Old 10-09-2013, 01:10 AM   #1849
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Ok last question!!!!!
Please help! about to purchase soon.
Wheels Work Kiwami 18x9.5 +38 Square
Setup 1:
Front 245/35 and Rear 255/35
Setup 2:
Front 245/35 and Rear 265/35
I have 0 front chamber and -2 deg rear chamber
Which one will look better? Thanks
hanabie is offline   Reply With Quote
Old 10-09-2013, 10:04 AM   #1850
RavSpec
Drives: Rx7
Setup 1:
Setup 2:
First one.
RavSpec is offline   Reply With Quote
Old 10-09-2013, 05:38 PM   #1851
Qsig
Qsig's Avatar
Drives: 2013 Subaru BRZ WRB AT
Hey, still trying to wrap my head around wheels and tire diameter, etc.
I'm keeping it at stock height since switching to winter tires and thinking of going with this for summer since I'd like a wider tire:
Wheel: Enkei EDR9 17x8 +38
Would a 235/40/17 tire be too wide or should I stagger 235 in back, 225 in front?
Thanks!
Qsig is offline   Reply With Quote
Old 10-09-2013, 06:11 PM   #1852
hanabie
hanabie's Avatar
Thanks!
No. See the post above you. Same offset but 245 and 9.5
Old 10-10-2013, 04:24 PM   #1853
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
Will it fit in the rear?
VW Turbo OEM wheels
17x7.5
5x100
38 offset
57.1 bore
*just looking at drift spares, lowered 1.5 inch
Ryaquinn is offline   Reply With Quote
Old 10-10-2013, 04:28 PM   #1854
Kostamojen
VW Turbo OEM wheels
17x7.5
5x100
38 offset
57.1 bore
Yes
Old 10-10-2013, 04:29 PM   #1855
RavSpec
Drives: Rx7
VW Turbo OEM wheels
17x7.5
5x100
38 offset
57.1 bore
To answer the question, yes it will fit. But since hub bore size are off by 1.1mm , might cause vibration at high speed if not mounted flush.
But I don't see why you want to go that route .. it's not that much aggressive or better than your OEM wheels.
Old 10-11-2013, 03:13 PM   #1856
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
The ones I'm looking at I guess are the GTi 15 spoke. As I said just to be used as extra drift spares in rear.
Old 10-12-2013, 01:02 AM   #1857
hanabie
hanabie's Avatar
poke difference 245 and 255? big or small diff? thanks
Old 10-12-2013, 05:08 PM   #1858
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
255-245 = 10mm...so that's 5mm to the inside and 5mm to the outside.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
hanabie (10-12-2013)
Old 10-12-2013, 05:11 PM   #1859
hanabie
hanabie's Avatar
I could not imagine how poke they look like. I was actually asking for pictures. hahaha
Old 10-13-2013, 01:02 PM   #1860
hanabie
hanabie's Avatar
My wheel is 18x9.5 with overall with is 10.5". Will there be any chance that a 255 is wider than 10.5" when inflated? Never have experienced measuring them.
Are all wheels designed to have the same overall width? Which is 1" more than the actual width.
Thanks
Old 10-13-2013, 01:32 PM   #1861
Kostamojen
So I've been looking at 18" wheels... Finally found something in the style and price range I was looking for (I was looking at BBS wheels but damn too expensive!)
http://mirowheels.com/portfolio/type-112/
18"x8.5" +35... That offset seems a bit low. I'm running stock suspension and would like to run 245's at least for tread width without rolling the fenders or having rubbing issues. I MIGHT go with a mild drop eventually in a year or so (.5" STI pink springs if anything) but for now just stock height.
Will those fit without rolling or is the offset just too low? I think the rear is ok, not sure about the front.
Old 10-13-2013, 03:42 PM   #1862
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Hey all, please help a tire newb.
I'm ordering one of these two sets. Will I have any issues on stock suspension?
RPF1 (17x7 +42). 225/45/17
RPF1 (17x8 +35). 225/45/17
Thanks!
SpectreRT is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
