Old 10-10-2013, 06:11 AM   #1
deedz
Drives: Rocket Bunny FR-S
Clutch Master FX400 Disengagement issues?
Just picked up a FX400 full face 8 puck clutch for my fr-s and apparently its having disengagement issues. Anyone have any similar experience with this issue? Has trouble with the shifter as well when trying to put it in gears...especially first and second gear and the engagement point is extremely low and sometimes it just dosnt wanna disengage.
Installers said they did everything correctly and brought this problem to my attention before I was even able to try it out and said I should bring it back and replace it.
Figured i'd put it in this section since most people who own the FX400 are boosted
Rocket Bunny Vinyl Wrapped Build Page:
http://www.ft86club.com/forums/showthread.php?t=33573
deedz is offline   Reply With Quote
Old 10-10-2013, 07:48 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Adjust the Clutch pedal to engage higher.
DIY - Easy clutch grab adjustment (~10 mins)
You're welcome..
The Following User Says Thank You to Sportsguy83 For This Useful Post:
deedz (10-10-2013)
Old 10-10-2013, 08:21 AM   #3
Frostyman
Drives: 2013 Raven FRS
no, YOU welcome. lol
Originally Posted by Don@Accelerated
For the sake of argument I went and cut my factory filter housing up.
Frostyman is offline   Reply With Quote
Old 10-10-2013, 08:22 AM   #4
Sportsguy83
Drives: Limited BRZ
All the time
Old 10-10-2013, 10:54 AM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by deedz View Post
Just picked up a FX400 organic clutch for my fr-s and apparently its having disengagement issues. Anyone have any similar experience with this issue? Has trouble with the shifter as well when trying to put it in gears...especially first and second gear and the engagement point is extremely low and sometimes it just dosnt wanna disengage.
Have you previously modified your clutch engaement point for the OEM clutch?
Old 10-10-2013, 11:23 AM   #6
mike the snake
If the clutch disk isn't perfectly flat or is warped, it'll do as you have described.
Old 10-10-2013, 11:27 AM   #7
Dipstik-sportech
Dipstik-sportech's Avatar
Mine did the same thing when I first installed it. I adjusted the pedal and that helped a bit but it's still dragging slightly. I didn't know the fx400 was organic?
Old 10-10-2013, 12:46 PM   #8
Fabron757
Drives: 2013 blue frs m6 BW EFR 7064 Turbo
Had a 2000 celica that had the same problem. It was fixed by adjusting the height it engages and bleeding the clutch. I have 7k miles on my FX400 with no problems so far.
Fabron757 is offline   Reply With Quote
Old 10-10-2013, 01:49 PM   #9
deedz
Have not modified it
Will remove it to see if its warped or anything, thanks!
Oops meant the full face one! So your you can feel the resistance when trying to push the shifter into first and second? Just feels like it's locked out even when clutch is all the way down.
Did you also have trouble putting into first or second gear where there's resistance?
Old 10-10-2013, 03:08 PM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Did they open the hydraulic system in the process of installing the clutch or did they unbolt the clutch slave cylinder from the transmission?
Old 10-10-2013, 05:30 PM   #11
M1K3
M1K3's Avatar
Drives: vrooom...
It's possible it could be the hydraulics like King Tut mentioned if they messed with it (that was my first thought). But if the issue is mainly felt when engaging and disengaging the shifter especially in 1st and 2nd gear, it could simply be an issue with the alignment of the Reverse Lockout Plate.
M1K3 is offline   Reply With Quote
The Following User Says Thank You to M1K3 For This Useful Post:
King Tut (10-11-2013)
Old 10-11-2013, 11:13 AM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Great point. I hadn't thought about that.
M1K3 (10-11-2013)
Old 10-14-2013, 12:36 AM   #13
Frs300
Frs300's Avatar
Drives: Pile of junk
I have same problem with my fx400 I will have to mess with the engagement when I get car back if toni doesn't do it or check lock out plate
Frs300 is offline   Reply With Quote
Old 08-07-2016, 09:16 PM   #14
xxGiXxeRxx
Drives: 2014 FRS
exremely old thread.
But did any of you who have had issues able to resolve it?
I have been debating between ACT HDD 6 puck sprung with Prolite Flywheel and CM FX400.
xxGiXxeRxx is offline   Reply With Quote
Clutch master stage4 anyone Djen Engine, Exhaust, Transmission 24 08-13-2013 05:42 PM
Aftermarket Clutch Master and Slave? Yruyur Engine, Exhaust, Transmission 5 07-27-2013 10:22 AM
FX400 Clutch Kit Djen Engine, Exhaust, Transmission 0 07-16-2013 07:41 PM
Problems with FX400 full-disk clutch after shady install... ***Help?*** Argento_FR-S Engine, Exhaust, Transmission 4 05-29-2013 02:29 AM
Clutch Masters FX400 Review Dustin@Dynosty Engine, Exhaust, Transmission 19 08-29-2012 06:46 PM
