Old 09-30-2013, 05:52 PM   #15
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
One thing I need to mention - with the key barrel removed you obviously need to plug the hole. This is where your ingenuity comes in.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 09-30-2013, 06:10 PM   #16
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
one other thing, you should probably unplug the switch in the trunk that makes the trunk only open with your key.
Flat Black VW is offline   Reply With Quote
Old 09-30-2013, 06:21 PM   #17
sav
sav's Avatar
Where is this switch?
95RON SAV Tuned
Old 09-30-2013, 09:31 PM   #18
toysub
Drives: DGM
^^ Just a heads up... I've accidentally had the valet switch activated in the trunk and had to use the key to open the trunk with my keyless (smart) system.
toysub is offline   Reply With Quote
Old 09-30-2013, 09:57 PM   #19
Zoti
Drives: BRZ Limited 6MT
Yep, removed it and sealed the hole after pulling the camera's wires through.
I've never used or needed a key to open the trunk on any car I've owned over the last 10 years so I doubt it'll ever be a problem.
You will regret it when you accidentally push the button inside the trunk. The only way to open the trunk is with the key if you do that.
Zoti is offline   Reply With Quote
Old 10-01-2013, 02:30 AM   #20
sav
sav's Avatar
Which button? I'm pretty sure I don't have a button inside the trunk?
Also, the seat folds flat from inside, so no problem.
95RON SAV Tuned
Old 10-01-2013, 11:52 AM   #21
rishi
rishi's Avatar
Drives: FR-S Series 10 #0059
There's a valet button in the trunk, next to the left wheel well. If you push it, you can no longer use the the trunk release lever, key fob trunk button and keyless entry, so you'd to use need the actual key to enter. That way you can hand off the keyfob to a valet without them getting access to stuff in your trunk.
rishi is offline   Reply With Quote
Old 10-01-2013, 12:07 PM   #22
sav
sav's Avatar
Thanks, I've had a look - don't have that button.
Surely they could get into the trunk from inside by folding the seat flat if they wanted to?
95RON SAV Tuned
Old 10-01-2013, 03:03 PM   #23
rishi
rishi's Avatar
Might be differences in trim, but I was under the impression the valet button was standard on all 86 versions.
You have to pull two straps on the back of the seat to release the latches before you can fold it, so it's "secure" if you can't get in the trunk.
Old 10-01-2013, 07:25 PM   #24
Flat Black VW
Yeah I would check again if I were you. I am pretty sure its always there. Many people have had issues getting in after the button being pressed by something rolling around in the trunk.
And like rishi said. The straps must be pulled from inside the trunk. So unless the seats are already folded down you will be locked out of your trunk.
Old 10-01-2013, 08:46 PM   #25
mid_life_crisis
Drives: FR-S 10 #103 AT
I would love to put one of these on my FR-S 10 but near as I can tell there is no way to use the stock HU as a display and I love the look of the mirror it came with, so what do I do for a viewscreen?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 10-02-2013, 02:44 AM   #26
chjno86
a/k/a ikuzOtaku
chjno86's Avatar
Drives: Whiteout FRancheSka
Thanks. It took some time but was easy enough.
Removed the plastic piece as pictured above to fit the camera as well as the boot trim on the left hand side and the one panel by the left hand side door to run the wires through. Power for the camera as well as head unit reverse trigger wires are fed from the reverse light.
There are 2 wires running to the radio - trigger wire and RCA.
can you show or tell where you ran the wires from the trunk to the radio?
thanks
instagram.com/chjno86 __ #TEAMFRANCHESKA _ #SOCALVALLEY86
chjno86 is offline   Reply With Quote
Old 10-02-2013, 04:51 AM   #27
sav
sav's Avatar
Thanks, ours is definitely different then. No button and no straps. You press 2 "buttons" on top of the seat on the inside to fold them flat.
95RON SAV Tuned
Old 10-02-2013, 04:54 AM   #28
sav
sav's Avatar
thanks
I didn't take pics unfortunately. Removed the trim on the left side of the trunk as well as the plastic piece next to the front seat and ran it through there. There is a nice channel for the wires.
95RON SAV Tuned
Question on drilling new holes WolfsFang Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 12-06-2012 09:02 AM
Front bumper drilling/plates mooshoepork AUSTRALIA 5 11-18-2012 07:02 PM
