#3193 |
Drives: 2013 Scion FR-S 10 Series
ive got my 10 series for about a month now, with almost 1000 miles on it. I've been putting gas with 10% ethanol (cuz thats all they have here in richmond, VA apparently) but I have not gotten the crickets yet. Is the crickets more the exception than the rule?
#3194 | |
Canadian FR-S Member
Drives: FR-S '10 Series'
Once my first check up comes ill bring it up if they get worse, along with the spot weld ticking/popping that has been getting worse at rear shelf panel. Anyone know if BRZ TSBs work hand in band with Scion? |
#3195 |
No crickets for me, but I have the rear deck pop, and the faux carbon dash has come unglued
#3196 |
#3197 |
Drives: Subaru BRZ Limited
The silver carbon dash is just an overlay?? What's under it? The regular FRS dash?
#3199 |
#3200 |
#3201 |
Drives: 1996 ST204, Series 10 FR-S
At first, it sounded like a knock under 1200 rpm. Now its just crickets coming from the fuel pump. Dam man, Toyota/Subaru needs to get their shit together. They have had more than a year since launch to fix these things. My rear deck hasn't popped yet but it rattles like a mofo.
#3202 |
8SiX
Drives: FRS 10series
My rear deck rattles a bit from the passenger side. I haven't figured out where thats coming from yet. I got the crickets, BUT knock on wood, I had them replace the fuel pump about 600 mi ago and it hasn't come back (mine started at 200 mi, and replaced it around 1200 mi). I've been using 92 E10, because that's what they have here in Hawaii.
#3203 |
Drives: FR-S 10 Series
#3204 | |
Read Decking Popping/Click Has a lot of information on possible means for rattle or popping. If it is audible clicking/tapping that occurs usually after 2000 miles, occurs when rear shelf panel bends/twists over uneven surfaces or bumps it is likely the spotwelding issues. Apparently this is bound to happen on all GT86/FRS/BRZ's made due to spotwelding techniques. There is a Subaru TSB in the link above or it can be found in the TSB section on the forum. Either they punch the welds, get it re-welded, or they follow a technique similar to the thread I will attach below for DIY where you insert grease into the areas to eliminate the popping heard from sheet metal rubbing together. Some dealers have a noise locator which will find exact location of where clicks are coming from. DIY Rear Deck Popping I guess it all depends on if you have warranty and your dealer with do Subaru TSB or if you'd rather remove the rear shelf panel carpet and do it yourself. Half of the spotwelds can be accessed via the trunk. |
| The Following User Says Thank You to FiRStsc10n For This Useful Post: | SurfAndSand (09-19-2013) |
#3205 | |||||
Drives: Scion FRS 10 Series AVO Turbo
Hey guys this just a reference, theirs currently a Group Buy on Facebook for the Silver Ignition Pre-painted by Five Axis them selfs. Let me know if you guys are interested I can provide more information via PM I believe it's 365 shipped Last edited by DesertFrs; 10-09-2013 at 01:56 PM. |
| The Following User Says Thank You to DesertFrs For This Useful Post: | SurfAndSand (10-09-2013) |
#3206 | |
Drives: tezla
i want the TRD spoiler, anyone have a good deal on that painted in SI? |
| Tags |
| 2014, brz, fr-s, gt86 |
| Limited edition WedSports | GH05T | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 02-17-2013 02:03 AM |
| Limited Edition FT86 Oil Cap #127 | phenom86 | Engine, Exhaust, Bolt-Ons | 2 | 12-12-2012 04:30 PM |
| Toyota TRD GT86 Special Edition Announced for UK | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 07-18-2012 11:23 AM |
| Limited Edition Colors? | bambbrose | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 11-30-2011 03:23 PM |
