Old 10-02-2013, 03:32 PM   #29
Fabron757
Drives: 2013 blue frs m6 BW EFR 7064 Turbo
Hey don't get on it until u get the problem fixed. If something don't feel right, don't chance it.
Fabron757 is offline   Reply With Quote
The Following User Says Thank You to Fabron757 For This Useful Post:
Adeets (10-02-2013)
Old 10-02-2013, 03:50 PM   #30
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
I second this motion.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 10-04-2013, 12:12 PM   #31
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
So i've got a response from Toni, and its not within the Tune, it's because I don't have my injectors or fuel pump. So i'll order it next year. But problem is, I hope there is no damage as i've already done 2 drift sessions and tons of 1/4 miles. Grrrrrr...
Scalzo is offline   Reply With Quote
Old 10-04-2013, 02:17 PM   #32
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
94 octane not pulling
Which trim kit do you have and how much boost are you running?
Last I checked, unless he sold it, @Sportsguy83 was selling a good combo of fuel injectors and fuel pump.
And yes, you're causing damage if you're starving the motor of fuel. Boost with a lack of fuel can be quite catastrophic.
With the 57 trim 7 psi is the max for the stock fuel pump and injectors, not sure which is the bottleneck so I said both. As a safety precaution and to give a bit more of a safety buffer, I err on the side of upgrading the injectors and pump when boosting it.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 10-04-2013, 03:30 PM   #33
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
He sold them already and got paid in $1 bills.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
ecko04 (10-04-2013), Sportsguy83 (10-04-2013)
Old 10-04-2013, 03:32 PM   #34
Scalzo
Scalzo's Avatar
I got the 57 trim, on my boost gauge i boost peak at 8-9 PSi.
I'll be buying fuel injectors and pump soon. Just waiting for my UEL headers to come in! been a month already :/
Old 10-04-2013, 03:34 PM   #35
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Yeah outside of the range for stock fueling. If you insist on boosting, safely, I would dial the boost back to 5-6psi and wait for the injectors and pump, along with a tune adjustment, before cranking it back up.
Old 10-04-2013, 03:38 PM   #36
Scalzo
Scalzo's Avatar
i dont know why its boosting that high.. I dont have a mbc or ebc..
Old 10-04-2013, 03:41 PM   #37
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Well that's another issue. Have you changed the the 5psi base pressure spring?
You're doing some over boosting there. Without some boost controller that spring should max around 5.4psi.
Old 10-05-2013, 11:29 AM   #38
Scalzo
Scalzo's Avatar
It was the yellow spring for waste gate right?
Old 10-07-2013, 10:28 AM   #39
mad_sb
Drives: 2013 Asphalt FR-S
Ever since I put the 3" turbo back i've had this prob, I'm putting the new fuel pump next summer along with injectors. I called Toni he said hes gonna check the datalog
This, larger exhasut on a turbo car = less backpressure in the turbine and exhaust manifold section = more boost. Your boost went up when you installed this exhaust. Your tracking load ranges that were probably not tuned and you are probably beyond the fueling capacity now, or some combination of those two things. Also, if you are using an MBC or just spring pressure, you will make more boost in the higher gears. You need to get the boost back to were you were tuned or where the stock fuel system can keep up. If you need to turn the boost down, get a softer spring for your wastegate, and an mbc if you don't already have one.
The Following 3 Users Say Thank You to mad_sb For This Useful Post:
Sellout (10-08-2013), Sportsguy83 (10-07-2013), TheRipler (10-07-2013)
Old 10-07-2013, 11:44 AM   #40
Scalzo
Scalzo's Avatar
So basically to be properly set up I need the following:
- injectors
- Fuel pump
- EBC or MBC
and of course a retune
Old 10-07-2013, 12:04 PM   #41
Andy@FA20Club
Drives: FA20Club.com
Andy@FA20Club is offline   Reply With Quote
Old 10-08-2013, 06:11 AM   #42
mad_sb
- injectors
- Fuel pump
- EBC or MBC
And the softer spring for your wastegate. Boost controllers bleed reference pressure away from the wastegate diaphragm allowing you to raise boost.
In your case, you need to lower boost so you don't turn your motor into a frag gregnade. A softer wastegate spring will lower the base boost pressure for now until you can get the tune and the fuel supply sorted out.
If the boost is too low with the softer spring, then you can add a boost controller to get it back into the range you were tuned for.
As for electronic vs manual... most EBC's are no better than MBC's at maintaining the same boost in each gear. They do tend to improve spool though.
My two favorite EBC are:
Apexi AVC-R - hands down the best EBC i have ever tuned. It has per gear base wastegate duty cycle compensation and per gear boost targets. Yes, 1990 called and wants it's superAFC back, but once you get past the looks it is the tits.
Greddy Profec B Spec 2 - best budget ebc. easy to setup, has overboost boost cut. Just make sure you get a real one and not an ebay counter-fit one.. those are a nightmare and create a sawtooth boost pattern from hell.
DIY fender rolling and pulling? OICU812 DIY (Do-It-Yourself) Guides 12 01-02-2017 09:02 PM
Brz pulling trailer? subiesteve Southwest 7 11-20-2013 09:04 PM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 01:23 AM
Pulling your FRS off of the lot, what are you bumpin'?? poormans_LFA BRZ First-Gen (2012+) — General Topics 201 06-09-2012 09:52 PM
Pulling the trigger tomorrow Style Scion FR-S / Toyota 86 GT86 General Forum 13 05-14-2012 02:38 PM
