Old 10-15-2013, 11:38 PM   #1639
DKPJester
DKPJester's Avatar
Drives: 2013 Whiteout FR-S
Originally Posted by Sevs753 View Post
foglights? My foglight switch is in the exact same spot.
Yep! Pretty excited to get mine installed. Don't the BRZs come with fogs?
But once again we must turn to the baby Jesus who once said "He who shall be last, shall be sideways and smiling."
DKPJester is offline   Reply With Quote
Old 10-15-2013, 11:54 PM   #1640
Sevs753
Sevs753's Avatar
Drives: BRZ, Canyon
They're standard on the Limited, optional on the premium. I have the premium but got the foglight option, hence the foglight switch not being in the turn signal stalk like the limited.
Sevs753 is offline   Reply With Quote
Old 10-16-2013, 12:03 AM   #1641
DKPJester
DKPJester's Avatar
So it's there from the factory?
Sent from my SAMSUNG-SGH-I317 using Tapatalk
Old 10-16-2013, 12:26 AM   #1642
Sevs753
Sevs753's Avatar
Drives: BRZ, Canyon
From what I heard from the dealer, it was added "at the port", like other major dealer add-ons. Probably explains why the drivers side foglight doesn't sit right in the socket...
Old 10-16-2013, 06:08 PM   #1643
ramiel
Drives: Red BRZ Limited
Got condensation in the driver's side tail light
Guess I'll have to make a trip up to the dealer to get it replaced.
ramiel is offline   Reply With Quote
Old 10-16-2013, 08:32 PM   #1644
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
I put a bead of silicone around mine when I had them out and they never got condensation. It's a 30 minute job they are really easy to get out and it saves all the time and hassle of trips to the dealership.
Sent from my Q10
Old 10-17-2013, 11:51 AM   #1645
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
The condensation has typically been caused by one of the mounting feet cracking. In my opinion, as long as my car is under warranty I'd prefer to have it replaced with a OE genuine part and hopefully they'll start stocking one with an actual design fix rather than band-aid the leak... my driver side is now leaking very slightly after I had my passenger side one relaced in the spring time.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 10-17-2013, 12:13 PM   #1646
Sevs753
Sevs753's Avatar
Drives: BRZ, Canyon
So i want to focus my mods over the winter to be better suited for AutoX. I want to stay in RTR for now so my mod choices are a bit limited. So far, I'm planning on better tires and wheels to go along with them (225 tires, same spec as stock wheels) and better brake pads.
I'm also thinking about upgrading a sway bar. I don't know much of anything when it comes to sway bars but i know that I can only upgrade one bar if I want to stay in RTR. Any suggestion on what bar to get? I would like to dial out some of the understeer I experienced this year.
Somewhat related, I know the FRS is a bit more tail happy compared to the BRZ. Is that because of the sway bars? I think i would like it if I could get the suspension setup of the FRS.
Old 10-17-2013, 02:55 PM   #1647
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
The sway bars are the same between the frs and brz. The spring rates are different between the two. The frs has a softer front spring and a stiffer rear that causes the oversteer.
kask2_6.0 is offline   Reply With Quote
Old 10-17-2013, 10:20 PM   #1648
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
Road Trips
I've been following the 'Ohio Route 555/26' thread. The group seems to have a successful participation in several road trips per year. Granted, Ohio has some very nice roads throughout the state for making best use of a BRZ relative to what Michigan has with their hills and river routes.
Question: Is there any interest that us Michiganders may have for road trips like those that would take most of a day, for instance??
For example: Circumnavigate the Detroit and/or St. Clair rivers - a Canadian/Michigan trip -Detroit/Windsor/Sarnia/Port Huron/Detroit.
I will plan one if there is at least 4-5 participants.
BRZfan is offline   Reply With Quote
Old 10-17-2013, 10:26 PM   #1649
DKPJester
DKPJester's Avatar
Absolutely. Our best meets are the few where we've gone for a drive. It's a cool feeling rolling out with all the cars
Old 10-18-2013, 11:27 AM   #1650
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Just a reminder, you will be in "C-Street" next season, rather than RTR... as the class changes have been made official.
I'm doing the same.... posted my winter plan on the NWOR site... so I'll copy it here...
Originally Posted by sccabrz192
Already on the koni's with the OE crash bolts....
still need to acquire:
17x7 RPF1's with proper street tires (leaning RS-3)
Strano FSB
indecisive on the brake pad I will run
likely a muffler delete to lose a few lbs.
an alignment
You commented you experience "understeer", what type of surfaces were you running on this year and what tires? I'd suggest this is probably more to do with driving technique and entry speeds than car set up.
Like kask said, the difference is in the spring rates, which is not legal in RTR/Street to swap.
With that said, a stiffer RSB will induce more oversteer. However, fair warning, it's going to be excessive on throttle and in transition... and if you are hard charging entries, it will not prevent the car from understeering on turn-in. A stiffer FSB will tend to push more on throttle and in transition. I feel one of the weak areas of the car is it pendulums too much in transitions, making it very difficult to keep applying power in slaloms. Additional rebound damping in the rear (care of koni dampers) and a moderate increase in FSB rate should clear that up without ruining the rest of the car's balance. I'd recommend going with a FSB that is only slightly stiffer than stock (The Strano bar seems to be a good ticket).
Old 10-18-2013, 11:47 AM   #1651
Sevs753
Sevs753's Avatar
Drives: BRZ, Canyon
Do you have a link to the rules that apply to that class? I can never seem to find a list of what exactly is allowed for each class.
The understeer was mostly when I ran on belle isle. Also, i was on the stock primacy HP tires. Planning on getting a set of Dunlop ZII's for next year. I didn't notice much understeer at the silverdome but I wasn't pushing as hard at the silverdome as I was at belle isle.
So even though the FRS and BRZ are basically the same car, it would still change my class if I just put the FRS springs on my BRZ? I wasn't going to do that but it seems a little weird to me.
Old 10-18-2013, 11:47 AM   #1652
DKPJester
DKPJester's Avatar
Hey @eikond
http://jalopnik.com/nissan-to-show-a...ore-1447701729
Japanese sports car rivalry might be kicking back up. Pony car wars at full tilt. C7 is being called the best sports car America has produced. Alfa back in sports cars. It's a good time to be a car enthusiast.
The Following 2 Users Say Thank You to DKPJester For This Useful Post:
eikond (10-18-2013), racecaresuaceb (11-02-2013)
NorCal (Bay Area) OFF-TOPIC Chat Thread BlaineWasHere Northern California 12912 08-18-2024 05:02 AM
NorCal (Bay Area) DRIVE Chat Thread MyRx Northern California 5559 07-23-2023 03:11 AM
*Chat* Vancouver FR-S/BRZ Members Mumbo Jumbo Thread peazs CANADA 1397 06-28-2019 01:17 PM
Mid-Atlantic Chat Thread clevrname Mid-Atlantic 5296 08-25-2016 02:30 PM
Tri-State Chat Thread Jayde NY / NJ / CT / PA 182 05-22-2014 12:14 PM
