Old 10-01-2013, 10:36 AM   #1
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
94 octane not pulling
I've realized that my car doesn't pull at 4th or 5th gear, could it be because i have 57 trim? It just makes a lot of noise but doesn't pull hard like let's say 3rd gear
I'm still learning to be nice :P
Sent from my iPhone using Tapatalk - now Free
Scalzo is offline   Reply With Quote
Old 10-01-2013, 10:58 AM   #2
DJCarbine
Thupercharged
DJCarbine's Avatar
Could be as simple as 4th gear just doesn't pull as hard, or something else like a boost leak so the turbo is "working" way too hard
Is this a new development, or has the car always behaved like this
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 10-01-2013, 11:27 AM   #3
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
It's cause you are Canadian. Have you datalogged it? Do you have any way of monitoring your boost and AFR during these pulls?
Old 10-01-2013, 11:41 AM   #4
fenton
The 94 we have here in Canada is actually really good. I have experience with Husky only and i never see knock in my logs.
What RPM are you starting from? If you are starting from 2000rpm you are just going to be creating a whole bunch of load and yes it wont go anywhere for a while.
Now if you are starting at 4000 rpm in 4th you should be moving pretty quick in no time.
fenton is offline   Reply With Quote
Old 10-01-2013, 07:33 PM   #5
Scalzo
Scalzo's Avatar
I have a AFR/Boost monitor .. Boost hits up to 9~psi which i think is too high because I should be hitting 7 MAX .. AFR is around 12.8~
I don't know i don't really do a lot of dyno pulls. I checked for any boost leaks and everything seems to be fine.
Starting at about 4500RPM and stomping the gas it doesn't go far. it's weird, It could of always been like that. I did a virtual dyno and it says i have 291HP 225 TQ .. I just realized now on the high way that after 3rd gear and slam it to 4th it doesn't go far lol. It was just a random question wanted to see if anyone else experienced it
Old 10-01-2013, 07:33 PM   #6
Scalzo
Scalzo's Avatar
I"m thinking it's probably my lack of injectors/fuel pump
Old 10-01-2013, 09:20 PM   #7
arghx7
Drives: car
You've got to post some kind of data log or dyno sheet.
Old 10-01-2013, 09:26 PM   #8
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
94 here is awesome, use chevron if you can it is the only one without ethanol (atleast in BC)
FreshFRS is offline   Reply With Quote
Old 10-02-2013, 09:30 AM   #9
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
That would effect every gear, your tuning doesn't change based on the gear your in, unless you have an EBC, then it's an option.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
The Following User Says Thank You to Adeets For This Useful Post:
SkullWorks (10-08-2013)
Old 10-02-2013, 09:46 AM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
My only guess is that you are pulling more boost in 4th gear and hitting a boost cut that was put in your tune.
Old 10-02-2013, 10:49 AM   #11
Scalzo
Scalzo's Avatar
This help?
Old 10-02-2013, 10:53 AM   #12
Adeets
OEDC
Adeets's Avatar
Holy shit lean.
My BRZ FI Build
Old 10-02-2013, 12:04 PM   #13
Scalzo
Scalzo's Avatar
Originally Posted by Adeets View Post
Holy shit lean.
Thats what I'm saying...
Old 10-02-2013, 12:12 PM   #14
Adeets
OEDC
Adeets's Avatar
You need to contact your tuner, and get it to a dyno or street tune. That's unsat.
My BRZ FI Build
DIY fender rolling and pulling? OICU812 DIY (Do-It-Yourself) Guides 12 01-02-2017 09:02 PM
Brz pulling trailer? subiesteve Southwest 7 11-20-2013 09:04 PM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 01:23 AM
Pulling your FRS off of the lot, what are you bumpin'?? poormans_LFA BRZ First-Gen (2012+) — General Topics 201 06-09-2012 09:52 PM
Pulling the trigger tomorrow Style Scion FR-S / Toyota 86 GT86 General Forum 13 05-14-2012 02:38 PM
