Old 09-27-2013, 12:17 PM   #1835
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by juanam0909 View Post
thanks for youre help sir, also how much will it poke out if possible do you have any pictures or link to something similar ?
It will poke out about an inch +/-.
Have a look at the various wheels and offset here:
http://www.ft86club.com/forums/showthread.php?t=7535
I see that there is at least one guy running that exact setup, but probably not without massaging some camber settings to get it to work. Lots of stuff to look at in that thread. Will keep you busy for a while.
Slick is offline   Reply With Quote
Old 09-27-2013, 04:55 PM   #1836
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I'll be trying it next Friday. I don't have any aftermarket suspension bolts or anything, just the RCE springs.
Originally Posted by Slick View Post
Statement or question?
Should be close, depends on your camber though. Let us know.
Originally Posted by humfrz
I'm old and lazy
Old 09-28-2013, 12:38 AM   #1837
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Enkei Raijin
Setup 1(preferred):
18x8.5 +45 : 245/40
18x9.5 +45 : 275/35
Setup 2:
18x8.5 +45 : 245/40
18x9.5 +45 : 265/35
Setup 3 (most people on Enkei Raijin thread used this)
18x8.5 +45 : 245/35
18x9.5 +45 : 265/35
Current setup : Stock struts with swift springs 1". Front 0 deg chamber. Rear -2 deg chamber.
Any rubbing issues on setup 1 and 2? TIA
hanabie is offline   Reply With Quote
Old 09-29-2013, 12:04 AM   #1838
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Originally Posted by hanabie View Post
Enkei Raijin
Setup 1(preferred):
18x8.5 +45 : 245/40
18x9.5 +45 : 275/35
Setup 2:
18x8.5 +45 : 245/40
18x9.5 +45 : 265/35
18x8.5 +45 : 245/35
18x9.5 +45 : 265/35
All good.
Edit- see 2point0's response below regarding tire sizing. It will fit, but they are noticeably taller as he kindly points out.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
The Following User Says Thank You to ill86 For This Useful Post:
hanabie (09-29-2013)
Old 09-29-2013, 03:22 AM   #1839
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Enkei Raijin
Setup 1(preferred):
18x8.5 +45 : 245/40
18x9.5 +45 : 275/35
Setup 2:
18x8.5 +45 : 245/40
18x9.5 +45 : 265/35
18x8.5 +45 : 245/35
18x9.5 +45 : 265/35
245/40 on an 18" wheel? That's over an inch taller than stock... 245/35 is popular because it's the correct diameter.
There are many online tire calculators out there. For instance...http://www.miata.net/garage/tirecalc.html
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following 3 Users Say Thank You to 2point0 For This Useful Post:
hanabie (09-29-2013), ill86 (09-29-2013), Slick (09-29-2013)
Old 10-04-2013, 01:53 AM   #1840
hanabie
hanabie's Avatar
Sorry for more inquiry.
What is the widest tire for 18x9.5 +38 square setup no rubbing with stock struts and lower springs (swift)?
Is any chamber correction required?
If yes, what part do I need without going to coils? chamber/crash bolts?
Thanks
18x9.5 +38 245/35 will it rub my front strut?
Old 10-06-2013, 11:20 AM   #1841
raytrix
Drives: Series 10 FR-S
I'm looking to buy a set of custom 2pc wheels and I'm torn between 3 offsets. I plan to run a 18x9.5 square setup with 225/40 tire on it. I plan to lower it quite a bit where a quarter of the tire is tuck. Which one of these offsets would be the absolute best fitment.
18x9.5 +25 (104mm / 4.09" lip)
18x9.5 +27 (102mm / 4.01" lip)
18x9.5 +30 (99mm / 3.90" lip)
Because this is a custom 2 piece wheel, each mm I go lower means I gain more lip. At +25 offset currently I have 104mm (4.09"). Also I plan to run Super Low Disk all around (25mm back pad) vs Normal disk up front (38mm back pad) since Wilwood brakes only stick out 18mm from the surface of the rotor hat I should be able to fit Super Low Disk up front to gain maximum lip on the wheel. What do you guys think?
raytrix is offline   Reply With Quote
Old 10-08-2013, 11:42 AM   #1842
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
I'm new to dealing with "offset". Hopefully someone can answer my questions.
Wheels: 18x8 +45.
Car is lowered on Eibach Sportlines (1.4").
What do I need for perfect flushness?
Will the new wheels be close to flush without the use of any spacers?
If I need spacers, what size exactly do I need for front and rear?
Thanks for all of your help. I feel like I've figured it out but I want to be safe and ask someone who actually knows for sure.
ericmpena is offline   Reply With Quote
Old 10-08-2013, 01:58 PM   #1843
hanabie
hanabie's Avatar
245/35 or 255/35 for 18x9.5 +38 squared. TIA
Old 10-08-2013, 02:04 PM   #1844
RavSpec
Drives: Rx7
u can use 245/35 front and 255/35 rear.
RavSpec is offline   Reply With Quote
The Following User Says Thank You to RavSpec For This Useful Post:
hanabie (10-08-2013)
Old 10-08-2013, 02:07 PM   #1845
RavSpec
Drives: Rx7
Wheels: 18x8 +45.
need 15mm spacer front and 25mm spacer rear to be near "flush".
Not ideal fitments on BRZ for flush, but good for track (if light weight) and use thick tires.
Old 10-08-2013, 02:08 PM   #1846
RavSpec
Drives: Rx7
Go with 18x9.5 +27 .. use 225/40 but you can do 245/35 tires on the rear.
Old 10-08-2013, 04:02 PM   #1847
Mister Torgue Flexington
Don't mind me...
Drives: WRB BRZ
So I know that an 18x9.5 +32 front and 18x9.5 +25 rear will fit, but how well will it work with a 265/35/18 tire and a 1-inch drop? Am I going to rub?
THAT SENTENCE HAD TOO MANY SYLLABLES! APOLOGIZE!
Mister Torgue Flexington is offline   Reply With Quote
Old 10-08-2013, 11:25 PM   #1848
hlk gts
Drives: Toyota ZN6
First of all thanks to the experience ones to contribute this thread
My question is:
Will front 18x8.5" +45 cause any rubbing during turning, especially full turn? I will keep the overall rim+tyre diameter as close as possible to the stock and no modification on height, camber and etc..
Thanks
hlk gts is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
