Old 05-07-2013, 08:23 PM   #1
ShowTime_DW
Drives: FRS
get 16“ rims for winter?
Is it a good idea to get a 4 16" rims and tires in the winter just cuz it is cheaper than 17"? I wondering the ground clearance will be less and get easily stuck in the snow...
ShowTime_DW is offline   Reply With Quote
Old 05-07-2013, 09:35 PM   #2
FRiSson
Drives: FR-S MT
If you choose a higher-profile snow, such as a 205/55/16, the diameter will be just about the same.
FRiSson is offline   Reply With Quote
Old 05-07-2013, 09:51 PM   #3
roddy
roddy's Avatar
Drives: '13 Ultramarine
This.
That is the size I ran last winter. We had more snow than we've had in a long time, and the car worked great. I used Bridgestone Blizzak WS-60s. I was pushing snow with the lower part of the front bumper a couple of times on my way into work, but the nannies combined with a great set of winter tires kept me moving forwards and under control. Generally speaking, for snow use, you'll want a skinnier tire with more sidewall (hence the 16" rim size) for the best bite. You will give up some dry handling, but the trade-off is worth it.
Old 05-07-2013, 11:36 PM   #4
ShowTime_DW
Drives: FRS
Originally Posted by roddy View Post
This.
Thanks, I guess I will use the one you were using lol
Old 05-07-2013, 11:50 PM   #5
ShowTime_DW
Drives: FRS
where did u get the wheels? used?
Old 05-08-2013, 12:06 AM   #6
wheelhaus
wheelhaus's Avatar
This is what I'm doing, 205/55/16's on black steel wheels from Tire Rack.
There's some tire diameter comparison sites that let you punch in different tire specs to find the closest tire diameter when using a different rim size. If you get it really close (close to or better than 1% +/-) there's virtually no difference in ride height or diameter.
Old 05-08-2013, 12:32 AM   #7
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
What other cars use the same bolt pattern? Any old Celica, Capri or Taco?
Need enough room for the calipers though.
Be good to know when cruizing Craigslist.
Old 05-08-2013, 02:19 AM   #8
wheelhaus
wheelhaus's Avatar
I'm pretty certain most Subaru 5x100 wheels will fit same as stock, but it's worth some quick research to verify... I believe most have the same offset, etc.
Old 05-08-2013, 04:01 AM   #9
Meaty
Drives: Gts86 ordered, lancer vrx daily
cant go past http://www.carbibles.com/tyre_size_calculators.html for working out Tyre geometry
Meaty is offline   Reply With Quote
Old 05-08-2013, 07:53 AM   #10
roddy
roddy's Avatar
I used new black steel wheels on mine. They were about $50/ea and were the same wheels used for an Impreza. Some people were able to find them at Costco for even less than that. If you don't like the look of plain steel wheels, you should be able to find a set of OEM Impreza aluminum wheels used for a pretty decent price.
Old 05-08-2013, 10:35 PM   #11
FRiSson
Drives: FR-S MT
Tire Rack steelies. Michelin X-Ice3 tires.
Old 10-01-2013, 10:39 PM   #12
Muskokan
Drives: white Sport-tech
I've got a set of 205 55 16's on 16" rims, will these work???
Edit: nvm thought you guys were saying 225 55 for some reason.
Muskokan is offline   Reply With Quote
Old 10-02-2013, 11:22 AM   #13
frs10
Drives: tezla
whats the difference between the blizz ws60 and ws70?
frs10 is offline   Reply With Quote
Old 10-04-2013, 02:17 PM   #14
Chinadian
Chinadian's Avatar
Drives: FRS Whiteout
I have michi xice3 n black steelies
Was wondering if n e one has painted their steelies like orange or sumtin becuase the black looks alil boring
Chinadian is offline   Reply With Quote
15 inch rims for winter? CBR600RR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 08-12-2023 05:42 PM
Poll: Winter Tires and Rims FRiSson New England 47 12-08-2012 04:15 PM
Winter Rims RandomHero Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-05-2012 09:06 PM
Winter Tires and 17" Rims?? stalon320 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-03-2012 09:33 AM
Cheap winter alloy rims Sport-Tech CANADA 52 04-18-2012 11:30 PM
