Old 10-14-2013, 09:14 AM   #29
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Originally Posted by Frostyman View Post
No, knock is fuel detonating when it shouldn't be. No aluminum is slamming into other aluminum.
educate yourself before speaking next time.
Engine knocking - Wikipedia, the free encyclopedia
Thanks for the lesson, I was misinformed until I read that.
slicktop is offline   Reply With Quote
Old 10-14-2013, 09:23 AM   #30
Frostyman
Originally Posted by slicktop View Post
Thanks for the lesson, ****head.
You're welcome.
Originally Posted by Don@Accelerated
For the sake of argument I went and cut my factory filter housing up.
Frostyman is offline   Reply With Quote
Old 10-15-2013, 03:44 PM   #31
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I think his tuner is using the Long Term Knock Correction to add in the extra timing for E85. I have never seen a Knock Correction Learn Value that high. What is the IAM on those runs? Does it ever change? I worry that your AFR is off the scale rich for the entire boost pull as well.
Old 10-15-2013, 04:10 PM   #32
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
What is the IAM ? Don't see that in the logs. Are you referring to the multiplier? It's 1 the whole time. Afr is 12.17 whole time as well
gdrider77 is offline   Reply With Quote
Old 10-15-2013, 04:23 PM   #33
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
From what my tuner told me
12.2 is perfect for e85
Maybe @Sportsguy83 can chime in with that
Sent from somewhere
Old 10-15-2013, 04:25 PM   #34
King Tut
NASA SpecE30 Racer
King Tut's Avatar
It isn't 12.2, it is somewhere below that, but the OEM AFR sensor and scaling he is using doesn't allow us to see how low it is going.
Old 10-15-2013, 04:25 PM   #35
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Sent from somewhere
Yeah, everything from 10.5-12.5 is good for E85. Being close to 12.5 in E85 is not a problem at all.
Take with grain of salt, this is what I learned through a lot of reading trying to understand why the AFR gauge reads the same for E85 and pump gas even though their stoich points are different.
Edit: Good point by @King Tut yah he would need to scale the OEM AFR differently to be able to read as low as 11.01
@gdrider77 what does your AFR gauge say (if it is a wideband and not an OBDII reading).
Old 10-15-2013, 04:26 PM   #36
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Ignition Advance Multiplier (IAM). It sounds like your tuner has defeated the knock control strategy if your IAM is always at 1 while seeing knock.
Old 10-15-2013, 04:48 PM   #37
jamesm
Originally Posted by Area86 View Post
Here you go.
here it looks like you're running 20% ltft and it's pushing your open loop afr's below 12:1. something isn't right i would think.
edit: just realized you were FI, so < 12:1 afr is good. still why such high ltft on the high range?
Old 10-15-2013, 05:17 PM   #38
gdrider77
gdrider77's Avatar
Not sure the "1" i mentioned is right. In ECUtek, logs, where is the IAM reading? I dont see that in my logs? I see something that says "advance multiplier" is that it? I Highlighted it in this image....
Old 10-15-2013, 05:22 PM   #39
King Tut
NASA SpecE30 Racer
King Tut's Avatar
It is a parameter that EcuTek added to its logging. I don't remember the exact term for it in EcuTek. I think it is Advance Multiplier or Ignition Multiplier. I believe it gets selected by default, but you might have to click it to have it be logged.
Old 10-15-2013, 05:25 PM   #40
xjohnx
Grip>Slip
xjohnx's Avatar
It's advance multiplier, and yes, it's selected by default.
Old 10-15-2013, 05:27 PM   #41
gdrider77
gdrider77's Avatar
Yes, its a wideband.
I will setup a camera to record, hard to watch that while im driving...i will also pull the logs from the aem failsafe and see what it says.
Old 10-15-2013, 05:33 PM   #42
xjohnx
Grip>Slip
xjohnx's Avatar
Probably just easier to pull the AEM logs than try to record it with a camera. The AEM Failsafe logs should show the last 3 hours worth of AFR, RPM and boost (assuming the wires for the last two were connected)
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
gdrider77 (10-15-2013), Sportsguy83 (10-15-2013)
BC Racing Coilovers - Knock? 636 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 12-09-2015 10:41 PM
FR-S Rod knock pozer Issues | Warranty | Recalls / TSB 95 11-03-2015 09:39 AM
ca-fi knock off questions fionnsfrs Electronics | Audio | NAV | Infotainment 2 10-27-2013 01:47 PM
Active Knock sensor Fat Spider Engine, Exhaust, Transmission 13 07-14-2013 08:37 PM
Would you rather buy knock off parts for your car? EJ20 Engine, Exhaust, Transmission 63 11-02-2011 06:17 PM
