
jimmillion
Power Ranger Elite
jimmillion's Avatar
believe it or not I just tucked it all over the panel pieces without removing them. By the door well there's even a channel to run to wires in if you pull off the trim piece.
Protrip: for feeding the wires throught the rubber gromet from the trunk door to the car interior, spray a tiny bit of WD-40 in there and they all slide right thru.
Old 02-24-2015, 11:39 AM   #9
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
what is the yello video out rca input that is shown in this picture
is it possible to connect the camera to that and instead get power from the reverse tail light? do we need the harness that u previously mentioned.
2022 BRZ WRB 6MT
2018 Camaro ZL1 1LE
vignesh is offline   Reply With Quote
Old 02-24-2015, 11:54 AM   #10
jimmillion
Power Ranger Elite
jimmillion's Avatar
I'm not 100% but I'm pretty sure that video out is for a second monitor, like say if you had one for the back seats like they have in mini vans.
What you need is a video "in" so that you can get the image from the camera. Unfornaturely only way to get that is either make or buy the extra harness that has that input.
Old 07-02-2015, 12:40 PM   #11
jtsimaras
Drives: Subaru BRZ, Mazda CX5,
Thanks for the write up I did this today. I added a slight variation to the wiring procedure.
For the Reverse wire I wired it up to a harness behind stereo that is used for stock back up camera, as indicated in picture it is the orange/white wire.
Saves time having to run to footwell. Only compliant I can give about the camera is the angle seems to point down a lot, besides that it is awesome.
Thanks
jtsimaras is offline   Reply With Quote
Old 07-09-2015, 01:58 AM   #12
a_dee
a_dee's Avatar
Drives: '14 BRZ CBS
the camera angle looks like mine, pointed all the way down to the ground and not up so you can actually see behind you. I need to make a wedge shaped shim to angle the camera back up.
'14 BRZ CBS
>>Pretty Stock
a_dee is offline   Reply With Quote
Old 07-10-2015, 10:52 AM   #13
jtsimaras
Agree I bought a different camera on ebay and same result. I'm going to make a plastic wedge from some left over interior panels I have kicking around.
Old 07-10-2015, 12:18 PM   #14
a_dee
a_dee's Avatar
Drives: '14 BRZ CBS
Post a shot when you're done, I think many people would benefit from these hacks.
'14 BRZ CBS
>>Pretty Stock
avic, camera, purple, rear, x9310bt
Rearview camera without drilling holes sav Electronics | Audio | NAV | Infotainment 41 08-16-2014 01:27 AM
Back Camera Install - Pioneer AVIC-X930BT cocoy_labuyo DIY (Do-It-Yourself) Guides 6 10-13-2013 03:26 PM
Canadian BRZ Factory Pioneer AVIC-X9310BT jjkerr626 Electronics | Audio | NAV | Infotainment 2 09-15-2012 01:21 AM
