#15 |
Official anti-BS squad
Drives: Toyota 86 High 6MT
One thing I need to mention - with the key barrel removed you obviously need to plug the hole. This is where your ingenuity comes in.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
#16 |
Drives: 2013 Subaru BRZ
#17 |
Where is this switch?
95RON SAV Tuned |
#18 |
Drives: DGM
^^ Just a heads up... I've accidentally had the valet switch activated in the trunk and had to use the key to open the trunk with my keyless (smart) system.
#19 |
Drives: BRZ Limited 6MT
You will regret it when you accidentally push the button inside the trunk. The only way to open the trunk is with the key if you do that.
#20 | |
Also, the seat folds flat from inside, so no problem.
95RON SAV Tuned |
#21 |
Drives: FR-S Series 10 #0059
There's a valet button in the trunk, next to the left wheel well. If you push it, you can no longer use the the trunk release lever, key fob trunk button and keyless entry, so you'd to use need the actual key to enter. That way you can hand off the keyfob to a valet without them getting access to stuff in your trunk.
#22 |
Thanks, I've had a look - don't have that button.
Surely they could get into the trunk from inside by folding the seat flat if they wanted to?
95RON SAV Tuned |
#23 |
Might be differences in trim, but I was under the impression the valet button was standard on all 86 versions.
You have to pull two straps on the back of the seat to release the latches before you can fold it, so it's "secure" if you can't get in the trunk. |
#24 | |
And like rishi said. The straps must be pulled from inside the trunk. So unless the seats are already folded down you will be locked out of your trunk.
Build Thread:
http://www.ft86club.com/forums/showthread.php?t=43355 |
#25 |
Drives: FR-S 10 #103 AT
I would love to put one of these on my FR-S 10 but near as I can tell there is no way to use the stock HU as a display and I love the look of the mirror it came with, so what do I do for a viewscreen?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#26 | |
a/k/a ikuzOtaku
Drives: Whiteout FRancheSka
thanks
#27 |
Thanks, ours is definitely different then. No button and no straps. You press 2 "buttons" on top of the seat on the inside to fold them flat.
95RON SAV Tuned |
#28 |
I didn't take pics unfortunately. Removed the trim on the left side of the trunk as well as the plastic piece next to the front seat and ran it through there. There is a nice channel for the wires.
95RON SAV Tuned |
| Question on drilling new holes | WolfsFang | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 17 | 12-06-2012 09:02 AM |
| Front bumper drilling/plates | mooshoepork | AUSTRALIA | 5 | 11-18-2012 07:02 PM |
